Jeepmmmj
    Orlando
  • Interests
    Fishing, jeeps, work
806 profile views
Jeepmmmj's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. was it one with headrests or without?
  2. thanks man, yeah i am in central florida. i am willing to spend about 300 bucks getting one to me. i believe i have someone that will meet me just north of atlanta with a bench and a headliner. waiting to see how things pan out on that for now..
  3. No I have not yet. I was hopping to get something stock but can you point me in the dierection of what some people are doing to put them in their mj?
  4. bump ready to buy
  5. looking for a grey or black bench seat for my 91 comanche project. also need a headliner board. please let me know if anyone has anything available. I'm located in central florida
  6. this is exactly what mine just started doing. Cool weather ok. Hot. No go..
  7. I understand this but since this is a daily I would like to have a shaft made before hand if possible so I can get it done quickly and efficiently And I understand that too. Just saying pick a point close to the end of the project, then measure and submit your order. A good local shop can turn it around in a day. One-half an inch error can make or break the project. Too short you can make it up with a longer slip yoke. Too long and you're screwed unless you have enough extension on the yoke to hack some off. I have to admit I found out the hard way................... Thank you for your advise. I am just getting a little excited and jumping the gun and rushing a tiny bit. My long wait for a good 4x4 ax15 is over and I've got the axle and other parts on the way :) I didn't mean to sound like a smart Alec earlier lol
  8. I understand this but since this is a daily I would like to have a shaft made before hand if possible so I can get it done quickly and efficiently
  9. Did you go with an SYE too. Or the stock slip yoke and shortened stock shaft?I went with stock slip yoke, but the drive shop i used wouldn't shorten then stock double wall shaft with the rubber membrane in it, so I got an XJ shaft lengthened. It cost more. Sent from my SM-N900W8 using Tapatalk did you happen to have any lift on the jeep or is your measurements for stock height?
  10. Did you go with an SYE too. Or the stock slip yoke and shortened stock shaft?
  11. I've got the short bed 91 eliminator with a 2wd ax15. I will be putting in a 4wd ax15 with a 231. It's from a 93 Cherokee. It should fit fine I'm assuming? My main question though is can I use a Cherokee rear driveshaft or do I need to get one cut to size? Thanks in advance and other tips and recommendation are appreciated for the swap :)
  12. It was the sensor in the thermostat housing telling my ECU I was running all kinds of different Temps and confusing the ECU
  13. That's an odd one. How did you troubleshoot and find that? Finally had the scanner on it while it was acting up. The temp sensor was all over the place every time the truck acted up reading anywhere from negative 3 - 210 degreeS. The cooler the temperature reading the higher the idle.
  14. Found this issue to be the coolant temp sensor!
  15. Thank you all for the replies I'll be putting some hours in on it in the morning and will give an update :)
