Eagle
Moderators
    27
Everything posted by Eagle
  1. That's really great. It's a sad reason for a parade, but it's heart warming to see Jeepers take the time out to recognize one of our own.
  2. The NP 231 is a much better transfer case than the NP 207, but you have to be sure the one you get has the same spline count as your transmission. Considering that you can't just bolt a transfer case to a 2WD transmission, IMHO you're far ahead of the game if you buy an AX-5 5-speed transmission and transfer case together. The AX-4 and AX-5 are the same for the first four speeds and reverse, so you could keep the AX-4 for spare parts. In addition to a front driveshaft, the transfer case obviously adds a lot of length behind the transmission, so you will either need a different rear driveshaft, or you'll have to have your driveshaft shortened.
  3. Adjustable MAP sensor.
  4. A '90 with the Big Ton package should have a Dana 44 rear. I don't think that has inner and outer seals. I'm pretty certain there's only one seal on each side, at the outer end where the bearing race fits into the end of the axle tube. For $150 to $250 that better be for both sides, and the seals better be gold plated.
  5. This. Cruiser, I think we have a bunch of youngsters here who have never owned a car that had an adjustable distributor. Or a carburetor, with an idle speed screw and an idle mix screw.
  6. That's what I plan to do with my '88. I think I have two screws snapped of that are supposed to hold the headlight bezels in place. Best solution I can think of. I plan to use stainless steel screws, and liberal anti-sieze.
  7. Tacking this question onto a five-year old thread is confusing. I split this new question out.
  8. https://comancheclub.com/topic/58217-1986-comanche-x-slave-cylinder-bleeding-issue/
  9. Don't do that. The ballast resistor only has two wires. If you can't identify which two connect to it, you may fry something else. Do your homework, don't just play three blind mice.
  10. More to the point, how is it even possible? 2.5L 5-speeds came with 4.10 gears. It was the 2.5L 4-speeds that came with 3.55 gearing.
  11. Because the transfer case uses ATF as the lubricant, and ATF is red.
  12. Tranny fluid? A Renix has a mechanical speedometer. It's remotely possible that your transmission or transfer case breather is clogged and as the case heats up the lube is being driven up the speedo cable and coming out where it attaches to the speedo head.
  13. My apologies. I zeroed in on the '85, without paying attention to the fact it's going into an '86 MJ. Yes, the '86 has a Renix injection/ignition system, so it needs a flywheel out of an '86 - '90 XJ or MJ 2.5L.
  14. The '85 used a carburetor and a conventional distributor. No CPS to worry about.
  15. I've been doing brakes for 60 years and I've never heard of pushing the peddle down before opening the bleeder. Different strokes for different folks, I guess.
  16. How is this different from bleeding brakes?
  17. I'm completely confused. You bought and laid sod just so you could tear it up and pour concrete?
  18. Then something isn't right, because the function of the thermostat is to shut off coolant flow through the radiator when the coolant temperature falls below 195 degrees.
  19. Wider track will make it more stable on the road, but it's going to create massive issues with the tires hitting the bodywork when you try to turn. Take it one step at a time. First, most factory wheels are 7" and the ones you're looking at are 8". If we use backspacing as the benchmark, with the same backspacing an 8" rim extends outboard on the vehicle one inch more than a 7" rim. Now reduce the backspacing by two inches. That pushes the entire wheel outboard another two inches relative to the hub, axle, and chassis. So you're now looking at the tires sitting three inches farther out (on each side) than stock. Then add a spacer/adapter and you're at 5" or 5-1/2", depending on how thick the adapter is. That's on each side. Consider that when the front wheels turn, the tire and wheel are rotating around the axis of the ball joints. Put your truck up on jack stands and watch the front tires while you have someone turn the steering wheel. Now imaging how it will be with 33-inch tires that have the outer shoulder 5 inches farther outboard. (Actually, more than 5", unless the tires you have on now are 12.5" wide.) Lastly, consider that with the tires sticking out an extra 5+ inches on each side you may be inviting tickets for unsafe equipment. I think every state has laws or regulations that require the bodywork to cover the tires. Those laws are enforced sporadically, but the farther out the tires stick the more likely you are to get cited. I one got a warning for 31x10.50s on stock rims, because I didn't have front flares and the tires stuck out about an inch (maybe an inch and a half). Afterthought: Also remember that you're only extending the tire and wheel outboard, the hub and bearings will remain in the same place. That means you will be greatly increasing the eccentricity of the load on the hub/bearing unit, which will result in the hub/bearing units wearing out faster.
  20. The long-standing rule of thumb is that the rim width should not be narrower than 4" less than the nominal tire width. Have people gone smaller? Sure. What happens, though, is that the narrow rim pulls the sidewall way in at the bead, causing the tread area to bow up at the shoulders. To get the tread to run more or less flat on the pavement, you have to lower the tire pressure too much. Otherwise, you're just driving on the center portion of the tread and the tire mileage goes into the toilet. On factory wheels (or 8" rims), you'd be better off running 33x10.50s.
  21. It depends on the year. If you have an early MJ with the front hubs set up with conventional bearings, the calipers are different from 4WD. If you have a later one with the unitized hub/bearing assemblies, the calipers are the same.
  22. All tire sizes have a range of acceptable rim widths, and an optimum. Consult the tire manufacturer. For example, here's a link to the specs for the BFG T/A KO2: https://www.bfgoodrichtires.com/upload/bfgoodrich/specifications/specs-all-terrain-t-a-ko2.pdf If you look up the 33x12.50-15, the range of rim widths is 8.5" to 11", and their specified dimensions are for a 10" rim (so I assume they consider 10" to be the optimal rim width).
  23. What's the backspacing? Stock Jeep 15x7 rims are 5-1/4" backspacing. As far as I know, nobody has yet found any aftermarket rim with that much backspacing. Your opening post said these "new" wheels are 5x5.5 bolt circle. Your hubs are 5x4.5. That means you can't use these wheels without adapters.
  24. It's called a "dimmer" switch because the switch that controls the headlight high or low beams has been called a "dimmer" switch for at least 75 years. It would be more confusing to change the terminology now. The actual switch isn't just a turn signal switch, it's now a multi-function switch. It controls both the turn signals and the high/low beams. In newer vehicles, the same switch also controls the hazard flashers.
