27
Everything posted by Eagle
HELP!! Cluster replacement issues
Eagle replied to SchneiderFishing's topic in MJ Tech: Modification and Repairs
I agree with Hornbrod ... who, by the way, knows a thing or three about electrical circuits. As he noted, the normal range of movement for all the small gauges is from approximately 10 o'clock to 2 o'clock. Any gauge with the needle outside of that range is seriously broken. -
Getting new aux fan, will the plug be the same?
Eagle replied to lostissues's topic in MJ Tech: Modification and Repairs
The old fan uses a standard 2-conductor weatherpak connector that you can buy at Auto Zone or Advance Auto. -
I think MiNi is correct. I'm pretty certain the new style fan has a different plug. -
That's usually what causes a diff to pee the juice out around the pinion. What did you think the problem was?
The gauges can't spin 180 degrees out, because they only have about a 90-degree sweep and I believe there are stop pins at both ends of the range. Please take a deep breath, slow down, and explain exactly what they are (or aren't) doing. -
Converting to new style 2WD hub assemblies.
Eagle replied to Windowsrookie's topic in MJ Tech: Modification and Repairs
I was thinking the same thing. But I can't see ANY reason to make this conversion. It'll mean buying new hubs, new rotors, new calipers, new pads ... and every time a hub goes bad you're looking at another $125 to replace, compared to ... what, for a standard wheelbearing and grease seal? $20? This swap does not strike me as being a great idea. -
They had heavy-duty suspension and they had a fast idle switch or solenoid so the battery would keep charging even if left standing for long periods with the lights on and radios, flashers, etc all running. They also had rubber floor mats rather than carpets. The local VA hospital where I go for medical issues used to run them. They were recently retired and replaced by Exploders.
They had heavy-duty suspension and they had a fast idle switch or solenoid so the battery would keep charging even if left standing for long periods with the lights on and radios, flashers, etc all running. They also had rubber floor mats rather than carpets. The local VA hospital when I go for medical issues used to run them. They were recently retired and replaced by Exploders.
Why would you need to replace a spindle? They have replaceable bearings. Did a bearing get so bad it started to chew up the spindle along the taper? -
let's have it, leaf spring from MJ on an XJ?
Eagle replied to MiNi Beast's topic in MJ Tech: Modification and Repairs
What makes you think there are advantages? I can't even figure out how you could make this work. The MJ springs are 5 inches longer. You can't make that all up with shackles, and there isn't enough body/chassis behind the XJ shackle mounts to relocate them anywhere near 5 inches farther back. -
I just re-read the original post. First off, if the goal here is just to get a freebie Jeep running, I think suggestions about swapping out axles and so forth are a bit off-topic. The simple solution is just to shim the disconnect. It's free and it takes less than an hour. However, the original question seems to suggest that the disconnect is connected and staying connected, and the OP wants to make it disconnect because he thinks it is harming the transfer case. That would be wrong. Starting in 1991 Jeep eliminated the disconnect front axle in the XJ, but they kept the NP 231 transfer case. The transfer case should shift into 2WD even if the front axle stays connected ... which is why shimming the disconnect to remain permanently connected is a useful work-around for problems with the vacuum shift motor. If the transfer case is making scary noises in 2WD, I would first verify that the noises are from the transfer case, and not perhaps a partially disconnected axle. Second, I would check to verify that the transfer case linkage is adjusted correctly so that with the lever in the 2WD position, the t-case is fully disengaged from the front drive shaft.
What wiring? The wiring is all in place already. And if the '87 has the gauges, the engine will already have the correct sending units.
Removing/modifying floor bracing
Eagle replied to 90PioSport99's topic in MJ Tech: Modification and Repairs
I have not heard of anyone replacing the stock MJ bracing with the new style XJ bracing, but when they made the changes Chrysler claimed that the new Cherokees were "significantly" (I don't remember the exact percentage they claimed) stiffer than the originals, so you may be onto something. I will be interested to see how your job turns out. -
The full-size Wagoneer D44s are not an easy conversion. The front is the real bear, but for starters -- they are 6-bolt wheels, so if you have anything invested in your current wheels ... kiss it goodbye. The full-size Waggies were leaf spring in front, so you have to be prepared to either convert your MJ to leaves, or fabricate and attach all the bracketry for the coil springs and control arms on the D44 axle. Clayton's Off-Road offers (or used to offer) a kit to do just that. If he even still sells it, it'll look pricey ... until you sit down and start adding up what it'll cost you to chase down all the materials, fabricate all the pieces, then chase down and fabricate all the stuff you overlooked ... His kit is actually a bargain.
I usually use a 2 or 3-pound sledge hammer applied to the sidewall of the tire from the back side (i.e. from under the vehicle). The wheel should be jacked up, and since you'll be lying on the ground under the chassis, you need to be sure the truck is well supported. If you care about the wheel, be careful not to hit it. I had one MJ a year or so ago where that worked for three out of four, but it wouldn't "pop" the right front. Fortunately, that truck had stock steel rims and I have plenty of those, so I gave up hitting the tire and used a full-size (long handle rather than one-hand) sledge hammer applied directly to the flange of the rim. I destroyed the rim pretty thoroughly before it came loose.
The "Accesory" position is not the first click. Accessory is the opposite direction from the Run and Start positions, and does not energize either the fuel pump or the ignition. The first click toward "Start" is "Run," not "Acc." The fuel pump does run with the key in the "Run" position -- IF the pressure in the fuel rail has bled down enough to need it. If you park overnight and turn the key on (to "Run") you'll typically hear the fuel pump run for 2 to 4 seconds, until it builds pressure. If I drive one of my trucks home, shut it down, and a few minutes later turn the key to "Run," the pressure is still up and the fuel pump does not run.
You're going to put an industrial size charcoal grille on a WOOD framework? You lads better cook fast -- and carry a couple or six fully-charged fire extinguishers. That grille should be on an all-metal, welded frame, with no wood touching it.
They are. You probe each one with a multimeter. The Renix system does NOT store trouble codes. You got hosed for an $80 diagnostic that they could not possibly have run. Not necessarily. The pump stops running when the pressure in the fuel rail reaches the required pressure. If you try to start and get a fail to fire, walk away, then come back and try again before the pressure has bled down sufficiently, the fuel pump may not need to run ... so you won't hear it.
After sitting for 5 years, you have a lot of potential problems. 1. The parking brake cables are probably rusted. If the parking brake was left on, that would leave the cable rusted so that it hold the brake engaged even when you release the foot peddle. 2. The rear brake shoes may be rusted to the drums. If so, you will probably have to destroy the shoes to get the drums off. 3. The front pads are probably rusted to the rotors. You should pull the calipers, check the pads, and buff as much rust as you can off the rotors with a wire wheel or sanding disk, then reinstall.
2.5L Oil Consumption. What's typical?
Eagle replied to 1987Comanche's topic in MJ Tech: Modification and Repairs
Is that 40 miles one-way, or round trip? Either way, that works out to half a quart in either 200 miles or 400 miles, which is a quart in 400 or 800 miles. In general, a quart in 1000 miles is about normal for an older engine. A quart in 500 miles or less is excessive. -
But a TJ axle is a low-pinion D30. You lose the disconnect but you also lose the high-pinion differential. For the amount of work involved in swapping an axle, plus the need then to change the calipers, I would MUCH rather just shim the disconnect and be done with it. If you do that you don't even have to get involved in axle seals. That's only for if you remove the disconnect and replace with a solid axle shaft on the right side.
The ultimate wheel chock. Some people will do anything to avoid replacing a parking brake cable.
The transfer case shifts into and out of 4WD mechanically, by the lever. No vacuum involved. When in 4WD, the transfer case then sends vacuum through a port on the transfer case to a switch on the firewall, which controls the light, and then to the disconnect motor on the axle. What I would do is remove all the vacuum stuff, shim the disconnect to the engaged position, and drive it. The position of the lever will tell you when you're in 4WD. However, you can probably keep the vacuum line to the firewall switch if you want to retain the light, and just eliminate the harness from the switch to the axle disconnect motor. There are write-ups on this site on how to permanently shim the diconnect motor, so I won't repeat.
Will these gears work on my 88?
Eagle replied to WahooSteeler's topic in MJ Tech: Modification and Repairs
I agree. I bought 3.73s with the intention of using them in my XJ with 30" tires. Then I picked up the '88 MJ with the lift and my brother gave me his old 31" tires, so I put the 3.73s into the MJ. Not bad for street (much better than 3.07s) but not really enough gear for 31s. Based on MPH per RPM the overall final drive ratio for 31x10.50s and 3.73 gears is exactly the same as stock tires with 3.55 gears. But ... the 31s are a lot heavier. -
There should be a test port on the fuel rail. Have you tried pressing the valve to see if fuel squirts out? When you first turn the key, do you hear the fuel pump running for about 2 to 4 seconds?
