Eagle
Moderators
    27
Everything posted by Eagle
  1. That only tells you how much lift you have. More important is the caster angle and the pinion angle. Then you need the driveshaft angle to figure out the operating angle at the pinion u-joint. An excellent article to get you started is from our friend GoJeep, in Australia: http://gojeep.willyshotrod.com/HowtoAlignment.htm
  2. It sounds more like your transmission jumped one of the shift rods and is stuck in two gears at once. It happens -- I have two or three trannies out in the yard with that problem, that I haven't gotten around to opening up yet.
  3. Ka-Ching! :agree:
  4. Looks sort of like one of those long wheelbase Egyptian army trucks. If so ... is the photo from the U.S.? I don't know if those can even be imported (legally).
  5. BMW owners won't wave at you unless you own a Harley? :???: :dunno: :hmm: :fool:
  6. What year truck? Do you have a mechanical speedo with a cable, or an electrical speedo?
  7. Buddy, I don't know what you're doing wrong (or not doing right), but your photos are not showing up. And they don't work as clickable links, either.
  8. ALL ZJ "Dana 44s" have the aluminum housing. Aside from the housing being weaker than a D35, the internals are NOT standard D44. The pre-99 versions are 5 on 4-1/2, but otherwise just as terrible as the newer ones. VERY bad choice. Run away, as fast as you can.
  9. That's sort of like a guy with an airsoft calling out a dude who wears a Colt .45 on his hip and carries an M16, locked and loaded. In other word: "Dumb!"
  10. I guess that might be true but, if so, it doesn't make any sense (to me) at all. There is nothing about higher RPM that would in any way make the signal stronger. The CPS is basically a Hall effect sensor. It's a magnet -- when a tooth (high point) on the flywheel zips by it, the magnetic pulse generates a VERY small electric current. I haven't studied any Physics or electrical theory for over 40 years, but it seems to me that faster would equate to less time in proximity, which would equate to a weaker signal, not stronger. But, hey ... that's why we have Hornbrod around here. To explain to me why I don't know jack about 'lectricity. What the heck -- it's a '91, so it's OBD-compliant. Hook it up to a scanner or DRB and see what shows up as out-of-spec.
  11. Both Pat and 87mjdriver requested that confirmation be posted when Pat made good in his commitment(s) in that transaction. I told them we would do so, either by unlocking the "other" thread, or by starting a new thread. As far as I can see, we do not have confirmation of anything yet. We also have nothing on which to justify additional bashing. Accordingly, I am going to lock this thread, too. I would appreciate it if the intended recipients would contact me, Pete, or Shelbyluvv when they have received their package(s) from Pat, so we can see that the information gets disseminated. Meanwhile, allowing further piling on strikes me as counterproductive.
  12. If allowing the fuel pump to run until it shuts off before cranking doesn't eliminate the time lag, it obviously isn't the fuel pump. It also probably isn't the CPS, or it wouldn't start at all. I'll vote for bad spark plugs or dirty injectors.
  13. The entire "Trail Rated" schtick is a massive marketing fraud by Jeep (started under Daimler-Chrysler). Up through the intro of the original Liberty, Jeep always proved each new model by driving it across the Rubicon Trail. They tried to do that with the Libertine, too -- in the process, they royally trashed the vehicle, and had to resort to stacking rocks at a number of the obstacles to get the Libby through at all. So they decided they wouldn't actually test new Jeeps on the trail any more. They'd just call them "Trail Rated" and call it good. I wouldn't allow one of those badges on my Jeep. Any true Jeeper will fall down laughing at you and your truck if he sees those things. They are like advertising "Hey, World. Here I am. I AM A POSEUR!"
  14. 6-bolt hubs. Jeep rims won't fit. Bad idea Remember that the Exploder 8.8 is considerably narrower than the XJ/MJ axle. If you use an 8.8 in the back, you MUST use either aftermarket rims with a lot less backspacing, or run spacers in the rear. The aftermarket rims create problems in the front, because they won't stuff inside the flares and fenders in the front. I know the 8.8 seems to have developed a following but, personally, I think a late model, 29-spline XJ Mopar 8-1/4" axle is a much smarter swap for an MJ. It's the right width, the pinion yoke is already set up for a Jeep drive shaft, and it's nearly as strong as a Dana 44. All late model 4-cylinder XJs had 4.10 gears. Should be easy to find.
  15. Did you replace the combination/proportioning valve (the junction block beneath the master cylinder)? I don't know if the ABS-equipped model used that, but I assume they must have. And if they did, I don't know if they were the same as the non-ABS proportioning valves. The XJ proportioning valve has a spring-loaded plunger inside. It appears that plunger and the O-ring sweep/seal on the inner end of it get gummed up and don't allow much (if any) braking to the rear axle. You might try disassembling and cleaning that. It's accessed by removing the bolt-looking thing in the "nose" of the proportioning valve body. CAUTION: The spring is a strong spring. Be sure you remove the thing slowly and carefully. It'll drip brake fluid when open, so protect the painted surfaces beneath it. Many XJers simply remove the O-ring and spring, and push the plunger all the way into the "nut." This maximizes braking to the rear wheels, but disables the proportioning function. I'll be doing that on my '88 XJ very soon ... I currently have NO rear brakes. If that doesn't fix your problem, you probably need a new booster.
  16. Cut 'em off. Dremel will work, so will a hacksaw.
  17. I disagree. I've driven Pat's 87 on 4.10s with IIRC 31s, and for street driving it felt like too much gear. I think 3.73 would have been nicer. I'll see your disagree, and I disagree with your disagree. 3.73 gears with 31" tires is EXACTLY the same overall final drive ratio (expressed as RPMs per MPH) as stock tires and 3.54 gears. But the tires are much bigger and heavier. 3.73 is a good ratio for 30s. 4.10's is perhaps optimum for 31s and okay for 32s, anything bigger needs 4.56 or 4.88. Back to the original poster -- I would agree that 31x10.50s would be a better choice for you, and you can run them with no lift. (I'm currently running 31x10.50s on my '88 XJ, which has smaller rear wheel wells than the MJ.) However, if you MUST go to 33s, be very careful regarding width. Factory Jeep wheels have 5-1/4" backspacing. In the back, 31x10.50s end up very close to the inner fender and to the leaf springs. If you try to run tires any wider than 10.50, you will absolutely have to go to aftermarket rims that have less backspacing. "Cool," you might say. "No problem." Except that the vehicle has a front axle. In the front, 10.50 width tires on stock rims tuck up neatly inside the flares and sheet metal. Put the same tires on aftermarket rims with less backspacing, and suddenly when the suspension compresses the tires crash into the flares and sheet metal. Hilarity ensues. It's not really a good idea to go bigger on tires than what you actually need. As with lifts and pretty much everything Jeep-related, cost increases exponentially with size. The higher cost of big tires is only the beginning.
  18. It should not be difficult to find XJs. Why get involved in mixing and matching? Buy a transmission and transfer case together and you know they work together. XJs are all over the place. The u-pull I used to go to had rows of them.
  19. Being the resident PITA pedant, let me jump in and point out that there MAY be some lack of clarity regarding terminology here. To convert a 2WD tranny to 4WD, you would remove and replace the tailshaft. But ... note that I said tail shaft. Otherwise known as output shaft. We're not talking about just the long, tapered tailshaft housing, which is perhaps what you had in mind. The 2WD tranny has a long tailshaft and tailshaft housing, that ends in a spline that mates up with the front yoke of the driveshaft. The 4WD tranny has a comparatively short tailshaft that ends in a spline count that mates up with the input of the transfer case. The 4WD tranny, of course, does not have a tailshaft housing. So ... to convert the 2WD tranny, you have to remove and discard both the tailshaft housing and the tailshaft. You have to find a 4WD output shaft (of the correct length and spline count to mate with whatever transfer case you have) and install that, THEN you can think about bolting up the transfer case. By the time you buy the necessary parts, it's probably cheaper to buy a 4WD transmission.
  20. Yep. That's what the diagrams tell us. Of course, there's another variable we haven't even brought up yet. Everything we've discussed so far assumes that all the leaves are bent to concentric arches, so that load gets applied uniformly to all leaves as the load increases. One of the reasons leaf springs held on for as long as they did for rear suspensions is that it's FAR easier to make a progressive rate leaf spring than to make a progressive rate coil spring. All it takes is bending each successive leaf to a slightly larger radius, and the result is that each successive leaf doesn't start to accept load until the one above it has been partially loaded and deflected. The MJ bottom overload leaf is a crude example. In most trucks, most of the time, it just sits there and doesn't do anything. It only starts working when the upper three (or four) leaves have been loaded down to be flat enough that they contact the overload leaf. That's what I'm counting on (in reverse) with my idea to use cut-off XJ main leaves in an MJ pack to build my own "home brewed" metric ton springs. The free arch of the XJ main leaf is, in rough terms, about the same as the arch of an MJ spring sitting in a truck at curb weight. Therefore (if I'm correct), plugging the XJ leaf in won't give me any lift because it won't be trying to push UP on the other leaves. But -- it will start to carry load when the bed gets loaded up, thereby (I hope) increasing the spring rate and carrying capacity. Or I could be wrong. I think it might have happened once ... Don't have a clue. I've seen innumerable springs that have tapered ends on the leaves, and innumerable others that don't. Including springs for the same make and model vehicle that came from different subcontractors.
  21. Of course it is possible to convert a 2WD tranny to 4WD. In terms of both time and expense, however, you would be FAR ahead of the curve to just buy a 4WD tranny and transfer case together.
  22. That's exactly what I do, except that I don't use 1/4" screws. I think that's too big. The originals, IIRC, are 5mm. I used something just a little larger, like 6mm. But the heads on all the factory studs I have encountered were flat and uniform in size, so it was fairly easy to get my holes on-center. I drilled undersized, tapped, inserted the new screws, then just touched the heads with a wire welder to hold them. I use copious amounts of anti-seize when re-installing, hoping to avoid snapping off the repaired studs.
  23. Length of the leaves below the main leaf doesn't make any difference. A leaf spring is nothing but a simple beam, upside down, that's working within the elastic limit of the steel. If you look at the bending moment diagram for a simple beam, you'll see that it's a wedge, with zero moment at the ends and maximum moment at the center (or the point where the point load is applied, if off-center like on an MJ rear axle). Progressively shortening the leaves only results in not wasting steel where there isn't any need to have it there because it wouldn't be doing anything, anyway. You can use the formula to calculate the rate of a spring with different thickness leaves, but not easily. For a three-leaf spring, for example, you would have to run a separate calculation for each leaf (using the same eye-to-eye measurement as the length), then add up the resultant numbers to get the total rate of the spring. I tried to Google up a beam diagram for a simple beam with a point load, but everything I found is in .PDF format and has pages of diagrams, that would be more confusing than helpful to those who don't understand what all the different diagrams illustrate.
  24. :agree: Not only pictures. There are multiple angles you have to take into account with the front axle, and it usually results in a compromise. To reduce the likelihood of death wobble, you ideally want to keep the caster angle as close to stock specs as possible. But with 6 inches or more of lift, that results in an excessive u-joint angle at the pinion. So you have to start balancing out the pinion angle against the caster angle and hope you can find a happy medium that doesn't cause death wobble, yet doesn't eat the drive shaft u-joints alive.
  25. Aha. So the MJ plates are different from XJ plates? I couldn't remember. There are ways to refurbish old plates wityh broken studs. Please, do not EVER throw away any that you come across. If you find 'em in a u-pull yard, grab them. With flares, if possible, but if the flares are gone or useless, get the plates anyway. And no, the rear flares on the MJ are not the same as the rear flares on a 2-door XJ. I know someone will post that (again). It is not true. I have posted the photos to prove it.
