jodawill Posted August 3 Posted August 3 I need to replace the clips that hold the trim above the driver's side door. They're smaller than anything I have on hand. Does anyone know how to find these?
89 MJ Posted August 3 Posted August 3 I would take it into a place that sells supplies for body shops. They should have an AuVeCo catalog and will help you match it up to something.
fiatslug87 Posted August 3 Posted August 3 Someone said these worked for them: EBay Link Summit sells ones mad by Crown but are currently unavailable, they go in and out of stock. https://www.summitracing.com/parts/cwa-34201545
GonzoTheGreat Posted August 3 Posted August 3 Seems like the crown ones are out of stock everywhere. Ive been trying to buy some of these and after waiting a month from quadratech (which now shows "out of stock") the lady there told me crown is currently looking for a new supplier. @jodawill please let us know if you manage to get ahold of these. @fiatslug87 I'll give those ebay ones a try and report back. The picture looks all wrong, but we'll see
fiatslug87 Posted August 3 Posted August 3 I have some of the Crown ones and they are not as rigid as the original and bend easily. Hopefully their new supplier makes a better product.
jodawill Posted August 3 Author Posted August 3 2 minutes ago, GonzoTheGreat said: Seems like the crown ones are out of stock everywhere. Ive been trying to buy some of these and after waiting a month from quadratech (which now shows "out of stock") the lady there told me crown is currently looking for a new supplier. @jodawill please let us know if you manage to get ahold of these. @fiatslug87 I'll give those ebay ones a try and report back. The picture looks all wrong, but we'll see Let me know how it goes. It does look wrong in the pictures because the original is flat at the base of the stem as it slides on in only one orientation, but I see that those clips aren't as thick as they are wide, so I suppose it's possible that they will fit on there. These clips have probably been broken for decades (ever since my grandpa replaced the headliner, whenever that was), so I guess there's no rush, other than the fact it's really annoying me. Hopefully the white ones come back in stock eventually.
jodawill Posted August 3 Author Posted August 3 I went ahead and ordered the ones from eBay. It's a small enough money, I'm willing to take the risk if they don't work out. Hopefully they do. I spent a lot of time looking into those clips, and it doesn't seem like they're generally available, so I'll take whatever I can get.
eaglescout526 Posted August 3 Posted August 3 Chrysler has a modern part number for that clip. I remember posting it somewhere when someone was also looking for the same clip.
garyweb3 Posted August 3 Posted August 3 I bought the available ones that are larger and drilled out the holes that the clips insert into.
jodawill Posted August 10 Author Posted August 10 Well, don't bother with the eBay fasteners. They don't work.
ghetdjc320 Posted August 10 Posted August 10 I actually need some of these as well. Lmk if you find one that works.
JZLAJeep Posted August 10 Posted August 10 I just saw this post. These could be the same that Jeep used in the hatch of an XJ. The photo is one of the few that didn't break. @eaglescout526 and I had corresponded about this a couple years ago and here's what we found, and what I did. At that time we thought the original part number was 3420 with Chrysler/MOPAR equivalent of 6504995AA. Both are made of unobtanium at this point. If I did find them, they were prohibitively expensive. I ended up buying these and trimmed. https://shorturl.at/MeUpw The fastener part appeared to be close enough to the right size. The head/cap diameter was too big, but I put these in a drill and used sandpaper to grind them smaller. Then I used a small file to modify the 'neck' so that they were narrower in one axis. A pain in the rear, but $6 for 100 versus a lot more than that for one of the Mopar 6504995AA. With some modification I got them to work. I can't find any photos of the final product, sorry.
fiatslug87 Posted August 10 Posted August 10 47 minutes ago, jodawill said: Well, don't bother with the eBay fasteners. They don't work. What was the problem? Head doesn’t fit, too small, not small enough for the hole?
Strokermjcomanche Posted August 11 Posted August 11 don't know if they have more but here is where I got my clips .
fiatslug87 Posted August 11 Posted August 11 28 minutes ago, Strokermjcomanche said: don't know if they have more but here is where I got my clips . Those worked for you? The number is the same on the ebay item, 12993, that didn’t work for @jodawill
jodawill Posted August 11 Author Posted August 11 4 hours ago, fiatslug87 said: What was the problem? Head doesn’t fit, too small, not small enough for the hole? The head is the right size. They don't have the flat section at the top of the stem, but you can insert them by flattening it out because it's hollow. The stem won't stay in the hole because it's too soft and narrow.
jodawill Posted August 11 Author Posted August 11 48 minutes ago, fiatslug87 said: Those worked for you? The number is the same on the ebay item, 12993, that didn’t work for @jodawill I don't think those are the same because they don't appear to be hollow. The ones from eBay are almost as thin as paper and only molded on one side of the stem. You can flatten it out completely.
jodawill Posted August 11 Author Posted August 11 1 hour ago, Strokermjcomanche said: don't know if they have more but here is where I got my clips . Are those flat at the base of the stem, or did you have to modify the plate?
Strokermjcomanche Posted August 12 Posted August 12 21 hours ago, fiatslug87 said: Those worked for you? The number is the same on the ebay item, 12993, that didn’t work for @jodawill Mine looked nothing like the eBay ones. Besides being black, they looked exactly like the original clips. Already installed in the Jeep with no issue. However, I will not take it apart in fear of breaking the clips lol
Strokermjcomanche Posted August 12 Posted August 12 20 hours ago, jodawill said: Are those flat at the base of the stem, or did you have to modify the plate? Exactly as the originals were made. Flat spot and all. Nothing like the eBay ones listed earlier in the link on this thread.
jodawill Posted August 12 Author Posted August 12 31 minutes ago, Strokermjcomanche said: Exactly as the originals were made. Flat spot and all. Nothing like the eBay ones listed earlier in the link on this thread. Thanks! I just ordered some. Expensive after shipping, but I'll be happy if they work. The originals have been broken for many, many years.
