A list of links for info
Or just info that I have gather up.
I just sold the 88 and the guy asked me to but a list together of stuff that i have found or thought would help out. So I did and after an hour or so I think I got most of the links to work and all wrote out so I thougth I would share with you guys.
Some great places to hang out and gain info NAXJA, Pirate, Comanche club is just a few you will find that there is a lot great website out there. Just do some searching.
Best place to find junk yards and parts:
http://car-part.com/index.htm
This is a great junk yard out in Cal.
http://www.jwjeep.com/
Some great pic here of MJ and XJ’s
http://www.xjdb.com/
http://www.naxja.org/forum/showthread.php?t=54762
http://www.comancheclub.com/forums/viewtopic.php?t=15
http://www.comancheclub.com/forums/viewtopic.php?t=112
Some different right ups here
http://www.madxj.com/
http://www.madxj.com/MADXJ/technical/te ... dSeals.htm
http://madxj.com/MADXJ/technical/techni ... Panels.htm
http://jeep.off-road.com/jeep/article/a ... ?id=257801
http://gojeep.willyshotrod.com/HowtoAlignment.htm
http://www.fourwheeler.com/howto/34047/index.html
http://www.4x4wire.com/jeep/tech/axle/xj_dana44_02/
http://www.opiebennett.com/tech/frontbumper/index.php
http://www.metalwebnews.com/howto/tube- ... ender.html
http://jeephorizons.com/phpbb/viewtopic.php?t=5833&
http://jeep.off-road.com/jeep/article/a ... ?id=257864
http://projectxj.com/mods/doorless.htm
http://www.rockcrawler.com/techreports/index.asp
http://www.rockcrawler.com/techreports/ ... /index.asp
O most forgot to add the DIY section of Comanche Club:
http://www.comancheclub.com/forums/viewforum.php?f=9
Stroker info:
http://www.rockcrawler.com/techreports/ ... /page2.asp
http://www.speedomotive.com/ps-147-15-j ... k-kit.aspx
How To: Gauge Cluster Swap / Odometer Recalibration (Lots of Pics)
http://www.naxja.org/forum/showthread.php?t=921205
Some different people that carry parts and stuff
http://www.mountainoffroad.com/more.htm
http://www.crboffroad.com/frontbumpers.html
http://www.tntcustoms.com/webV5/default2.asp
http://www.quadratec.com/products/52435_01.htm
http://www.jcroffroad.com/Merchant2/mer ... y_Code=XJB
http://www.diy4x.com/main.htm
http://www.dpgoffroad.com/engine.htm
http://www.rigidco.com/FbW.htm
http://www.jbconversions.com/pages/index1.html
http://www.roughcountry.com/
http://www.quadratec.com/default.php
http://www.rocky-road.com/index2.html
http://www.pacesetterexhaust.com/jeep.htm
http://www.rockkrawler.com/
http://www.rustysoffroad.com/
http://polyperformance.com/shop/product ... 158&page=1
Seat Swap:
http://www.geocities.com/xjs4ever/seats_console.html
Half doors:
http://www.formattfab.com/
Locker:
http://www.offroadlockers.com/
Some parks
http://www.orvpark.com/
http://www.rorp.com/homepage.html
Axle chart:
http://coloradok5.com/axleguide.shtml
8.8 info
http://members.cox.net/quanno/ford88.html
http://www.jedi.com/obiwan/jeep/ford88.html
http://www.stu-offroad.com/axle/8.8axle/8.8axle-1.htm
http://www.jeepsunlimited.com/forums...d.php?t=674123
spicer# for the flanged yoke on the 8.8
2-2-1379
flange bolts for the 8.8 at the axle part# Ford P/N N800594-S100
spring preches that i used on the 8.8
http://www.performancedepot.com/product ... 01&dealer=
Tow strap saftey
http://www.youtube.com/watch?v=2JBnxSqpuCM
Measuring for new shocks?
I always try and set up suspension with about 25% up travel and 75% droop. Meaning all but 1" of the shock travel is being used up on full compression (bumpstops touching).
I don't have access to a fork truck so I do it like this...
When building the front suspension I hook up all the control arms and pull the coils out. Mount one of front tires. Jack up that side until the tire is within 1" of touching the fender (after final fender cutting). If the bumpstops aren't touching the distance that remains between them is how much bumpstop needs to be added. For instance if you jack it up and the tire is 1" from the fender and there is a 2" gap between the bumpstops I add 2" to the bumpstops so that they touch when the tire is 1" away from the fender.
Now the bumpstops are right and I move on to shocks.
With the new bumpstops in I fully compress that side of the suspension again (with or without the tire on)(doesn't matter because the bumpstops are right now!) Next I measure the distance between the shock mounts. I add 1" to this measurement. That gives me the compressed length of the shock. Next you fully droop that side of suspension and measure the distance between the shock mounts. This gives me the extended length of the shock. Now I know what size shocks to order.
When ordering shocks I usually look for one that has the compressed length that I am needing and whatever travel shock that ends up being is whatever it is.
This method of setting up front suspensions gives you most ideal setup. It sets your bumpstops so your tires don't hit. It gives you the most ideal shock for your suspension height that will give you the most droop possible and gives you a shock that isn't too long or too short.
I always hate to see nicely built long arm setups where people are running shocks that are way too short. It drastically reduced the amount of droop that they could be getting out of their front end. I have a buddy with a TJ who installed a Full Traction long arm and installed the shocks that they sent with the kit. The shocks were obviously from a smaller lift kit because they were way short for his 6" lift. This caused his front suspension to only droop a limited amount. He could not use the suspension to it's full potential until we measured for the correct shock. After buying the right length shock it flexes amazing!
Shew.... tired of typing now. :cheers:
I no there is more out there this just my list. Fell free to add your list and maybe this could become a sticky. :nuts:
x2 on the sticky. i was just thinking the other day there should be a sticky for each common tech thread since so much of it gets repeated. of course, we all like to talk shop so that's probably not a big deal but it would be a quick reference for a lot of things, but this works fine IMO.
Great job Rockhound, and thanks for putting in the time to do it!
this was compiled by the early cj-5 forum
Bantam Pilot Model - 1940
BRC-60 - Bantam model - 70 produced
BRC-40 - American Bantam Jeep for military
BRC-40/4WS - Bantam 4 wheel steering Jeep model
BRC-40 Checker - Checker's take on the Bantam design
Quad - Willys design prototype - 1940
Pygmy - Ford's design prototype - 1940
CPJ - Chevrolet entry proto for the Military design group
Mark II - Bantam production 1940-1941
MA - Willys production Jeep for the military 1,553 produced - 1941
GP - Ford's Jeep that the military ordered 1,500 of eventually 4,456 were produced - 1941
BRC-40 - Bantam's Jeep turned into the military 1,500 but in the end 2,605 were produced - 1941
MB(1) - Willys second generation Jeep design (the model produced in 1941 had a welded grill and 25,808 were produced)
MB(2) - Willys second design that incorporated the Ford designed stamped grill - 335,531 were built
GPW - Ford's Jeep built on Willys design specs, the breakdown of the designation is "G" Government, "P" Ford's designation for 80" wheelbase "W" Willys design 277,896 were built from 1941 - 1945
GPA - Ford's Amphibious Jeep 12,778 were built from 1942 - 1943 "A" fpr amphibious
M-38 - Willys gov design of the CJ-3A from 1950 - 1952 only 61,423 were ever produced
M-38a1 - Willys government design that would mostly resemble the CJ-5. 101,488 were produced from 1952 - 1957
M-170 - Long wheelbase Military Ambulance
M-151 - MUTT ("Military Unit Tactical Truck") built from 1959 - 1978
M-718 - Ambulance version of the M-151
M-422 - Mighty Mite. Aluminum Marine Corps Jeep, air cooled V4 lightweight
M-422A1 - Longer wheelbase version of the Mighty Mite
M-606 - The Jeep M606 was a military version of the Jeep CJ-3B, built 1962
M-606A1 (12v) and M606A2 (24v), M606A3 Designed after the CJ-5 both for US Armed Forces and Export from 1965 through 1982
M-676 - FC truck the M676 (or type I) was a two door pickup which differed very little from a stock FC-170
M-677 - FC truck The M677 (type II) was a four door crew cab pickup having the same 103" wheelbase and thus a shorter pickup box
M-679 - FC Marine Ambulance
M715 - Kaiser-built military pick-up truck, similar to the Gladiator J2000 - J4000 trucks
M-725 - military field ambulance
CJ-V35 - Military custom order. Cross between MB, M38, CJ-3A.
CJ-V35/U 1000 modified CJ-3As were produced for the U.S. Navy as the underwater vehicle
XM-170 - Experimental cousin of the CJ-4
CJ-2 (Agrijeep) - Willys first commercial bid for the gen public, mostly in farm use
CJ-2A - Willys second production Jeep for the gen public, 214,202 were built from 1945 - 1949
CJ-3A - Willy third design, this Jeep had 131,843 produced from 1949 - 1953
CJ-3B - Willys design this was much like the CJ-3A only the hood was much taller. To accommodate the F-head. 155,494 were produced from 1953 - 1968
CJ-4 - The missing link as some would call this one, it is an early design of what would become the CJ-5, only one is known to still exist
CJ-4 (Mahindra and Mahindra) - a long CJ-3B built in India
FC 150 - Jeep Forward Control Truck, based on the 81" wheelbase CJ-5 initially.
FC 170 - Longer wheelbase (103.5) Forward Control truck, used Super Hurricane I6
CJ-5 - Willys (Kaiser) made from 1955 - 1970, then AMC took it from there and built them till 1983 when among criticism about getting tough on high rollover risk AMC reluctantly decided to drop the short base model form its lineup. in the end over 600,000 of them were produced
CJ-6 - Willys (Kaiser) 1956 - 1970 and AMC 1970 - 1981, this one has a 101" wheelbase. From 1976-1981 they were export only. The only production number I have is 50,172 which sounds awful low to me for that many years
CJ-5A/CJ-6A - Kaiser Elevated the Tuxedo Park package to a separate model in 1964 ended ?
CJ-7 - Built by AMC starting in 1976, this Jeep had 93.4" wheelbase and had many offspring to its design
CJ-8 - this AMC design was known as the Scrambler, it has a 103" wheelbase and with the half top took on a truck type look. built from 1981 - 1985 27,792 were built
CJ-10 - 3/4 ton CJ Truck, export mainly to Australia
CJ-10A - Aircraft Military Tug in the United States
DJ-5A - Jeep built 2 wheel drive for mostly Postal delivery, they did also built a DJ-8 similar to the CJ-8
YJ - Wrangler, Started by AMC in 1986 and taken over by Chrysler in 1988, 632,231 were built up until 1995
TJ - 1997 - 2006, Jeep Wrangler
TJ-L - Long wheelbase TJ available for overseas military use
LJ - 2003 - 2006, Wrangler Unlimited
KJ - Jeep Liberty
XJ - Jeep Cherokee
VJ - 1949 through 1951 original 2WD Jeepster
ZJ - Jeep Grand Cherokee 1993 - 1998
MJ - Comanche - 1984-92 - compact pick-up
FC - Forward Control Jeep Van Trucks
FJ-3 and FJ-3A - Fleet Vans
FJ - Eagle Talon
WJ - Jeep Grand Cherokee 1999 - 2004
WK - Jeep Grand Cherokee 2005 -
SJ - Denotes the full size Grand Wagoneers and Trucks 1963 - 1993
XK - Jeep Commander
JK - Jeep Wrangler, 2007 - present
Great idea. Love having the resources and thanks for the work on putting them together. :cheers:
That is a cool list from CJ-5, but there is one thing on there that does not actually exist... "LJ" is not a real body code, but only something that has been created in the minds of Jeepers and simply means "Long Jeep". The 2003 - 2006 "Unlimited" Wrangler still falls under the TJ body code.
KJ - Jeep Liberty
XJ - Jeep Cherokee
FJ - Eagle Talon
XK - Jeep Commander
Don't forget the Jeepster Commando. C101 (1966 - 71) and C104 (72-73). I had a '67 hardtop with the Dauntless V6 in High School and love those suckers!
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
  • 1 month later...
  • 9 months later...
