Any help with any photos
22 hours ago, Aussiemj said:
Hi guys
This is a plead any photo of engine bay would be a big help in trying figure things out in the engine the rhd xj I have is totally different
Thanks
I have these photos of RHD XJs. Sorry these aren't great pictures,  I was really only interested in the alternator mount.
I do have a RHD alternator mount, if you need more pictures of that.
EDIT: Deleted pictures
1 hour ago, Aussiemj said:
i was hoping for 1990 4-liter photos I forgot there where so many different combos.
probably passenger side photos as the wiring is giving most problems.
Let me know what photos you need and I can take photos tomorrow.  I have a 90 4.0L.
Hopefully these help.  The two modifications you will note are the addition of factory cruise control and the plug for a Renix engine monitor on the large diagnostics port.
Overview:
Battery side
Electronics cover panel removed:
AC line lifted to see vacuum hose routing to accumulator ball in front bumper
Relay area:
Relay area:
Lots of common lugs come here, I forget what the block they are on is for.
Back side of said block:
Connectors near battery:
Connectors near battery view 2:
View looking under coolant bottle:
View showing cruise control actuator and the 4x4 vacuum lines:
General view of ignition coil:
Distributor:
thanks
looking at the photos i think i am also missing a lot of steel pipes in the coolant system
I assume you are talking about this photo.  That steel pipe connects to the bottom of the expansion tank, heater core and the rubber hose that runs up the left side of the upper radiator hose.  The cooling system you have should be more similar to an HO Comanche or XJ than a Renix one.  I don't think this steel pipe would be applicable in the HO setup.
