3rd Brake Light Location Question
fiatslug87
I like it better up top for sure.
How do you plan to wire it? If you just tie in to the tail light it’ll blink with the turn signal. I’ve seen a handful of canopies where that was done and it’s not ideal.
Thanks @GonzoTheGreat but this is on a trailer and pulled by a non-MJ, no access to brake switch wiring.
Anyone have another work around taking the above into account?
If worse comes to worse, it flashing with the turn signals isn’t the end of the world. Besides how often do people signal anyway?:shaking:
If the trailer had typical 7-pole RV wiring, you do have a generally unused auxiliary wire that would work for purpose. But if you were to ever plug into a vehicle set up with the potential for reverse lights in the aux spot (not uncommon) then it would come on in reverse… likely not the end of the world, but I’m not always thrilled about non-standard lighting patterns. Especially late at night, people tend to tunnel vision at a thing that’s blinking in a strange way in the dark, and often it won’t occur to them not to drive into it before they’ve figured out what’s going on. But response to a standard lighting pattern is usually more automatic when people don’t need to think about it.
  • 1 month later...
