The86manche Posted April 29, 2023 Share Posted April 29, 2023 Went down to a local electronics parts store and picked up a few capacitors for a buck a piece, 4 in total for 1 module and decided I'd try my hand at fixing a wiper module. They usually fail and I was curious to see what they look like without their case on. It looks like this. I had actually already done the repairs when I took these photos. The old resistors were green and white. When I had opened it I checked resistance to each one and found one to be open. And also one of the circumstances was broken. Hence the red wiring to repair the circut. Went out to my truck today, plugged it in and checked all intermittent settings.. IT WORKS! we got a working module again! I have several more I intend to repair and confirm function again and afterwards will be up for sale. I'd be happy to repair any if anyone has a pile they want fixed or to get rid of. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 30, 2023 Share Posted April 30, 2023 Nice. I’ve found a few cuircuit boards that failed due to cracked solder joints, and the fix is as simple as poking the crack with a soldering iron to reflow. It’s nice saving an original component and sometimes a few hundred dollars. Link to comment Share on other sites More sharing options...
The86manche Posted April 30, 2023 Author Share Posted April 30, 2023 41 minutes ago, gogmorgo said: Nice. I’ve found a few cuircuit boards that failed due to cracked solder joints, and the fix is as simple as poking the crack with a soldering iron to reflow. It’s nice saving an original component and sometimes a few hundred dollars. Never seen that on these but I've seen it on the grand cherokee vic modules and headlight switches. I'm more of a fix it before replacing it kind of guy. If I can fix it I'll give it a shot. I have kind of wanted to have a new modern circut board made and program wiper module commands to it but that's somewhat foreign territory. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted April 30, 2023 Share Posted April 30, 2023 4 hours ago, The86manche said: Went down to a local electronics parts store and picked up a few capacitors for a buck a piece, 4 in total for 1 module and decided I'd try my hand at fixing a wiper module. They usually fail and I was curious to see what they look like without their case on. It looks like this. I had actually already done the repairs when I took these photos. The old resistors were green and white. When I had opened it I checked resistance to each one and found one to be open. And also one of the circumstances was broken. Hence the red wiring to repair the circut. Went out to my truck today, plugged it in and checked all intermittent settings.. IT WORKS! we got a working module again! I have several more I intend to repair and confirm function again and afterwards will be up for sale. I'd be happy to repair any if anyone has a pile they want fixed or to get rid of. I have one I’d like to get tested and repaired. Let me know Link to comment Share on other sites More sharing options...
Whitaker717 Posted April 30, 2023 Share Posted April 30, 2023 15 hours ago, The86manche said: Went down to a local electronics parts store and picked up a few capacitors for a buck a piece, 4 in total for 1 module and decided I'd try my hand at fixing a wiper module. They usually fail and I was curious to see what they look like without their case on. It looks like this. I had actually already done the repairs when I took these photos. The old resistors were green and white. When I had opened it I checked resistance to each one and found one to be open. And also one of the circumstances was broken. Hence the red wiring to repair the circut. Went out to my truck today, plugged it in and checked all intermittent settings.. IT WORKS! we got a working module again! I have several more I intend to repair and confirm function again and afterwards will be up for sale. I'd be happy to repair any if anyone has a pile they want fixed or to get rid of. I would be interested in a working one if these. I just added CC and now have an intermittent wiper stalk with no intermittent wiper. Would be interested in buying a working one. Good work Link to comment Share on other sites More sharing options...
cruiser54 Posted April 30, 2023 Share Posted April 30, 2023 I have a ton of used ones. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 30, 2023 Share Posted April 30, 2023 17 hours ago, The86manche said: Never seen that on these but I've seen it on the grand cherokee vic modules and headlight switches. I'm more of a fix it before replacing it kind of guy. If I can fix it I'll give it a shot. I have kind of wanted to have a new modern circut board made and program wiper module commands to it but that's somewhat foreign territory. I’ve mostly done it on clusters, yeah, and typically only on ‘90’s era stuff. Something about larger components hung off a vertical board, don’t seem to like bouncing around. Could likely make a modern wiper module happen easily enough with arduino or raspberry pi, or whatever is being used today. It’s what we used back in the day for our cluster and shift control on our FSAE cars, although that was ten years ago. But it’s not exactly a cost effective production solution. Link to comment Share on other sites More sharing options...
olddude Posted April 30, 2023 Share Posted April 30, 2023 5 hours ago, cruiser54 said: I have a ton of used ones. I need a working module. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 30, 2023 Share Posted April 30, 2023 I'd have to test them on my Comanche Link to comment Share on other sites More sharing options...
olddude Posted May 1, 2023 Share Posted May 1, 2023 2 hours ago, cruiser54 said: I'd have to test them on my Comanche Just let me know. Mine works but not intermittent, just one speed. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 1, 2023 Share Posted May 1, 2023 Makes me wish I was good with electronics to do my own work on this stuff like the early style tachs and cruise control modules. Link to comment Share on other sites More sharing options...
The86manche Posted May 1, 2023 Author Share Posted May 1, 2023 Wow this generated quite a bit of interest! Well let me go over the other ones that I have and see what I can do. I've got the other two taken apart and they seem slightly different than the one i fixed previously. Maybe an 86 and earlier model. And these are 87 and up? regardless. Only one capacitor has changed and i only need to check values on them to see what and if anything has failed. Link to comment Share on other sites More sharing options...
The86manche Posted May 1, 2023 Author Share Posted May 1, 2023 10 hours ago, cruiser54 said: I have a ton of used ones. I may be interested in some if you are willing to unload some of your collection. Link to comment Share on other sites More sharing options...
The86manche Posted May 1, 2023 Author Share Posted May 1, 2023 Now.. where in the world did I put my volt meter.. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 4, 2023 Share Posted May 4, 2023 I have 3 good ones and 3 bad ones. $35 each shipped in US for good ones. The86manche: Just pay shipping on the 3 bad ones. Link to comment Share on other sites More sharing options...
JYau Posted May 4, 2023 Share Posted May 4, 2023 I'm also interested as I have been looking for a good one. Pretty much every time I ask about one, the owner doesn't know if it works or not. I tried repairing mine as well but it was so badly corroded the mechanical relay was seized and I wasn't able to fix it. Link to comment Share on other sites More sharing options...
The86manche Posted May 4, 2023 Author Share Posted May 4, 2023 14 hours ago, cruiser54 said: I have 3 good ones and 3 bad ones. $35 each shipped in US for good ones. The86manche: Just pay shipping on the 3 bad ones. I can do that! Haha Link to comment Share on other sites More sharing options...
The86manche Posted May 4, 2023 Author Share Posted May 4, 2023 I for the life of me cannot find my meter so I have to go out and get another one today. That's been my holdup right now. I did also find another one in my stash for testing as well. Just for a short update. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 4, 2023 Share Posted May 4, 2023 If anyone wants one of the three good ones, email me at cruiser54private@gmail.com 86, do the same for the 3 bad ones. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 4, 2023 Share Posted May 4, 2023 the86manche's are boxed up and ready to go. Shipping paid. The other 3 are boxed up waiting for PayPal of $35 to slowcreek54@gmail.com. Please include your name and address. Link to comment Share on other sites More sharing options...
The86manche Posted May 5, 2023 Author Share Posted May 5, 2023 Would you still like me to email you? Link to comment Share on other sites More sharing options...
cruiser54 Posted May 5, 2023 Share Posted May 5, 2023 Nope. all boxed up and ready to go. Link to comment Share on other sites More sharing options...
Manche757 Posted May 5, 2023 Share Posted May 5, 2023 On 4/29/2023 at 4:16 PM, The86manche said: Went down to a local electronics parts store and ... I am impressed that you put your knowhow and focus to extending the life of failing MJ parts as those are bound to fail as time passes. Kudos to you. The future of MJs depends on youthful forward thinkers like you. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 5, 2023 Share Posted May 5, 2023 YES!!^^^ I have one left. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 6, 2023 Share Posted May 6, 2023 I thought someone else wanted a good one. Once the last one is sold, I'll take them all to the Post Office to ship. Mark 39? Link to comment Share on other sites More sharing options...
