Pete M Posted January 8, 2023 Share Posted January 8, 2023 is there an official fix for this leak? replacement part? it doesn't stay put and is most definitely leaking. Link to comment Share on other sites More sharing options...
Warren99 Posted January 8, 2023 Share Posted January 8, 2023 And this is directly under where the cowl drains it's water, genius design. I just got a slightly better one from my parts MJ but I'm still gonna slather it up with rtv. Link to comment Share on other sites More sharing options...
Gojira94 Posted January 10, 2023 Share Posted January 10, 2023 You can get assortments of rubber grommets, vinyl caps, etc. at some parts stores but they're usually limited stock or special order. In my area, it's NAPA, O'Reilly, Advance and AutoZone. I've seen 170-180 piece grommet and cap kits on Amazon for $12-$20. When I'm finishing up my project I'm going to need a few various/ sundry of these and will probably order one of each, caps and grommets. For your antenna wire pass-through I'd get a solid rubber grommet, punch the wire through it, get it properly situated and then smear a little RTV around the wire on both sides. That ought to last for 10+ years. Link to comment Share on other sites More sharing options...
rokinn Posted January 11, 2023 Share Posted January 11, 2023 Home Depot has grommets as well. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted January 11, 2023 Share Posted January 11, 2023 A new rubber grommet is good but I’d also add some black rtv sealant. I used some 3m 5200 sealant on mine. Also, be sure to add a “drip loop” to the antenna wire before it enters the grommet. Never had a leak after that from the antenna Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 12, 2023 Share Posted January 12, 2023 I have this exact same problem. My original antenna was bastardized by the PO. I replaced it with one from another 88 cherokee and the sheet steel punch out hole was a larger diameter than the rubber plug on the antenna cable. The rubber plug on my antenna cable did not slide along the cable either. I was not using excessive force, but I could not get it to move. My solution is grab a new rubber grommet from mcmaster and either shove the entire antenna cable and old rubber plug through the new grommet or slice off the old rubber plug from the cable, buy a new plug, make a slit, attach the plug to the cable and add a little bit of silicone to the slit. Either method should work. I just have to take some measurements first. Something like this: https://www.mcmaster.com/7291N45/ Or this https://www.mcmaster.com/grommets/grommets-6/ Or this: https://www.mcmaster.com/7291N19/ I'm leaning toward the last link and just making a slit. Link to comment Share on other sites More sharing options...
oleskool Posted January 14, 2023 Share Posted January 14, 2023 I used one of these off amazon. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2023 Author Share Posted January 14, 2023 10 minutes ago, oleskool said: I used one of these off amazon. link? Link to comment Share on other sites More sharing options...
oleskool Posted January 15, 2023 Share Posted January 15, 2023 2 hours ago, Pete M said: link? (3 Pack) Universal Firewall Boot - Safe and Convenient Firewall Grommet Kit Can Accommodate 3/8 Inch to 1 Inch Wire Bundles https://a.co/d/bDm8neQ Link to comment Share on other sites More sharing options...
Aidenmoreno3 Posted January 4, 2024 Share Posted January 4, 2024 Does anyone know the size of that hole?? I'm guessing its between 1" and 1.5". gonna get a cheapo micrometer tomorrow and measure Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted January 4, 2024 Share Posted January 4, 2024 24 minutes ago, Aidenmoreno3 said: Does anyone know the size of that hole?? I'm guessing its between 1" and 1.5". gonna get a cheapo micrometer tomorrow and measure The hole size varies depending on year. I have 2 different plug diameter OEM antenna cables. Its kinda bonkers. Only one of them was correct. Link to comment Share on other sites More sharing options...
Aidenmoreno3 Posted January 4, 2024 Share Posted January 4, 2024 Just in case this helps anyone else in my position down the line, 1992 base model: according to the caliper it’s a size 1.25”. these are the two I’m gonna try. I’m gonna cut out or punch out a hole in the middle to see if I can feed the antenna wire through. Hopefully no leaks this time 🤞🏽 (1.25” is roughly 32mm) Link to comment Share on other sites More sharing options...
Aidenmoreno3 Posted January 5, 2024 Share Posted January 5, 2024 Aight last one. It worked! Both grommets came in this morning (amazing delivery time lol) I decided to use the 2nd grommet listed in my last post. Punched a small hole in it, fed the wire and it fit like a glove. Here’s how it looked from the inside. Hope this helps some more people with similar issues: Link to comment Share on other sites More sharing options...
