Everything posted by Warren99
Yea I do plan to upgrade the fronts at some point as well. Right now I'm just sorta in a rush to get 4.10s in for an upcoming offroading trip my brother and dad are trying to organize. I'm leaning more towards just getting the quadratec kit for the rear, but to be honest I may just hold off on touching the brakes right now and just do gears and the locker.
Alright I've decided to just convert my dana44 to discs, and get an e locker and some 4.10 gears. For the HP dana 30 in the front, do I need reverse cut gears? I know I need a bigger carrier to go from 3.55s to 4.10s. Also, so far this is the only complete disc conversion kit I've found for a dana 44. https://www.quadratec.com/products/12700_414_07.htm?gad_source=1&gad_campaignid=19480551502&gbraid=0AAAAAD_wpjgLBBsqXjg6KO5t0CeUypgYR&gclid=CjwKCAjwnvTUBhBoEiwAZNDxZyCJqWfRhU90aVGzj7Layxg4_wGGejMCb1h-SP6oQKA02fwnlzizlBoCeUoQAvD_BwE Does anyone recommend a different one? Or know of any cheaper ways before I pull the trigger on these?
I think I'll go with that then, or any worm gear style lsd.
Thats air operated right? If so no thank you, I'd rather install an electric one or a cable.
I mean for street stuff I just wanna be able to do the occasional burnout, and get both tires to lock up if I try to slide it lol. For trail stuff I'm just doing light offroading for now to not mess up my rockers or fenders. Maybe its worth trying the truetrac out, it's like half as much as an e locker anyway
I mean I guess I could just buy a disc conversion kit and a new carrier with a locker. Might be a lil more expensive but seems like it would be worth it in the long run based off what you said
I mean the main thing is I wanna get a locker, and disc brakes. It just seems like its easier to swap in a 8.8 than convert my dana 44 to discs, and the 8.8 is a little stronger as far as I'm aware
32 tires and I'm gonna want 4.10s. Right now it has a dana 44 with like 3.55s. And I think it's more like 350 hp, no real way of nowing until I dyno it. But the dana 44 with a spool has held up to some decent street abuse so far. I'm only really gonna be doing mild offroading with it. I think the 8.8 should be fine. In the far future when the body gets more beat up I may get some one tons and cut up the fenders.
I was kinda thinking an 8.8 from a 95-01 explorer
I wanna swap in a better rear end with a locker to handle my ~400hp om606. All I really care about is I want the same width as my dana44, disc brakes, the same bolt pattern, and something easy enough to find in a junkyard or off marketplace. Maybe an 8.8 or a 9 inch? Any recommendations?
Hm ok, I'm probably just dumb and was doing it wrong lol
Nvm found it, but still wondering why my old activity threads seem to be missing
I haven't been on here in a minute, but I'm looking for a thread I started and or a write-up someone made for how to replace the rear window. When I look in activity and "content I started" or "content I follow" there doesn't seem to be anything passed like august of 2025. But anyways I'm searching for this because my rear window is pushing out from all the times I used the palm of my hand to open the glass, since I was lazy and didn't add my own latch. If I can find the thread about how to install the rear window again, I'll fix it and add a generic latch. I just can't remember all the small details about replacing it, and what type of rubber sealant to use, etc, but I know it's all in that thread.
Mercedes OM606 TD Swap
Warren99 replied to Warren99's topic in MJ Hardcore Tech: Epic Journeys to Greatness
2 inch, but the intercooler itself has 2 1/4 inch. I went with 2 inch pipes because thats the diameter of the turbo outlet, and it was a tight fit, had to trim a good bit of fiberglass -
I still haven't cut any of the old harness out, as I don't wanna end up finding out something I cut out was being used as a ground for something I'm still using or something dumb like that lol. But for now it's just tucked out of the way. I made the gauge mount from a license plate and a hose clamp. Eventually I wanna mount the egt gauge where the clock bezel is, and replace the stock voltmeter with a boost gauge that looks like the one that came in the 86 models with the 2.1 renault engine. So if anyone needs a working clock bezel and has a base model blank one then I'll trade eventually. Relocated the battery to under the bed. Figured worst case scenario if it falls off, I can still drive home as long as I don't turn it off, I'll just lose my gauges. -
Custom AC and Electric AC Compressors
Warren99 replied to Warren99's topic in MJ Tech: Modification and Repairs
OM606, 3.0 Mercedes turbo diesel. My battery is under my bed on the side of the frame rail now, so mounting the compressor back there would be better for the power draw. I'm wondering how much better the plate and fin design would help, I put a brand new evap core in like 2,000 miles ago before I pulled the 4.0 out and I'm really not feeling like pulling the dash and hvac box out again. -
I engine swapped my MJ and theres no room for a belt driven ac compressor so I'm gonna try out one of those electric ones I've seen. Should be able to just upgrade my alternator, and then make custom lines/hoses to the stock jeep A/C components. I was curious if anyone had any advice like would longer A/C lines affect the effectiveness much? Because I relocated my battery to under my bed and theres not much room in the engine bay so ideally I'd like to mount the electric compressor somewhere under the bed as well. Also wondering if anyone has any advice for making the system more efficient, like instead of just using new components for a renix era A/C system, maybe I would be better off using components from a high output system, or an entirely different car altogether. I guess I mean like could I make it better by using a "better" receiver/drier or expansion valve, or maybe none of that really matters and it mostly boils down to the compressor, amount of freon, length of hoses, amount of air moving over condenser, etc. I don't really know much about A/C systems. But I should be able to just mix n match whatever with an electric compressor and the jeep evap core since I figured I can just get one of those hose crimping kits and make my own lines. here's an example of the type of compressor I mean https://www.amazon.com/ACTECMAX-Universal-Electric-Compressor-Conditioner/dp/B0CQYJ6PSS/ref=sr_1_7?crid=3FB9RLT0N8FJ4&dib=eyJ2IjoiMSJ9._Y5ZuKNTltL35YqClfWHJfAUhzlpFpDyoKAtDPXKVFu6P-FrPvC2-wlP8KlLpuQmW3ii3EfOfYath3EAbDFAraD6osrLLkKHjA9mXquAPuwEpD70P2JcJEr0wcJYI_SSVn9HWOSFh5EnN3nfPx-ziJOliwc8bLk2gY6oEfWdL1s8NlavJkTAouwYrHoD3y8zEM0nSNHAzTetLnNbFaBkxfvYG2CwHtUkWOldGLWNw64.9Kk4Uq08G6VQsE-lSJJYPx09RvNR2eaogfpjyboIBiI&dib_tag=se&keywords=12v%2Bac%2Bcompressor&qid=1773283844&sprefix=%2Caps%2C575&sr=8-7&th=1
I've been really bad about updating sorry, and progress came to a halt for a few months but its almost ready for the first test drive under full power. Just need to mount an oil cooler, and install the EGT and boost gauge. I'll make a detailed update on here soon and post videos on youtube or something so I can link it here. -
Not sure if this belongs here or in modifications and repairs but I have a red front fiberglass piece that I wanna paint white to match the rest of the truck. Its an 89 base model and I'm assuming I can find the paint code on the firewall or fenders or using the vin. I was wondering if anyone had any suggestions for where to find some. The rest of the trucks paint is pretty bad if ur not more than 10 feet away, so I'm not looking to do a professional paint job on this one little piece, I'd just like to make it the same or a very similar shade of white as the hood and fenders so it doesn't stick out. Thanks!
How to wire up a different alternator
I labeled the B+ and D+, that other wire is for a resistor or capacitor or whatever that thing is on the back and it’s supposed to be connected to that spade that’s why i drew the line. the main battery connection on the alternator and the plug in my hand the yellow wire comes from that plug to here where it goes thru some kind of splice or fusable link ig then into the harness for all the other stuff. the tan wire comes from that plug and into this plug then to the instrument cluster according to the wiring diagram -
I have an 89 MJ with a mercedes om606 engine in it. I'm currently trying to figure out how to wire it up. I figured it would be pretty self explanitory but the mercedes alternator has two posts, a "B+ and D+" while the jeep one had a battery terminal and a connector for a tan wire and a yellow wire. After looking at wire diagrams I see these two wires hook up to a regulator in the jeep alternator. From what I could figure out with some research, european alternators use B+ for the battery, and D+ is for the exciter wire and all other functions or something. So do I just directly connect the yellow and tan wires from the jeep to this D+ terminal? Or maybe theres something else I have to do like connect the yellow one to the D+ terminal and the tan one to a 12v in the run position wire. Kinda hoping someone will know exactly what the jeep alternator does to the yellow and tan wire. I'll send some various pics in a moment
Will a 5V Sine wave work on an MJ Tach?
Still trying to wrap my head around a few things, does the ICM modify the signal that it gets from the crank position sensor? Because if not maybe I could just ignore the coil and wire straight from the crank position sensor to the tach. Also still wondering if I can just wire it up and see what it does without risk of it causing damage to the tach. I'd assume it wouldn't cause any damaged and would just give bad readings but I don't know how the tach works in detail. -
Warren99 posted a topic in MJ Tech: Modification and Repairs
So my gauge cluster's tach is for a 4.0, and I mated a mercedes diesel to my ax15. It has a crank position sensor built into the block similar to the jeep one that goes on the bell housing which I can no longer use with the adapter plate I have on. I'm wondering if I can just simply hook up the jeep wire to the mercedes crank position sensor. According to some people the mercedes cps works off of a 5v sine wave. Is that also what the jeep uses? If not how can I convert it? Also I could very easily just hook it up and see if it seems to work. Not sure if that can somehow risk damaging the tach, but if it's risk free I'll just try it. Thanks -
Different radiator needed for engine swap
https://www.rockauto.com/en/moreinfo.php?pk=4012827&cc=1181461&pt=2172&jsn=646 Thanks, this one for the 2.1 diesel looks perfect
