Warren99
Everything posted by Warren99
  1. I couldn’t find a number on either backing plate, but I found numbers on the tube on either side of the diff, as well as some on the diff.
  2. It’s smooth lol, guess it’s Dana 35 Hardware then?
  3. No idea :/, if needed I could ask the person I bought it from, can't guarantee they know tho, pretty sure it was being used on a trail rig
  4. Putting a rear dana 44 from an XJ into my MJ. The pads are basically gone and the drums aint in the best shape either so I wanna just fully redo them all. Any good reccomendations? https://www.quadratec.com/p/crown-automotive/rear-drum-brake-service-kit-cherokee-xj-comanche-mj-52001915K So far this is the first one I've found that actually specifys dana 44, but it says with 10" x 2.5" drums. The inside diamter of my drums are 9, the pads are 2.5 wide tho. I couldn't find anything stamped into the outside of the drum. Is it likely the right one or did they differ? Thanks
  5. Don't count on it starting anytime soon, I'm 19 and between jobs rn so it'll be a bit before I have enough money for my parts lol
  6. Don't know how I never saw this, this is sick! I'll be om606 swapping mine once I have the funds saved up.
  7. Hate to see something like this. Cruiser's tips helped me fix so many things on my truck.
  8. Well good thing I don’t ever plan on running anything bigger than 32s since that’s the biggest I can fit and still realistically get flex without cutting much of the fenders with my current lift. With that being said I’ll probably just run with the 30 until it breaks if it ever even does. Also update, they are actually 3.73 gears and luckily it’s a spool, not welded. I’m actually happier with 3.73 as I’ll still drive it on the road a lot, and right now with 3.55s or whatever it is I have my Speedo is like 3mph slower than my actual speed at highway speeds, so it may even out perfectly
  9. 6.5 hours one way unfortunately, but yea I still think it would be worth it. I'd run a spool/welded one for a while and eventually get some type of locker.
  10. Ah ok cool, its a 6.5 hour drive that would be the main draw back. He says he thinks its welded or has a spool, hes taking the cover off today to check.
  11. Alright thank you. What would you guys say would be a fair price for a XJ/MJ Dana 44? I just found one being sold with 4.11 gears and a Dana 30 for $400
  12. Thinking forward, I think I'll try to look for a dana 44 front and rear. I don't care too much about rear disc brakes, so if I see a rear d44 on another XJ or MJ I'll get that, as for the front one I'm not too sure. I guess I could also look for a set from a rubicon TJ. Are those the same widths as the XJs/MJs? I'm aware the rear would be a 4 link but I have no problems cutting those off and welding on leaf perches. Also, would the 4 link brackets on a rubicon TJ's front D44 match up perfectly to my long arms(running a stock dana 30 right now), or would I have to somehow relocate them?
  13. Returned the c clip axle to the junkyard, and found a bunch of other c clips, seems like a non c clip dana 35 is like 87-89 or something. Regardless, took the destroyed side and spider gears plus some 1/4 inch steel plates and welded the diff, so far it's held up.
  14. My 2wd 89 MJ with a 4.0 and the ba/10 5 speed came with 3.07s
  15. Ah ok thank you
  16. I thought low pinions were less desirable? Not sure if it has to do with strength or ground clearance but I had the impression that high pinion was always better
  17. Ah ok, I mean if I find one I may swap it just for the peace of mind, and also I wouldn't wanna put much money into a dana 30 for a locker and CAD delete kit.
  18. Thank you all but I should have clarified, I do plan to upgrade both axles in the future at the same time when I swap my mercedes' om606 TD. I'm aiming for around 300hp and not planning on doing any super crazy rock crawling or anything so I figured dana44 front and rear should work good, just not yet sure the best kinds to get. I daily my 98 e300 td, but I'm still basically just trying to get my truck back and moving as cheap and easy as possible, thats why I went and got the first dana35 I saw from a junkyard. I know the proper way to do things would be to just start with a fresh diff but, as I said, I just wanna throw this together as cheap as possible, and it only has to last for a little while until I have the money to build and swap my engine and get better axles. With that being said, I had my diffs apart today and discovered that my trucks diff(keep in mind my trucks axles aren't original, they came from some XJ some years ago) is a non-c-clip type, but the donor axle was a c-clip axle. Also, my spyder gears where what blew up, but the ring and pinion are unphased so we tried just taking the gears from the donor axle and putting those in the original carrier but they are ever so slightly different and won't fit. What I think I may do is see if I can find just the spider gears for sale somewhere, or just go back to the junkyard and search for some from there.
  19. Happened a few weeks ago but I blew my rear diff doing dumb things lmao. I went and got a whole axle from a 94 xj and will swap the guts sometime soon. I've never worked on a diff before but I should have some help. Regardless if theres anything useful to know about these specfically please let me know. Thanks!
  20. Actually I think I know the issue now lol. But yea I was getting annoyed and thought maybe someone on here could happen to know. But when I have the time and money, I'll be swapping a mechanical injection pump on, and building it for 300 hp. Then unless someone knows of a good manual trans and transfercase I could fit into my MJ, which will bolt up to an OM606 or has an existing adapter plate kit, then I'll get an adapter kit for my AX15 and see how well it holds up to it lol
  21. As a disclaimer I won’t actually be building and swapping the engine for a few years, I’ll be daily driving the car in the meantime however. I just wasnt gonna start the thread until I actually started building the engine, but after driving 9 hours home with no issues, the next day it started dying when hot and not starting until it was cooled down. I’ve already changed a few things but It has me puzzled. Does anyone happen to have any knowledge on these? If so I’ll give way more details as to what’s happening and what all I’ve done so far.
  22. So my lines are cracked and leaking now. My truck is an 89, but I swapped a pump from a 96 cherokee a long time ago. When I did, I used one of the lines from the Cherokee, and one line from my truck. My question is can I just order 2 new lines for a 96 cherokee and they both fit, or is the layout or steering box somehow different on a 89?
  23. Pm sent
  24. I can always go back. Not for a bit though. I don't remember for certain if the mirror's plastic piece was still in 1 piece or not. And are you talking about the A pillar trim? And the trim piece behind the seat was there, as well as the carpet panel if you want that too.
