1990 Comanche Eliminator
  • Replies 172
32 minutes ago, Ωhm said:
The Cruise/Trans SW electrically is used by the Transmission Control Unit (TCU) for the purpose of disengaging the Torque Converter, when brake pedal is depressed.
Ah, so I didn't need to fight for 10 minutes getting it plugged in as I have a manual.  That explains why the valve that I got that came out of a manual truck didn't have the plug.
8 minutes ago, eaglescout526 said:
Yeah I have seen that switch used for the transfer case and cruise control
So you are saying it might disengage cruise if for instance the t case is not in high range?  I'll have to test that.
Good news today, the roads were dry enough to drive the truck and test the cruise control, it works!  It does need to be tuned as the variation and aggressiveness is hilarious.
In bad news today, my clutch stopped working.  Pedal goes to the floor yet the master cylinder is full.  I suspect it might have a collapsed soft line that isn't allowing fluid to move to the slave cylinder.
  • 3 weeks later...
I found the clutch master cylinder was in very bad shape.  It looks to be original at 258k miles.  The piston was stuck at the bottom of it's travel.
I replaced it with a Sachs master cylinder.  I didn't have much success bleeding it with the two person method.  So I then tried gravity bleeding and that worked brilliantly!  Clutch feels amazing, better than it has since I purchased the truck!
Upgraded reverse lights with these light bulbs based on someone's recommendation on the forum.  https://www.amazon.com/AUXITO-Lumens-Replacement-Backup-Reverse/dp/B07W7HQPZF?pd_rd_w=6gfht&content-id=amzn1.sym.55bebd03-1feb-4883-a1f4-21b3be773289&pf_rd_p=55bebd03-1feb-4883-a1f4-21b3be773289&pf_rd_r=9E39KKAW1QJP61GG399Y&pd_rd_wg=2heao&pd_rd_r=bc776f05-5ffb-48a9-9a7e-884b8e70f0e3&pd_rd_i=B07W7HQPZF&psc=1&ref_=pd_bap_m_grid_rp_0_1_i
They are awesome.  Final install.20230221_191408.JPG.e17b2b301c8164e8d8355432db0c5085.JPG
New on left old on right.
Lighting up what's behind.  You would barely see that garage with the original lights.
  • 1 month later...
  • 3 weeks later...
Had the factory Eliminator wheels refinished professionally and five new KO2 BFGs put on!  235 75 R15
They ride smoother and quieter than the cheap Chinese light truck tires that were on it.
20230503_195108.JPG.1756d683feb324ec62b4745ad0121965.JPG20230503_195141.JPG.cf3f8a51f54c3e9c6726d3a18fd7be57.JPG20230503_195134.JPG.cab427434f0815c3759fd441a269f53c.JPG20230503_191436.JPG.b0c3ce530337daa6a0b81e783c11f761.JPG
5 hours ago, Airsuperiority said:
Beautiful machine! I wish my paint looked like that!
It's not all that great.  Previous owner had repainted by an amateur.  They did an alright job but it has a lot of orange peel and scratches super easily.
we call that a 20 footer. :D  looks great from 20ft away.  all my Jeeps are like that.  :L:
Yup!  Most of my cars are 20 footers.
During lockdown my twin brother and I spent our days fixing all the paint issues on our old BMW M3.  Fixed rust, got color matched paint, the whole deal.  Two winters later you wouldn't know that it was ever nice.  It's far easier owning a fleet of 20 footers.  At least the Comanche is getting spared the winter weather.
  • 3 weeks later...
On 10/25/2022 at 7:58 PM, pizzaman09 said:
Installed the REM II Clock panel this evening!  I was initially a bit disappointed in the quality of the 3D printed housing has it had some voids on the front.  It turns out the voids are hidden behind the dash so it doesn't matter!
I quite like that you can adjust the display to a custom color, I've tried to match the color of my JVC head unit.20221025_194821.JPG.8dca74b997df95ca446a7f756032a775.JPG
I was going to ask if you were able to change the display color! I think I am going to do the LED lights, so thanks for the link to that.
You can, though I've twice had issue with the blue LEDs not working.  Nick fixed it for me, though last week they went out again and I haven't gotten around to asking what I can do to fix it if I care.  The stock green is actually easier on the eyes at night compared to the color I had mine set.  I just had it set to match my radio head unit.
  • 3 weeks later...
Added some 3d printed center caps thanks to @Dzimm putting in the effort to reverse engineer and 3d print them.  20230620_210719.JPG.52b386a93827f91fb883c03e1bd91333.JPG20230620_210727.JPG.2a31d11edd88f418a45bddcd7b64a138.JPG
Additionaly I've finally found a Renix coolant bottle combo that doesn't leak, the Dorman 603-300 bottle from Amazon with the stock original cap from the factory bottle.
Finished the Advanced Adaptors external slave conversion today!  I'm so excited to finally have a reliable clutch hydraulic system, every part of it is new at this point.
Getting the transmission aligned with the pilot bearing was miserable, 4 hours of fiddling around.  We had the truck on a two post lift but only had a 2ft high transmission jack.  A combo of the transmission jack and jacking the back of the engine up and down with a floor jack under the oil pan finally did it.  It popped in and all was easy from there.  Only other challenge was you are apparently not supposed to cut the plastic tabs on the clutch slave cylinder before install, ended up shooting the piston out of the front of the cheap plastic slave provided in the Advance Adapters kit.  Replaced it with a nice metal one that was in stock at O'Reilly's.
Also because I had access to do so, I did the CPS advance mod.  Definitely the original Siemens French made CPS.20230624_171518.JPG.89abaccddc86d9c28077192fd565177d.JPG
