Misfit_MJ Posted February 1, 2021 Share Posted February 1, 2021 1991 2WD MJ Jeep with 4.0HO & 5speed  Goal - Street friendly 4WD truck, with a killer audio system.  Plans - 4WD conversion with HP D30 & 8.25 axles - Transmission 4wd AX15, T case,not sure yet  Phase one - Locate 8.25 axle / Build 8.25 axle with 4.56 gears and locker (lunchbox or ARB)    Link to comment Share on other sites More sharing options...
Jesse J Posted February 1, 2021 Share Posted February 1, 2021 @Pete Mcan you move it to the right section. Also welcome to cc. make sure to put it in the registry Link to comment Share on other sites More sharing options...
89 MJ Posted February 1, 2021 Share Posted February 1, 2021 Â She looks like a great truck to build! What are your plans for it? Link to comment Share on other sites More sharing options...
Jesse J Posted February 1, 2021 Share Posted February 1, 2021 she is a beautiful truck. Link to comment Share on other sites More sharing options...
Misfit_MJ Posted February 1, 2021 Author Share Posted February 1, 2021 Thanks for moving to the correct place! Link to comment Share on other sites More sharing options...
Pete M Posted February 8, 2021 Share Posted February 8, 2021 no problemo. Â Â by the way, you want a 242. Â Link to comment Share on other sites More sharing options...
Misfit_MJ Posted February 10, 2021 Author Share Posted February 10, 2021 Change of plans on the build for Axles, found a killer deal on a 31spline 8.8(with 3.55s and Disc Brakes) setup for an XJ with matching HPD30 locally. Deal comes with front and rear drive shafts from the XJ. Now just need to figure out wheel spacers, gearing and locker for rear axle for now.      Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2021 Share Posted February 11, 2021 more gearing is better   Link to comment Share on other sites More sharing options...
Misfit_MJ Posted February 11, 2021 Author Share Posted February 11, 2021 Pete, what gearing do you like for street duties with trail riding on weekends on 33's? I'm thinking 4.56? Link to comment Share on other sites More sharing options...
Pete M Posted February 11, 2021 Share Posted February 11, 2021 4.56 is what I would suggest as a rule of thumb for more street than trail, 4.88 if more trail than street. it's a bit up to personal opinion though. Link to comment Share on other sites More sharing options...
Misfit_MJ Posted February 23, 2021 Author Share Posted February 23, 2021 Radio install was painless. How are you guys getting RCA cables and amp turn on wire to the head unit? Area behind radio is sealed pretty tight. Link to comment Share on other sites More sharing options...
olddude Posted February 23, 2021 Share Posted February 23, 2021 Do you know a good Magician? Link to comment Share on other sites More sharing options...
fiatslug87 Posted February 23, 2021 Share Posted February 23, 2021 There's space at the back straight down. Link to comment Share on other sites More sharing options...
Misfit_MJ Posted September 28, 2021 Author Share Posted September 28, 2021 Audio system completed, now to move on to the cooling issues. Flushed cooling system and added louvers to the hood. Need to get it out on the highway to see if that fixed the issue.  Link to comment Share on other sites More sharing options...
Jesse J Posted September 28, 2021 Share Posted September 28, 2021 dig the louvres! Link to comment Share on other sites More sharing options...
Misfit_MJ Posted September 29, 2021 Author Share Posted September 29, 2021 thnx! Â Link to comment Share on other sites More sharing options...
Misfit_MJ Posted August 17, 2022 Author Share Posted August 17, 2022 4wd conversion question? In my area (DFW TEXAS), I'm not seeing many XJs with AX15s. Do see plenty of 4wd XJs with autos... Should I buy an XJ with and auto to swap over, of still try to locate a ax15 from an XJ or TJ. Link to comment Share on other sites More sharing options...
scguy Posted August 17, 2022 Share Posted August 17, 2022 Car-part.com Link to comment Share on other sites More sharing options...
Pete M Posted September 22, 2022 Share Posted September 22, 2022 On 8/17/2022 at 1:02 PM, Misfit_MJ said: 4wd conversion question? In my area (DFW TEXAS), I'm not seeing many XJs with AX15s. Do see plenty of 4wd XJs with autos... Should I buy an XJ with and auto to swap over, of still try to locate a ax15 from an XJ or TJ.  auto or manual is entirely a personal decision. it may take some time to locate an AX-15, but I'm sure you will eventually.  there are some threads on man-auto transmission swapping in here:   Link to comment Share on other sites More sharing options...
Misfit_MJ Posted May 1, 2023 Author Share Posted May 1, 2023 Been busy, but picked up an 8.25 (27 spline) rear axle(Ford 8.8 didnt pan out) . In the process of converting it to 29 splines (not going over 33s) with ebay shafts and an open carrier from a 97 XJ. Also picked up 4.10 gears and a Spartan locker for a crazy low price. Nothing fun to show yet, just cutting off shock brackets and leaf spring perches. Hopefully soon can start working on the hidden winch front bumper and get the 8.25 swapped in. Link to comment Share on other sites More sharing options...
Misfit_MJ Posted May 25, 2023 Author Share Posted May 25, 2023 Found an Ax15 from an XJ with a NP232J, will this setup work for an easy bolt up conversion? Link to comment Share on other sites More sharing options...
Pete M Posted May 27, 2023 Share Posted May 27, 2023 as easy as it can get. Â Link to comment Share on other sites More sharing options...
Drahcir495 Posted August 1, 2023 Share Posted August 1, 2023 You probably have already got the rca cables run, but here’s what I found works. The area behind the radio is pretty limited on space, but as fiatslug87 said it’s very much  doable. I used an electricians fish tape to pull all my wires through, but a coat hanger will work just fine. Tape the wire to the end of the coat hanger and feed the other end down and out of the dash. Then all you have to do is pull it all out Link to comment Share on other sites More sharing options...
