MJ Bumper options
22 hours ago, krustyballer16 said:
I think there is already a page for this.
But dirtbound offroad makes some awesome bumpers. I've ran them for a few years now.
Their rear bumper looks way better than jcr's
Sent from my SM-G973U using Tapatalk
Wow, you're right. That's a great looking rear bumper. I like it a lot more than the JCR.
21 hours ago, OldSch88L said:
If you like stock looking stuff BadDadFab does a really nice stock front bumper with an integrated winch receiver, and of course, the good ol' Westin/Fey rear bumper. Otherwise, theres JCR, Dirtbound, Ares Fabrication, Hanson and Nates for custom stuff that I know of.
That BDF front mount is exactly my speed.
Do you know if the front bumper requires fender cutting?
I like those mounts that poke through for D-Rings. And I like the ability to hide a winch behind there.
The JCR one has been around a good while and their stuff is really top notch. The DBO bumper is very similar in design and it looks like many aspects were copied from the JCR. I like the license plate area for the DBO one but there is a big difference in the D ring tabs on those two. The JCR ones are much thicker. The JCR also does a great job of protecting the corners. The DBO has those little add on corner armor pieces but the bumper itself doesn’t wrap around the corner. I’ll take some pics of mine in a bit
I see what you're saying. And I agree, the wider bumper protection is the one thing I liked better.
I like that the DBO bumper keeps my license plate there. And also allows for their hitch to mount below it (definitely need to tow with my comanche)
Also, those side pieces offered by DBO actually solve another problem that I have...
The rear corners on my bed are full of rust holes. Figured I could sand down, repair, and paint what I can, then put those guards on.
(Unless I can find someone with a short bed for sale that's in better shape than mine... Or even the rear quarters to cut and weld in place. I thought about cutting the bed on my 87 LWB but it's got such a clean body and frame that I can't bear destroying it)
The rear corners on my bed are full of rust holes. Figured I could sand down, repair, and paint what I can, then put those guards on. (Unless I can find someone with a short bed for sale that's in better shape than mine)
Where you located? Lol
I'm not following you; why would the bumper require fender cutting? It uses the stock bumper so it shouldn't interfere with the fenders. You may have to cut the holes for the fairlead and whatnot in your bumper though
It doesn't require cutting. I checked with BDF. Figured I'd ask because every single other bumper out there seems to require cutting.
Ultimately I decided on the JCR DIY because it had better rear clearance than the DBO. This was after I bolted my draw tight hitch on and saw how low it hung.
I wish I had a better license plate provision, but after some Moab wheeling I’m glad I have the rear clearance I do. The long rear end of the MJ needs everything it can get to stay up high.
On 11/16/2020 at 4:51 PM, Tex06 said:
I'm currently considering a BadDadFab BTSB winch mount
Winch: Yes
Prefabricated
BadDadFab
https://www.facebook.com/Baddadfab/
Looks pretty cool and allows a winch mounted without changing the length of the truck. The newest addition is D-rings that stick thru the bumper and tie back to the unibody giving you a nice anchor point. $400 plus shipping seems pretty reasonable too.
95919585_658277111411625_3478680118258302976_n.jpg.083beea155c6f98c80a30ea4b432a9b4.jpg95598637_658277128078290_4677282718931746816_n.jpg.9d95cc421d4e81c4a0fa12bcffe3f0a3.jpg491119981_bdfbumper.JPG.41eec354231c4c8e428a1113e7860dba.JPG
I like this!
Definitely agree. I run the JCR built rear bumper and use a receiver hitch license plate adapter. Works great and my clearance is much better than most.
Tell us more! Did you build it yourself, or is it on the market?
I was considering modifying the JCR DIY rear bumper to add a license step pocket.
Bought it off of Amazon just searched for “receiver hitch license plate”. There is also a mount for a license plate on the d ring tabs from quadratec.
Looking at pics I would say the BDF mount will require cutting of the "crossmember" webbing under the radiator to fit.  This is something required of most aftermarket hidden winch setups I have seen.  It doesn't look like you would need to cut the fenders as it uses the stock bumper.
Thanks. I think I'll do my own, I think I can make it a little more secure and rattle free at the same time. Great place to start from, though.
Just now, BeatCJ said:
I think if that had nutserts, or nuts welded to the back side of the pin holes, I would feel more secure. Great idea, though.
I’ve got an extra license plate in the cab lol. Plus here on island many vehicle don’t even have plates so theft hasn’t been an issue. You could use the safety nuts also like I use for my KC lights
2 hours ago, BeatCJ said:
sounds like Guam is pretty relaxed on that. I have been pulled over, too. I would use a pair of the LED bolts, they are simple to use and wire.
Yep I used those bolts before too. No nobody cares about the light here. Never had an issue with it in Austin either
