Truck won’t unlock
11 minutes ago, 89 MJ said:
Sounds like you get to take the door panel off and make see if the locking mechanism is all hooked up.
9 minutes ago, eaglescout526 said:
Like 89 says. The latch could be seized or the linkage is binding somewhere.
Weird. Started taking the arm rest off and it unlocked  ¯\_(ツ)_/¯. Always something with this truck
yeah similar thing for me yesterday. it wouldnt from the inside or out side but i shot some pb blaster in there ad jiggled a lot and it popped. my keys also made it harder becuase they arent they originals and i need to like put them all the way in and jiggle and pull out until it goes. (I'm gonna get new ones that say jeep because right now my keys say, " for gm cars" :crazy:)
now is the time to lube up that latch mechanism. :L:  I'd do both doors.
2 hours ago, War_Pony89 said:
Mine does this when ever it nears 32, Have to climb in like Bo Duke.  I like the pb blaster idea to both sides. Or maybe just so grease, probably last longer?
yeah it was temporary i just shot it into the keyway to see if that would help and lo and behold.
Power locks or manual? I know it happens on both, but just curious. My driver side does this sometimes also, especially when it's cold. I have power locks which will sometimes get it open after i open the pass side and start it for full juice to the locks. Otherwise, I have to reach across and lock it manually then give it a firm and fast push to unlock to get it to pop sometimes.
