Anyone wrap their jeep instead of paint? thoughts?
1 hour ago, early comanche owner said:
It shows dents but what about pioneer stripes?  Would they need to be peeled before wrapping?
 Yep, would have to be smooth all over otherwise the uneven surfaces will show.
Even if you pull the stripes the surface will be raised slightly where the stripes were as that area has been ‘untouched’ from essentially wear down from elements/ car washing.
I’ve been using wd40 degreaser to remove any leftover adhesive that has baked on over the years and it works great. Straight wd40 works well also. As for wrapping, I wouldn’t do it unless I prepped all the panels the right way. There are so many seams where rust can form and if they are not prepped, treated and sealed correctly, I can see the wrap acting as more of a moisture trap. Remember, as has been said before, these trucks rust from the inside out at least with paint you can see what’s happening and where a problem area may be developing. Just my .02
I wouldn't fret too much if you are planning on off roading the mj. Take care of any rust, prep to prevent as much future rust as possible, and give it a shot. My TJ always came back worse for wear after off roading no matter how cautious I was, and if it were still running, it would be getting wrapped, dents included. The key thing is keeping on top of rust.
