eaglescout526 Posted March 10, 2021 Author Share Posted March 10, 2021 Well...carb was 95% assembled right, not bad for my first carb rebuild. The 5% that wasnt built right was the float and needles werent together as they shouldve been to stop the flow of fuel into the bowls. So now I could be looking at vac, timing or something else. Ill probably need to get my vac stuff sorted out first before rooting with timing and electrical. Link to comment Share on other sites More sharing options...
89 MJ Posted March 10, 2021 Share Posted March 10, 2021 Carbs are a PITA. If you decide to keep the car and still can't get it running right, there are lots of companies that make fuel injection systems that look like 4 barrel carbs and will bolt right on (of course, they are not cheap) Here are some options, but not all: https://www.holley.com/products/fuel_systems/fuel_injection/ Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 10, 2021 Author Share Posted March 10, 2021 On 3/10/2021 at 1:09 PM, 89 MJ said: Carbs are a PITA. If you decide to keep the car and still can't get it running right, there are lots of companies that make fuel injection systems that look like 4 barrel carbs and will bolt right on (of course, they are not cheap) Expand I'm not too worried about getting the carb system just yet. This car has sat since 1998 so it’s a challenge for sure but I have to learn about how cars work prior to fuel injection and so far it’s getting more simple the more I work on it. Link to comment Share on other sites More sharing options...
jdog Posted March 10, 2021 Share Posted March 10, 2021 Carbs aren't bad, was used for years, and just takes a little extra time and finesse to get correct. But once it's correct and set correctly they run just fine Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 10, 2021 Author Share Posted March 10, 2021 Yeah. The fun part will be the fuel mixture screws at the base of the carb that are already a pain to get to. I am very tempted to take the damn hood off this car though. I can imagine it was not a favorable hood open design. Link to comment Share on other sites More sharing options...
derf Posted March 11, 2021 Share Posted March 11, 2021 It also doesn't hurt to go back once a year and readjust things. Sometimes they work their way out of tune and you need to go back and adjust them. Also, I have something like this from back when I ran carburetors. It's great at getting to the idle screws. https://www.amazon.com/Performance-Tool-W1187-Carburetor-Adjuster/dp/B0002KNZL4 Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 12, 2021 Author Share Posted March 12, 2021 On 3/11/2021 at 2:22 PM, derf said: Also, I have something like this from back when I ran carburetors. It's great at getting to the idle screws. https://www.amazon.com/Performance-Tool-W1187-Carburetor-Adjuster/dp/B0002KNZL4 Expand That has been added to my shopping cart! Good find. Problem is is the car has sat since 98 which was the last time it was on the street. Something tells me the PO's father was messing with it at one point for a moment to see why it was running hot. Its missing a fan shroud which probably at the time was no longer made until now. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 20, 2021 Author Share Posted March 20, 2021 Major major progress. I still need to clean contacts and what not. But fuel is PUMPING!!! It’s a slow process but it’s gonna take a few battery charges to get it primed and ready to fire on its own. Once it does, gonna move forward, reinstall everything and do the brakes and hope she drives. Link to comment Share on other sites More sharing options...
Pete M Posted March 20, 2021 Share Posted March 20, 2021 Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 4, 2021 Author Share Posted April 4, 2021 Ok so it’s starting to warm up in a bad way so I may or may not be able to move more forward as I’d like with the T-bird. But I went over today and I cranked it a little bit till the battery died. Took out the battery and let it charge for the moment I was there. Replaced the starter solenoid with the one I thought was shorted. It wasn’t I was just dumb and put the ground cable on it the first time and that’s what caused it to short like it did. Whoops! Part of me knew this at the time but not well enough. Anyways new one installed, cranked it and she fired right up which is fantastic! Link to comment Share on other sites More sharing options...
Pete M Posted April 4, 2021 Share Posted April 4, 2021 so this is the end of phase 2, right? Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 4, 2021 Author Share Posted April 4, 2021 Lol, pretty damn close. Once the cooling system and what not is back in place, last is the brakes by using the XJ master and prop valve to get better breaking. Link to comment Share on other sites More sharing options...
jdog Posted August 12, 2021 Share Posted August 12, 2021 soooooo whens this coming home? Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 12, 2021 Author Share Posted August 12, 2021 That is an absolute great question! I’m currently waiting for the weather to cool down before I can get to this. It’s been killer out. Hopefully I can get the cooling system back together and address the brakes to get this thing driving and stopping. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 26, 2021 Author Share Posted November 26, 2021 Finally got to this thing. With the inevitable rush of my grandparents moving, I am having to get this thing done, possibly quick and dirty too sad to say but its all in the name of time. Anyways: So I got the water pump back on, PS kinda bolted in place as I await to be entirely sure I am ready for the belts to be put on. It starts, runs and revs really high. I think about 1500-2000 RPM. I am damn sure I have a vac leak and it also looks like I have to disassemble the carb again as I can now see open gaps in the throttle plates letting air in. I don't think thats entirely right or normal but I know the mating surface of the intake and the spacer are in meh shape so I am going to replace those to help do away with vac leaks. I am open to any suggestions or tips that will help bring down the idle. I tried the adjustment screws and they seem to have helped but the vac leaks appears to be too great at the moment for a difference. Link to comment Share on other sites More sharing options...
89 MJ Posted November 27, 2021 Share Posted November 27, 2021 Nice……Mopar battery in a Ford Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 27, 2021 Author Share Posted November 27, 2021 On 11/27/2021 at 4:45 AM, 89 MJ said: Nice……Mopar battery in a Ford Expand I have been literally running this car off of free magnetti and Mopar batteries that Chrysler says we can toss out lol. They may not have the cranking power they should, except the big boy diesel one I had did before I killed it but it is so much better than buying a battery to get this car going. Link to comment Share on other sites More sharing options...
JMO413 Posted November 27, 2021 Share Posted November 27, 2021 On 11/27/2021 at 5:26 AM, eaglescout526 said: I have been literally running this car off of free magnetti and Mopar batteries that Chrysler says we can toss out lol. They may not have the cranking power they should, except the big boy diesel one I had did before I killed it but it is so much better than buying a battery to get this car going. Expand Gotta love the scrap list from Mopar. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 27, 2021 Author Share Posted November 27, 2021 On 11/27/2021 at 5:52 PM, JMO413 said: Gotta love the scrap list from Mopar. Expand Oh that list and what they scrap baffles me sometimes. Never makes any sense. Link to comment Share on other sites More sharing options...
JMO413 Posted November 27, 2021 Share Posted November 27, 2021 On 11/27/2021 at 6:32 PM, eaglescout526 said: Oh that list and what they scrap baffles me sometimes. Never makes any sense. Expand Agreed. GM does the same thing. Being a dual line has definitely stocked my garage with some weird and useful items. Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 31, 2021 Author Share Posted December 31, 2021 This thing has been annoying lately. But I think I might have figured out my high idle issue. Thanks to a lot of digging and help from some of you guys, I was able to get the engine to calm down. Turns out the gasket between the carb and the top cover was on wrong some how but upon inspection, it looks like the gasket was made wrong. So a piece of the carb for some reason wasn’t being covered and was allowing more airflow than it should’ve I also found the throttle return spring and mounting plate and got that back on and everything seems to be working like it should. I got the radiator in. Soon it’ll be time to see if I can get it to move under its own power. Link to comment Share on other sites More sharing options...
89 MJ Posted December 31, 2021 Share Posted December 31, 2021 Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2022 Author Share Posted January 14, 2022 I am announcing the death of this project. As of recently I have no place to store it in any way and it has to be removed from my grandparents property ASAP. It will be going back to the family I purchased it from whom will probably in turn sell it again to an enthusiast who has time and space. I can’t say I’m happy about the choice but I know I’ve learned a lot from this short project and the decision is better than it being in the scrap yard. If anything happens to it, I’ll update the thread like if it sells to someone else. The car runs and it’ll drive but won’t brake. I’m more or less proud of what I’ve done to this car. Thanks y’all for any help and input along the way for this car. Keep an eye out for the next one or watch Chunks build for his changes and fun. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2022 Share Posted January 14, 2022 Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2022 Author Share Posted January 14, 2022 On 1/14/2022 at 4:26 PM, Pete M said: Expand Pete the way I look at this, I am glad it will be out of my possession much like how I was when my accord was totaled. I think the engine on this car needs a full rebuild. But I’ll drop a hint as to what the next car could be. It’s a model year newer than what was in Smokey and the bandit. Link to comment Share on other sites More sharing options...
