scguy Posted May 16, 2022 Share Posted May 16, 2022 That header looks sweet. Can't wait to hear it! Link to comment Share on other sites More sharing options...
Pete M Posted May 16, 2022 Share Posted May 16, 2022 10 hours ago, GrandComanche said: sweet! Link to comment Share on other sites More sharing options...
GrandComanche Posted May 22, 2022 Author Share Posted May 22, 2022 Another day's worth of progress. I need to pick up just another little bit of material to cover the back wall and fill in the odd spots. Link to comment Share on other sites More sharing options...
GrandComanche Posted July 17, 2022 Author Share Posted July 17, 2022 Finished up with the heat shield / sound deadening material. Replaced all the weather stripping, both channel runs, beltline moldings, division bar glass runs and door to body seals. Then moved onto wiring for the courtesy and dome lights. When I first bought the truck, there were no interior lights. The previous owner had removed them all and left behind a nice mess of loose wires. After installing new door light switches, referencing the Haynes Repair Manual and replacing all of the corroded, busted and burned out fuses, we able to successfully get the lights up and running! We're going with the Euramtec Universal 12V Auto Courtesy Flip Interior Light. They seem to be a nearly perfect replacement to the originals. We just needed to file the pillar opening just a hair to make them fit. Next up will be wiring the spot lights and fog lights. I will also be looking to add some extra padding to the bench seat, since the driver side is pretty worn down. Link to comment Share on other sites More sharing options...
MiNi Beast Posted July 17, 2022 Share Posted July 17, 2022 Looks quiet Link to comment Share on other sites More sharing options...
GrandComanche Posted August 4, 2022 Author Share Posted August 4, 2022 Alright, got another great days worth of work in! We were able to get the Spot and Fog lights wired and mounted, right to the new switch panel, courtesy of ghetdc320. Went with Lasfit 3" LED Sport Series. Upgraded the headlights with HWstar 2022 Bright Anti-glare LEDs. The door speakers were shot, so we replaced them with Rockville 5.25" factory speakers. Then got the new door cards put in place, but realized that my current mini arm rests won't work. So I ordered new hockey stick style arm rests from TeamCherokee. Put up the new SMS Headliner from a1500ram, and added a DirtBound Molle Roof Rack with a Baja Design Dome Light. And finally got the vinyl floor back inside the cabin. Hopefully next time in the garage we'll get the bench seat squared away and put back in. I also saw in a Comanche group on Facebook that a '97 Wrangler shifter console that has a cupholder will fit with slight modification. I was able to fit it without the seat in, I think it'll work out pretty good. Super excited for the cupholder!!! Link to comment Share on other sites More sharing options...
jeeps always Posted August 12, 2022 Share Posted August 12, 2022 Love the new work you and your dad are putting into the comanche. Projects like that never seem to end, but that's what makes it great! Also adding and fixing things to make it totally your own. Link to comment Share on other sites More sharing options...
GrandComanche Posted August 14, 2022 Author Share Posted August 14, 2022 Haven't had anytime this week to sneak away to the garage, but the mailman was busy! Quick mock up with the Wrangler's shifter console too. Link to comment Share on other sites More sharing options...
Chad R Posted August 15, 2022 Share Posted August 15, 2022 That wrangler shifter console looks real good. Link to comment Share on other sites More sharing options...
GrandComanche Posted June 1, 2023 Author Share Posted June 1, 2023 So it's been awhile since I gave an update, let's see what's going on. The Wrangler's shifter console didn't work out the way I wanted. Even after making a few cuts, it stuck out a little to far, pushed into the bench seat and obstructed the actual shifter, keeping it from going into gear. Going to have to figure something else out or just scrap it all together. I added some much needed seat padding to the bench seat and gave it a extraction cleaning too. Now onto the BIG issue. . .RUST! After all the work that was put into sanding, cutting out and filling holes, it all came back after being on the street during our lovely New York winters! We started addressing the issues, re-sanding and welding until my father found a donor bed on Facebook Marketplace, in much much better condition in Pennsylvania, about 4 hours away. For $200, I think I got a pretty good deal. A few very very minor areas of rust, with very little rot to be filled. Got that sanded down and the old one pulled off. We're going to POR15 the frame and undercarriage before installing the new bed. I was able to pick up a standard Red set of the new Oracle LED Tail Lights, can't wait for those to ship! I'm also thinking about ordering a BoxyJeep replacement tail gate handle, current one is pretty shot. https://boxyjeep.com/products/jeep-comanche-tailgate-handle-full-assembly-1986-1992 That's all I have for now, a long time in-between garage days have slowed down the restoration greatly. I'm hoping to pick up the pace in the coming weeks and try to get the War Horse back together, painted and onto the street. Link to comment Share on other sites More sharing options...
GrandComanche Posted June 16, 2023 Author Share Posted June 16, 2023 Quick update: Got the POR15 on the underside of the bed and the frame. Grabbed all the necessary supplies, I believe, to complete the body work before we move to paint. Can't quite lock down what color I want to go with. Leaning toward a dark blue/gray, just can't figure out the exact shade. Also, I don't think I ever showed the installed Rock Sliders from DirtBound. Originally went on upsidedown or backwards, which left a pretty good sized gap in-between the sliders and the body. We eventually figured it out! Haha Link to comment Share on other sites More sharing options...
GrandComanche Posted July 14, 2023 Author Share Posted July 14, 2023 The body work is done. We sanded, bondo'd, applied rust converter, and wet sanded. Wrapped it up today with taping. Weather permitting we'll get primer on this weekend! Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted July 14, 2023 Share Posted July 14, 2023 39 minutes ago, GrandComanche said: The body work is done. We sanded, bondo'd, applied rust converter, and wet sanded. Wrapped it up today with taping. Weather permitting we'll get primer on this weekend! That's what matters right there! Nice work. As someone from Long Island, I feel your pain. The rust is real. Luckily, my Mj spent most of it's life in North Carolina, but it still has some rust that needs attention. Link to comment Share on other sites More sharing options...
Pete M Posted July 17, 2023 Share Posted July 17, 2023 that actually looks pretty cool. I shall call it: reverse patina. Link to comment Share on other sites More sharing options...
GrandComanche Posted July 18, 2023 Author Share Posted July 18, 2023 Well Pete, I'm sorry to say the reverse patina is no longer. Primer went on today. Link to comment Share on other sites More sharing options...
GrandComanche Posted July 29, 2023 Author Share Posted July 29, 2023 Moving right along, we went with Jeep Rhino PSQ for the color. Kind of a blue-ish gray. I really like how it came out. We also put the bed onto the frame. A few more minor things left, then she's ready for the road again! Link to comment Share on other sites More sharing options...
Drahcir495 Posted July 30, 2023 Share Posted July 30, 2023 Yep, good choice of paint color! Looking really good Link to comment Share on other sites More sharing options...
Pete M Posted July 30, 2023 Share Posted July 30, 2023 ooooooo! love it! can't wait to see it in the sunshine. Link to comment Share on other sites More sharing options...
GrandComanche Posted August 13, 2023 Author Share Posted August 13, 2023 This paint color is wild! Depending on the angle, light source and brightness it can appear Green, Blue or Gray. I really like it a lot. We were able to Rhino line the bed, install the roll bar, spare tire mount, Jerry can holder and Oracle taillights. Ran into an issue with the truck starting and ended up having to replace the ignition coil and ignition control module. Which worked, until the electronic control module went. That will hopefully be here in the next few days. Then replaced the broken track bar mount. Did some more work on the Wrangler shifter console and got that secured in place where it shouldn't interfere with the shifter getting into gear. Also got the tailgate trim painted with help from my mother and her taping patience and added another Wander's Compass to the hood. There are still a few things I'd like to do and a few items I'm waiting on. 98ish percent done I believe.....this time. Link to comment Share on other sites More sharing options...
yungupgrade Posted August 17, 2023 Share Posted August 17, 2023 Did you put POR15 in the inside of the frame/ did you coat the POR15 with another paint? I bought the supplies to do that as well but supposedly you need to coat it with something else to protect it from debris Link to comment Share on other sites More sharing options...
GrandComanche Posted August 17, 2023 Author Share Posted August 17, 2023 18 hours ago, yungupgrade said: Did you put POR15 in the inside of the frame/ did you coat the POR15 with another paint? I bought the supplies to do that as well but supposedly you need to coat it with something else to protect it from debris We did not do inside the frame. With the box off, we cleaned up the frame really good and painted it on nice and thick. Once it drys, it's rock hard. Also did not require the top coat, because this is all underneath the truck and not exposed to the UV rays. Link to comment Share on other sites More sharing options...
yungupgrade Posted August 17, 2023 Share Posted August 17, 2023 2 hours ago, GrandComanche said: We did not do inside the frame. With the box off, we cleaned up the frame really good and painted it on nice and thick. Once it drys, it's rock hard. Also did not require the top coat, because this is all underneath the truck and not exposed to the UV rays. Did you paint the frame under the cab as well? Link to comment Share on other sites More sharing options...
GrandComanche Posted August 18, 2023 Author Share Posted August 18, 2023 21 hours ago, yungupgrade said: Did you paint the frame under the cab as well? No, the undercarriage was surprisingly in really good shape, even under the old bed. I don't plan on driving it during the winter anymore and it'll be stored in the garage. We did the POR15 because why not, when the bed was already off. Link to comment Share on other sites More sharing options...
yungupgrade Posted August 18, 2023 Share Posted August 18, 2023 2 hours ago, GrandComanche said: No, the undercarriage was surprisingly in really good shape, even under the old bed. I don't plan on driving it during the winter anymore and it'll be stored in the garage. We did the POR15 because why not, when the bed was already off. How did you prep the metal for the POR15? Link to comment Share on other sites More sharing options...
GrandComanche Posted August 21, 2023 Author Share Posted August 21, 2023 On 8/18/2023 at 7:52 PM, yungupgrade said: How did you prep the metal for the POR15? Brushed it clean of dirt and surface rust with purple Scotch Brite pad. Really just gave it a good once over. Link to comment Share on other sites More sharing options...
