coolwind57 Posted October 9, 2019 Share Posted October 9, 2019 For those of you interested, Tomco of St. Louis, MO makes an Air Temperature Sensor and have for a while it seems. http://www.tomco-inc.com/ They do have a new part number, replacing the old #12120. New part number is 12134 and it runs $69.73. They have them in stock. Telephone: 314-646-5300 I read that some guys were using the 312-190, modifying with the AC Delco PT307 harness, which is quite a bit less expensive possible option. Just sharing what I've been searching about today. Link to comment Share on other sites More sharing options...
JMO413 Posted October 9, 2019 Share Posted October 9, 2019 The Delco works and is quite a bit cheaper. Sensor, connector to the sensor, & connector end to plug into harness. Link to comment Share on other sites More sharing options...
Swampy Posted December 30, 2019 Share Posted December 30, 2019 On 10/9/2019 at 7:17 PM, JMO413 said: The Delco works and is quite a bit cheaper. Sensor, connector to the sensor, & connector end to plug into harness. Do 4.0l and 2.5l engines have the same sensor. I ordered that one but it's too big Link to comment Share on other sites More sharing options...
JMO413 Posted December 30, 2019 Share Posted December 30, 2019 Just now, Swampy said: Do 4.0l and 2.5l engines have the same sensor. I ordered that one but it's too big Not for sure. I actually mounted mine in the air box. Link to comment Share on other sites More sharing options...
Swampy Posted December 30, 2019 Share Posted December 30, 2019 32 minutes ago, JMO413 said: Not for sure. I actually mounted mine in the air box. ohh so it doesn't have to go directly on the manifold? Link to comment Share on other sites More sharing options...
JMO413 Posted December 30, 2019 Share Posted December 30, 2019 From the factory it goes directly in the intake. I saw no real difference with it in the air cleaner. The ECM does read the air temp is lower beacuse it is. The intake is not heating the sensor. Link to comment Share on other sites More sharing options...
Swampy Posted December 30, 2019 Share Posted December 30, 2019 Just now, JMO413 said: From the factory it goes directly in the intake. I saw no real difference with it in the air cleaner. The ECM does read the air temp is lower beacuse it is. The intake is not heating the sensor. Did you install it on the upper part or the lower part of the intake box Link to comment Share on other sites More sharing options...
JMO413 Posted December 30, 2019 Share Posted December 30, 2019 This is mine installed in the air cleaner. I put it after the air filter to keep it clean. It stays much cleaner than in the intake manifold. Link to comment Share on other sites More sharing options...
JMO413 Posted December 30, 2019 Share Posted December 30, 2019 I installed it in the top. That way it would get filtered air and stay clean. It stays much cleaner than in the intake manifold. Link to comment Share on other sites More sharing options...
Swampy Posted December 30, 2019 Share Posted December 30, 2019 17 minutes ago, JMO413 said: I installed it in the top. That way it would get filtered air and stay clean. It stays much cleaner than in the intake manifold. Perfect. I'm going to install mine there tomorrow Link to comment Share on other sites More sharing options...
JMO413 Posted December 30, 2019 Share Posted December 30, 2019 3 minutes ago, Swampy said: Perfect. I'm going to install mine there tomorrow Good to hear your getting it so put back together. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 30, 2019 Share Posted December 30, 2019 47 minutes ago, JMO413 said: It stays much cleaner than in the intake manifold. In the intake of the 2.5..........fuel wash, whereas the 4.0 has no fuel wash. Also, the 2.5 has a heated intake whereas the 4.0 does not. Considerable difference in air temps. Just pointing that out. Everyone here keeps comparing the apples to the oranges. Link to comment Share on other sites More sharing options...
JMO413 Posted December 30, 2019 Share Posted December 30, 2019 3 minutes ago, Jeep Driver said: In the intake of the 2.5..........fuel wash, whereas the 4.0 has no fuel wash. Also, the 2.5 has a heated intake whereas the 4.0 does not. Considerable difference in air temps. Just pointing that out. Everyone here keeps comparing the apples to the oranges. You are correct. I know nothing about the 2.5. There 4.0 on the other hand I have had a few of. Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 30, 2019 Share Posted December 30, 2019 4 minutes ago, JMO413 said: You are correct. I know nothing about the 2.5. There 4.0 on the other hand I have had a few of. Well, I wasn't correcting you. Mainly making a statement to the 2.5 guys, they need to know and understand THEIR engine. Link to comment Share on other sites More sharing options...
omega_rugal Posted December 31, 2019 Share Posted December 31, 2019 the perfect place should be below the throttle body... the 4.0 has it near the firewall, what if the other side is hotter/cooler? Link to comment Share on other sites More sharing options...
Ωhm Posted December 31, 2019 Share Posted December 31, 2019 The perfect place is where engineering put it. Keep in mind any location hotter or colder, fuel trim will compensate for because O2S is boss and 14.7:1 will be maintained. Unless location is so hot or so cold ECU may default to OPEN LOOP. Link to comment Share on other sites More sharing options...
zomeizter Posted January 1, 2020 Share Posted January 1, 2020 ^^this^^ Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted November 23, 2024 Share Posted November 23, 2024 Has anyone discovered improvements with moving the Intake AIr Temperature sensor to the air box? This is an old article about it claiming 1-1.5mpg gains: https://markism.net/jeep_IAT_relocate.html I'm curious if anyone has had success doing this. Maybe I'll make a new thread about it. Thanks! Link to comment Share on other sites More sharing options...
89 MJ Posted November 23, 2024 Share Posted November 23, 2024 On 12/29/2019 at 5:14 PM, JMO413 said: Not for sure. I actually mounted mine in the air box. 26 minutes ago, Salvagedcircuit said: Has anyone discovered improvements with moving the Intake AIr Temperature sensor to the air box? This is an old article about it claiming 1-1.5mpg gains: https://markism.net/jeep_IAT_relocate.html I'm curious if anyone has had success doing this. Maybe I'll make a new thread about it. Thanks! JMO, did you see any fuel economy gains? Link to comment Share on other sites More sharing options...
JMO413 Posted November 23, 2024 Share Posted November 23, 2024 I never really checked for mileage close enough to tell. I didn't think it hurt it but if it did help it was but by much. Link to comment Share on other sites More sharing options...
Salvagedcircuit Posted November 24, 2024 Share Posted November 24, 2024 I was debating putting a threaded brass insert into the top rear of the air box and a plug into the intake. Then using it for a month locally then switching back and doing a comparison. I need to find that brass threaded insert first. I should be able to heat-set it into the plastic, similar to the threaded inserts used in 3D printed parts. Link to comment Share on other sites More sharing options...
