Awinski Posted April 23, 2019 Posted April 23, 2019 On 2/25/2019 at 1:22 PM, dzlmnche said: Yes, unfortunately I did. Rough math says I lost about 1 qt of capacity in the sump. Not much to be done to avoid it though, and have seen 5cyl swaps with even more removed. You could always ifs the front. Shouldn't look much different till someone got under it. Then you'd have plenty of room
dzlmnche Posted May 9, 2019 Author Posted May 9, 2019 About 1200 miles so far, averaging 28.5 mpg. Really needs a turbo with the 3.55s... soon enough. Grabbing seats and console from a 99 2dr XJ this weekend.
bigmistake Posted May 17, 2019 Posted May 17, 2019 I might have missed it - do you have A/C in your truck? Did you keep the jeep compressor?
dzlmnche Posted May 17, 2019 Author Posted May 17, 2019 Nope, no AC. Never had it.Seats and console done. I adapted to MJ boot to the auto shift cover but found the boot is too stiff where it’s located and makes shifting difficult. Bought a leather boot on eBay. Also bought a blank for the t case shifter hole.
dzlmnche Posted August 1, 2019 Author Posted August 1, 2019 Turbo installed. Drives much better.Averaging 29mpg on my commute.
Pete M Posted August 1, 2019 Posted August 1, 2019 turbos make everything better. it really looks factory in there. I remember when the Libby blew an air hose and I lost all my boost. felt like I lost half my horsepower
kansashogan Posted August 2, 2019 Posted August 2, 2019 That diesel looks like it was meant to be there. Good job.
dzlmnche Posted August 5, 2019 Author Posted August 5, 2019 Thanks guys! My intention was to try to make it look like it came there from the factory, makes me happy to hear an objective opinion that it looks that way.Lot of zip tied stuff I plan to clean up.6hr round trip this weekend and could not be happier. Has motivated me to give it that last 10% of love it needs to drive like new. Ordered some new shocks, rebuild steering gear, add some sound deadening.
dzlmnche Posted September 17, 2019 Author Posted September 17, 2019 Full gauge cluster swapped in and working. Tach run off alternator using Dakota Digital conversion box thingy.Floor patch, carpet, rear window in the coming weeks. Couple healthy layers of undercoating oil and keep on driving. Over 7,000 miles on it to date.
A-man930 Posted October 2, 2019 Posted October 2, 2019 Well done swap! Nice to hear you're happy with the results
dzlmnche Posted October 22, 2019 Author Posted October 22, 2019 Don’t look too close, this is not a SEMA build.New carpet and rear window next. Heavy dose of NH Oil undercoating under the whole truck. Then, keep racking up the miles.
Pete M Posted October 29, 2019 Posted October 29, 2019 Sema builds are just better at hiding the ugly
dzlmnche Posted October 30, 2019 Author Posted October 30, 2019 Done. Glad it’s behind me. Undercoating oil coming up soon.
Comanchejess Posted October 31, 2019 Posted October 31, 2019 On 4/11/2019 at 9:13 PM, BustedKnuckleJK said: Dude! This swap is so kickass, and cheers on the detailed pictures. Very well done! This is definitely one of the coolest most bad @$$ swaps I've ever seen on any vehicle.
eaglescout526 Posted October 31, 2019 Posted October 31, 2019 On 10/29/2019 at 6:39 PM, dzlmnche said: I don't know how or why but the garnet interior with the black bezel and black face on the cluster looks really damn good. Just some maroon or black carpet and it will look better.
dzlmnche Posted November 18, 2019 Author Posted November 18, 2019 10k miles on the swap on this thing today. Ready to keep racking up the miles.Underside got a heavy coating of NH Oil. Need to grab some sand bags to toss in the bed before it snows.
Pete M Posted November 26, 2019 Posted November 26, 2019 I still shudder at the thought of a non-rusty MJ in the salt. but what must be done, must be done. I always suggest a set of snow tires.
Awinski Posted November 27, 2019 Posted November 27, 2019 On 11/18/2019 at 10:32 AM, dzlmnche said: 10k miles on the swap on this thing today. Ready to keep racking up the miles. Underside got a heavy coating of NH Oil. Need to grab some sand bags to toss in the bed before it snows. Need to get myself some of that under coating as well.
dzlmnche Posted November 27, 2019 Author Posted November 27, 2019 I still shudder at the thought of a non-rusty MJ in the salt. but what must be done, must be done. I always suggest a set of snow tires. I get it, but I don’t own anything to preserve it, I own things to use them.I’m no newb to snow, but I think LSD and weight with decent tires will work pretty well
Pete M Posted November 27, 2019 Posted November 27, 2019 have you gotten to drive on snow tires yet? my old minivan (the only thing I've been able to put snow tires on) DOMINATED the white stuff and was an absolute joy to drive no matter how nasty the weather. (I don't have a minivan GIF so you'll have to pretend that's a silver Town-n-Country ) just be sure to wash out your rockers (there's a tiny access hole near the back), frame, doors, and above the rear tires inside the bed. Our trucks rot from the inside-out and flushing them out will go a long way towards preventing the rust from starting.
dzlmnche Posted November 27, 2019 Author Posted November 27, 2019 I used about twice the mount of oil they recommended. Filled rails, rocker panels, fender wells, and up inside the bed (where it looks like it’s already started ). I like the oil because it never hardens and seeps into areas a normal coating can’t get. I definitely plan to make sure I wash it after every storm.
A-man930 Posted November 28, 2019 Posted November 28, 2019 11 hours ago, dzlmnche said: I used about twice the mount of oil they recommended. Filled rails, rocker panels, fender wells, and up inside the bed (where it looks like it’s already started ). I like the oil because it never hardens and seeps into areas a normal coating can’t get. I definitely plan to make sure I wash it after every storm I agree completely. I bought a gallon of Fluid Film and an applicator gun kit.
dzlmnche Posted December 23, 2019 Author Posted December 23, 2019 Gave it some thought and decided I put too many miles on this thing to not have snow tires. Mounted four of these this weekend along with the Powertrax Pro Grip helical gear LSD. Can’t wait for some snow!!The NH Oil undercoating seems to be doing well. Probably apply it in the wheel wells a couple more times this winter.
Pete M Posted January 31, 2020 Posted January 31, 2020 snow tires are just the best! I seriously can't understand why more people don't have them
thecodemonk Posted March 9, 2020 Posted March 9, 2020 On 1/31/2020 at 6:37 AM, Pete M said: snow tires are just the best! I seriously can't understand why more people don't have them I've heard everything from: - "I have 4wd/awd/traction control, winter tires probably won't be that big a difference" - "The tires I have do just fine" - "They're so expensive...why would I have a second set of tires just for winter?" - "They'll disintegrate as soon as it's summer!" - "They don't look as cool as my mud-terrains." They're a huge difference though. I swear by them, even on my wife's subaru.
