Jackrabbit41 Posted January 29, 2019 Share Posted January 29, 2019 So looking for a front dana 44 for my comanche now. Got some questions and wanting some advice. First of all, but rigs will have a dana 44 with my bolt pattern and driver drop and same width? I know theyre rare but just trying to do my homework. Now, I got a buddy selling fully built mathcing dana 44s with RCVs, lockers, 4.56s, and trussed and set up for a 3 link for 3,000$. Do yall think I should just go with that? I just don't need a rear 44 because I have a ford 8.8 already and I also don't want to just go and drop 3,000$ right now. Thanks yall! Link to comment Share on other sites More sharing options...
kryptronic Posted January 29, 2019 Share Posted January 29, 2019 Why do you need a D44 front? Are you running very large tires or wheeling your rig extremely hard? As far as I know, the only driver side drop D44s that are the right width are found on 1982-1991 Wagoneers and 2003-2006 Wrangler TJ Rubicons. The swap doesn't gain you much over the stock D30, which is plenty stout. Unless you need a D44 up front, or have more money than most, skip it. Link to comment Share on other sites More sharing options...
Eagle Posted January 29, 2019 Share Posted January 29, 2019 15 minutes ago, kryptronic said: As far as I know, the only driver side drop D44s that are the right width are found on 1982-1991 Wagoneers and 2003-2006 Wrangler TJ Rubicons. The swap doesn't gain you much over the stock D30, which is plenty stout. Unless you need a D44 up front, or have more money than most, skip it. And the 82-91 Wagoneers don't use the same wheel bolt pattern as the XJ/MJ. Link to comment Share on other sites More sharing options...
Pete M Posted January 29, 2019 Share Posted January 29, 2019 is your dana 30 stock? there are upgrades you can do that cost waaaaaaay less than trying to put a 44 in there. Link to comment Share on other sites More sharing options...
kryptronic Posted January 29, 2019 Share Posted January 29, 2019 3 hours ago, Eagle said: And the 82-91 Wagoneers don't use the same wheel bolt pattern as the XJ/MJ. This too. Would need a Wagoneer or Rodeo/Passport D44 rear to match. Link to comment Share on other sites More sharing options...
mnkyboy Posted January 29, 2019 Share Posted January 29, 2019 $3000 for those axles probably isn't bad with everything done, just be sure that D44s are going to be enough axle for your build, you could spend that same $3k and be sitting on 1 tons. Also, personally i would much rather have a built D44 rear over your current 8.8", strength is similar between the D44 and 8.8 but a D44 has much better ground clearance, an 8.8 has roughly the same clearance measurements as a D60. Link to comment Share on other sites More sharing options...
89eliminator Posted January 30, 2019 Share Posted January 30, 2019 the only one that will kind of match what you are looking for is a TJ D44 which is a 30/44 hybrid, thus not much of an upgrade. Link to comment Share on other sites More sharing options...
Darren Posted January 30, 2019 Share Posted January 30, 2019 $3000 for bolt in Dana 44s with RCV shafts, Lockers, and 4.56 gears. That is a steal. Try adding up parts and labor on building those axles from scratch. Link to comment Share on other sites More sharing options...
Smokeyyank Posted January 30, 2019 Share Posted January 30, 2019 3k for those axles isn't a bad deal especially if they are ready to bolt in. If you're running the 33's and the AX15 that would be a good all around combo. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted February 13, 2019 Author Share Posted February 13, 2019 On 1/29/2019 at 5:25 AM, kryptronic said: Why do you need a D44 front? Are you running very large tires or wheeling your rig extremely hard? As far as I know, the only driver side drop D44s that are the right width are found on 1982-1991 Wagoneers and 2003-2006 Wrangler TJ Rubicons. The swap doesn't gain you much over the stock D30, which is plenty stout. Unless you need a D44 up front, or have more money than most, skip it. I want to run 37s and yeah I know all that but still want a 44 Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted February 13, 2019 Author Share Posted February 13, 2019 On 1/29/2019 at 10:14 AM, mnkyboy said: $3000 for those axles probably isn't bad with everything done, just be sure that D44s are going to be enough axle for your build, you could spend that same $3k and be sitting on 1 tons. Also, personally i would much rather have a built D44 rear over your current 8.8", strength is similar between the D44 and 8.8 but a D44 has much better ground clearance, an 8.8 has roughly the same clearance measurements as a D60. Yeah I thought about 1 tons but Id need new wheels and I think itd be cheaper for me to just do a 44. Probably going to wait till the swap meet here in WA in Puyallup on march 10 and find a dana 44 Link to comment Share on other sites More sharing options...
Darren Posted February 13, 2019 Share Posted February 13, 2019 The only way you'll be able to use your existing wheels is if you get a TJ/LJ Rubicon 44. Wagoneer 44's are 6-lug. Link to comment Share on other sites More sharing options...
kryptronic Posted February 14, 2019 Share Posted February 14, 2019 22 hours ago, Jackrabbit41 said: I want to run 37s and yeah I know all that but still want a 44 37s. Gotcha. You probably need the D44. Link to comment Share on other sites More sharing options...
