Chief Falling Rock Posted October 5, 2018 Posted October 5, 2018 Is there such a thing as a 3 inch lift kit made for Comanches that is not an add a leaf for the rear? I would prefer to just start with a whole new set of leaf springs.Â
JMO413 Posted October 5, 2018 Posted October 5, 2018 I just went through this, the truck I bought had a cracked rear spring. The only lift I could find with rear springs with was a 4.5" from Rusty's Off Road. I am pretty happy with the lift and the quality. I did have to buy sway bar links and longer brake lines to make it all work. Still happy with the out come.Â
Chief Falling Rock Posted October 5, 2018 Author Posted October 5, 2018 I'm afraid that's what I am going to run into. I don't really want to lift it that much, but may have to if no one knows of another option.Â
Dzimm Posted October 5, 2018 Posted October 5, 2018 That Rusty's kit is the shortest kit I could find with full springs as well. I'm totally happy with it tho, really isn't too tall. I could see it getting out of hand if you put huge tires on it. Mine has 29" tires but they look small. With 30" or 31" it would fill the wheel wells out but would raise the truck a little more.Â
Chief Falling Rock Posted October 5, 2018 Author Posted October 5, 2018 Dzimm I take it yours is the 4.5 inch lift as well?
WahooSteeler Posted October 5, 2018 Posted October 5, 2018 http://www.hellcreeksuspensions.com/  3" leaf packs and 3" Rough Country coils  I've got a pair of the RC 3" coils I'll sell.......
Dzimm Posted October 6, 2018 Posted October 6, 2018 8 hours ago, Chief Falling Rock said: Dzimm I take it yours is the 4.5 inch lift as well? Yes, same Rusty's kit JMO413 mentioned.Â
HOrnbrod Posted October 6, 2018 Posted October 6, 2018 11 hours ago, Chief Falling Rock said: I'm afraid that's what I am going to run into. I don't really want to lift it that much, but may have to if no one knows of another option.  Rear: New General Springs metric ton rear springs then when they settle, Teraflex 1" extended rear shackles. Front : To match the rear, OME 930 coils w. whatever spring pads you might need to equalize. For me a 1/2" stock spring pad was perfect. Plus all your suspension springs F & R are new. Handles/rides great.  Total lift after full settle = ~2.5".
Chief Falling Rock Posted October 8, 2018 Author Posted October 8, 2018 On 10/5/2018 at 11:51 PM, HOrnbrod said:  Rear: New General Springs metric ton rear springs then when they settle, Teraflex 1" extended rear shackles. Front : To match the rear, OME 930 coils w. whatever spring pads you might need to equalize. For me a 1/2" stock spring pad was perfect. Plus all your suspension springs F & R are new. Handles/rides great.  Total lift after full settle = ~2.5".  Thank you Hornbrod! I like the sound of this
HOrnbrod Posted October 8, 2018 Posted October 8, 2018 18 minutes ago, Chief Falling Rock said:  Thank you Hornbrod! I like the sound of this  It works well and is all quality stuff. Perfect for 31's. Do do the heavy(er) front end suspension component upgrades too, like the ZJ sway bar, WJ control arms, etc.
JeepFanactic Posted October 8, 2018 Posted October 8, 2018 On 10/6/2018 at 12:51 AM, HOrnbrod said:  Rear: New General Springs metric ton rear springs then when they settle, Teraflex 1" extended rear shackles. Front : To match the rear, OME 930 coils w. whatever spring pads you might need to equalize. For me a 1/2" stock spring pad was perfect. Plus all your suspension springs F & R are new. Handles/rides great.  Total lift after full settle = ~2.5". Hornbrod  Will this set up give you 3 inches in the rear? Which one do you go with the 5 spring or the 4 spring? Thanks Â
HOrnbrod Posted October 8, 2018 Posted October 8, 2018 I don't know what you are driving. I got 3" out back at first, but like all leaf springs they settle a bit. I lost about 3/4" over a year's time, thus the longer shackles to bring it back up. Plus I have a camper shell on a longbed, so it'll settle a bit more than your average SWB MJ. Â
JeepFanactic Posted October 8, 2018 Posted October 8, 2018 1 minute ago, HOrnbrod said: I don't know what you are driving. I got 3" out back at first, but like all leaf springs they settle a bit. I lost about 3/4" over a year's time, thus the longer shackles to bring it back up. Plus I have a camper shell on a longbed, so it'll settle a bit more than your average SWB MJ.  That's a nice Mj.. How many leaf pack is that? four or five?  Thanks Â
HOrnbrod Posted October 8, 2018 Posted October 8, 2018 1 minute ago, JeepFanactic said: That's a nice Mj.. How many leaf pack is that? four or five?  Thanks  Thank you. The General Springs Metric Ton MJ springs are five-leaf, two of which are overload leafs. Â
fiatslug87 Posted October 23, 2018 Posted October 23, 2018 Hey Don, are these what you have the Teraflex 1.5" shackles https://teraflex.com/shop_items/xj-1-5-rear-shackle-kit? I see Warrior makes a 1" http://www.warriorproducts.com/catalog-new/catalog/jeep/84-01-jeep-cherokee-xj-2/suspension/leaf-spring-shackles/
Nodrama43 Posted October 26, 2018 Posted October 26, 2018 I bought Hell Creek leaf springs and am using Old man emu front springs with JKS adustable coil spacers to put the front right where I want it after I see what I get in the rear. Â Â
HOrnbrod Posted October 26, 2018 Posted October 26, 2018 On 10/23/2018 at 4:30 PM, fiatslug87 said: Hey Don, are these what you have the Teraflex 1.5" shackles https://teraflex.com/shop_items/xj-1-5-rear-shackle-kit? I see Warrior makes a 1" http://www.warriorproducts.com/catalog-new/catalog/jeep/84-01-jeep-cherokee-xj-2/suspension/leaf-spring-shackles/  Si Mike - those are the Teraflex shackles I'm using.
HOrnbrod Posted October 26, 2018 Posted October 26, 2018 17 minutes ago, Nodrama43 said: I bought Hell Creek leaf springs and am using Old man emu front springs with JKS adustable coil spacers to put the front right where I want it after I see what I get in the rear.    How much lift did you get with the Hell Creek rear leafs? And are your rear wheels still centered in the flare arch? A pic would be nice...
Nodrama43 Posted October 28, 2018 Posted October 28, 2018 On 10/26/2018 at 12:27 AM, HOrnbrod said:  How much lift did you get with the Hell Creek rear leafs? And are your rear wheels still centered in the flare arch? A pic would be nice... none of it is installed yet.  The truck is painted, interior is in, the engine is rebuilt sitting on a stand and a bunch of parts piled up ready to go. I will be starting the lift install process very soon.  I will be sure to post up pictures once the lift is on.  I purchased the OME 2.75" lift springs along with JKS ACOS so I can adjust the front lift depending on what the rear leafs give me.  This the same process I used when I put the lift on my 2001 XJ and the ACOS came in very handy when I added the Backbone winch mount and Warn 9000 with synthetic rope.  I used OME for both front and rear with it and I ended up with 3.5" of total lift after everything settled on the XJ. I am not sure what to expect from the Hell Creek spring set but they seem to get great reviews so I ordered them. Â
HOrnbrod Posted October 28, 2018 Posted October 28, 2018 One of the guys installed some Hell Creek lift springs awhile back and his wheels ended up off-center. I don't remember if this was a one-shot thing or what.  Maybe someone else will chime in. Â
Nodrama43 Posted October 29, 2018 Posted October 29, 2018 looks like those were installed backward, or the top leaf was installed the wrong direction.   I will be sure to match them up against the originals when I pull them out.  I have the bed off the truck right now. Once installed If mine look like that Hell Creek will be buying them back. lol
masimmons25 Posted October 29, 2018 Posted October 29, 2018 They are not installed backwards. This is a common concern with the aftermarket springs (general spring metric ton reproductions, hell creek springs ect.) The spring is designed this way to allow for load in the bed which will compress the spring and move the axle rearward, at least thats what I have read. As an owner of the general spring metric tons I'm not wild about the apperance, but I understand the reasoning behind it.
HOrnbrod Posted October 29, 2018 Posted October 29, 2018 The GS MT springs do not offset the rear axle that much.
NickS Posted October 30, 2018 Posted October 30, 2018 I was eyeing hell creek springs but this has me worried. Do you have the link to the original post? Was there any follow up?Â
HOrnbrod Posted October 30, 2018 Posted October 30, 2018  14 minutes ago, AntiNicker said: I was eyeing hell creek springs but this has me worried. Do you have the link to the original post? Was there any follow up?  Found it - HERE
