JeepFanactic
Everything posted by JeepFanactic
How do I check for either a broken wire or bad ground?
My MJ has been sitting in the garage for a while. Started it up today and the fuel gauge reads past the full mark. I haven't driven it in a while. Any ideas? Thanks
Carpet Replacement
JeepFanactic replied to JeepFanactic's topic in MJ Tech: Modification and Repairs
Great...can't wait to see how it turns out... -
Carpet Replacement
I have the black vinyl carpet and its falling apart from old age. -
Can anyone recommend a decent carpet replacement. I tried doing a search but everything is pretty dated...Thanks
Nice Truck
Seat Bracket Power to Manual
Great Thanks -
I just finished up my conversion and it really wasn't that difficult. This was the first time ever doing anything like this. What I did was I asked a lot of questions and read a lot of write ups. There are a lot of knowledgeable and patient people here that are willing to help out as much as possible. A lot of times the same question and topics come up and it must be frustrating to the see the same thing come up but everyone is willing to help out so don't be afraid to ask a question. I upgraded to the AX-15 transmission so it took longer to find all the parts that I needed. If I would of started out with a automatic it would of been a lot quicker since it seams there a lot more of them out there. It is definitely easier to have a donor vehicle in front of you as I always found myself running to the junkyard for little things that I didn't have. It's been a fun project and I learned a lot of things that I didn't know. Good Luck
I got seats out of a 2 door 89 XJ that are power. Is it possible to remove the power brackets and put in manual brackets from a 93 XJ and below. Thanks -
Looking at 2 door seats today. Are the brackets on power XJ seats interchangeable with manual seats. Also are the seats able to recline manually or are they power also. Is it better to look for manual seats. Thanks
They are power seats. Do you know if they could be swapped to manual? Will they be able to be adjusted/ tilt back?
Just looking for thoughts and opinions. Going to pick up a center console and bucket seats out of a 2 door XJ tomorrow. Been looking for 2 door seats for awhile now. The seats are in decent shape but are gray and my interior is blue. Should I get the seats redone at a shop or should I go with the all gray interior. Just looking for ideas for what people have done. Thanks
Looking for 2dr buckets seats or MJ seats. Prefer blue in color. Thanks
Thanks for the pictures. I have narrowed it down to the 16 inch Moab's or the Ravines. Let the search begin. Thanks
What's a fair price for a set of Ravines? Just so i know what there going for?
That's with no lift?
Nice MJ....What size tire are you running?
Wow that's a nice truck. What size tire are you running?
I know this is personal preference but I am looking to put 31's on my 87 MJ SWB with a 3 inch lift. I have narrowed it down to the following rims: Canyon, Ravine and the 16 x 8 Moabs. I know the other two are 15 inch rims. I was just wondering if anyone prefers one type over the other. I also just like the look of stock rims. Just looking for feedback. Thanks
3" Lift kit w/o Add a leaf
JeepFanactic replied to Chief Falling Rock's topic in MJ Tech: Modification and Repairs
What shocks are you running? Need to get a set to finish my lift. -
I just finished lifting my MJ 3.5 inches in the front. The factory bump stops are closed to the new coil spring. It looks like they may start rubbing when I hit a bump. Is this normal or is there a way to fix this. This is my first time doing a lift kit. Also I have adjustable upper and lower control arms which I lengthen a little bit. Any help would be appreciated. Thanks
That's a nice Mj.. How many leaf pack is that? four or five? Thanks -
Hornbrod Will this set up give you 3 inches in the rear? Which one do you go with the 5 spring or the 4 spring? Thanks -
I'm looking at options. I seen one vendor selling leaf springs for $600. Is that the going rate or are there other alternatives.
Currently my MJ has 2wd leaf springs completed the 4wd conversion a couple of months ago.
