Wounded_Fighter Posted July 11, 2018 Posted July 11, 2018 Has anyone ever tried to swap out the small triangle window for a vent window? I'm thinking about trying to accomplish it if I can...
Pete M Posted July 11, 2018 Posted July 11, 2018 yup, they swap directly. be careful though, the movable vent windows are prone to leaks, both air and water.
jpdriver1 Posted July 11, 2018 Posted July 11, 2018 35 minutes ago, Pete M said: yup, they swap directly. be careful though, the movable vent windows are prone to leaks, both air and water. yep --- they can drool in the rain and whistle in the wind
Eagle Posted July 11, 2018 Posted July 11, 2018 I bought a Cherokee Pioneer new in 1988. The operable vent windows were an extra cost option, which I bought. They leaked. The factory had a "fix" -- replace the operable windows (that I had paid extra for) with fixed glass -- but they wouldn't refund the price of the option. I told the factory rep to pound sand. I smeared the gaskets with silicone grease, closed the vents, and they haven't been opened since. That was 30 years ago. Bottom line -- DON'T DO IT.
Minuit Posted July 11, 2018 Posted July 11, 2018 I got REAL tired of them dripping water onto my carpet and whistling on my nice truck, so I put them on my not nice truck. Don't do it if you care about water leaks.
HOrnbrod Posted July 11, 2018 Posted July 11, 2018 This comes up at least once a year. My vent windows have never leaked water or air, even in the car wash. The gaskets are firm; I keep them lubricated so they don't dry out and crack. I had to replace the latch handle about six years ago on the most used drivers side - the only maintenance I've ever done in 15 years. I really like them and would hate the fixed windows. Bottom line - Find a nice pair and DO IT.
Wounded_Fighter Posted July 11, 2018 Author Posted July 11, 2018 7 minutes ago, HOrnbrod said: This comes up at least once a year. Yeah... I posted it and went to sleep, lol. I Think I did it as a note to myself since I was on the site. I searched it this morning and saw all the results. haha Pretty much the same reactions it seems.
Pete M Posted July 12, 2018 Posted July 12, 2018 yeah, it's just one of those things that will never have a consensus. just be cautious and inspect before buying. check for cracked rubber and wallowed out pivot holes (and don't throw the old windows out, just in case).
NC Tom Posted July 24, 2018 Posted July 24, 2018 On 7/11/2018 at 3:15 PM, HOrnbrod said: This comes up at least once a year. My vent windows have never leaked water or air, even in the car wash. The gaskets are firm; I keep them lubricated so they don't dry out and crack. I had to replace the latch handle about six years ago on the most used drivers side - the only maintenance I've ever done in 15 years. I really like them and would hate the fixed windows. Bottom line - Find a nice pair and DO IT. I love mine too! My first car, a 73 Dodge Dart, had them so I guess I'm partial. However, my MJ driver's side vent is crazy loose. I noticed a nut and spring up under the window inside the door. Tried to tighten it, but nada. Is there a way to tighten these vents?
Pete M Posted July 24, 2018 Posted July 24, 2018 I installed mine right before my trip out west and they were an absolute godsend on the freeway in kansas in summer with no AC! but the drivers side quickly showed it couldn't keep the rain out no matter what I did. I still have the pass side in place and usable. in fact, it's my trail mirror now. I stuck a 3" convex mirror to it and fold it out to see what the rear tire is doing.
DirtyComanche Posted July 24, 2018 Posted July 24, 2018 Can you buy new seals for them? I wish I had them on the highway. But I think I'd rather just go to the new style large one piece window.
HOrnbrod Posted July 24, 2018 Posted July 24, 2018 1 hour ago, NC Tom said: I love mine too! My first car, a 73 Dodge Dart, had them so I guess I'm partial. However, my MJ driver's side vent is crazy loose. I noticed a nut and spring up under the window inside the door. Tried to tighten it, but nada. Is there a way to tighten these vents? Once in awhile new R & L handle assemblies pop up on Ebay, p/n 83504101 (R) and -02 (L). They really tighten things up. Also the pivot hinge pin gets worn over the years. An easy cheap fix is to drill the worn pin out and replace it with a stainless steel pop-rivet and appropriately sized stainless flat washers on each end.
Eagle Posted July 25, 2018 Posted July 25, 2018 2 hours ago, DirtyComanche said: Can you buy new seals for them? I wish I had them on the highway. But I think I'd rather just go to the new style large one piece window. The seal IS the problem. Actually, it's not the seal, it's the overall design. There's a metal frame channel along the bottom edge of the glass. BUT ... the metal channel doesn't run the full length of the bottom edge. Obviously, where the metal stops there's a step to the plane of the glass, and the rubber seal can't close that step effectively. That's where they weep. That's where I packed mine with silicone grease to seal it up. As long as I don't open the window, it's tight. If I were to use the window regularly, I would probably have to reapply the grease every week or two.
Jaketr1 Posted July 25, 2018 Posted July 25, 2018 yea i am having to have new door put on bc of mine leaking all the way down at the bottom of my door, so i will do without them dang vents.
1989commanche Posted August 26, 2020 Posted August 26, 2020 On 7/10/2018 at 10:24 PM, jpdriver1 said: yep --- they can drool in the rain and whistle in the wind I fixed my leak for 20 cents. 2 nickels under each of the latches. No more wind noise or leaks.
cruiser54 Posted August 27, 2020 Posted August 27, 2020 On 7/11/2018 at 7:58 AM, Eagle said: I bought a Cherokee Pioneer new in 1988. The operable vent windows were an extra cost option, which I bought. They leaked. The factory had a "fix" -- replace the operable windows (that I had paid extra for) with fixed glass -- but they wouldn't refund the price of the option. I told the factory rep to pound sand. I smeared the gaskets with silicone grease, closed the vents, and they haven't been opened since. That was 30 years ago. Bottom line -- DON'T DO IT. Absolutely true!!!!! ^^^^^^
