Pete M Posted May 10, 2018 Posted May 10, 2018 so the other day's venture to the junkyards wasn't going well until I stubbled upon a thrashed 85 2door XJ with these near perfect black buckets. yay! when I got home I discovered that only the passenger seat folds forward. and by that, I don't mean the drivers side mechanism is broken, I mean it's non-existent. there's no lever to actuate it, no hinge, no catch. by all other accounts it perfectly matches the pass side. what the hell?! I thought 2door seats all folded forward. is this an early model difference?
Strokermjcomanche Posted May 10, 2018 Posted May 10, 2018 May have been switched at one point in time ...
Jeep Driver Posted May 10, 2018 Posted May 10, 2018 The slide levers look different. Someone swapped, apparently.
Jeep Driver Posted May 10, 2018 Posted May 10, 2018 I've seen the black checkered just like you have without the carpeted back.
Pete M Posted May 10, 2018 Author Posted May 10, 2018 ooops, asked the wrong question. I meant to ask do the 4door XJs have this carpeted panel or is in a 2door thing?
Minuit Posted May 10, 2018 Posted May 10, 2018 I've seen it on a 4dr Limited with leather seats before. On that XJ it had a little storage pocket.
rokinn Posted May 10, 2018 Posted May 10, 2018 I have those exact same seats, carpeted back, only drivers side folds forward, out of an 80's XJ. I think it was a 2 door but I honestly don't remember anymore. They also have the rocker type sliders. Haven't installed them yet. I've got another set (different fabric) that does have the fold forward on passenger side. Going to mix and match till I get what I want. Too many other things to do first. You didn't happen to pick up a set of black arm rests you want to sell me did you?
johnj92131 Posted May 10, 2018 Posted May 10, 2018 29 minutes ago, rokinn said: Going to mix and match till I get what I want. Too many other things to do first I mixed and matched at least 6 pairs of bucket seats before I finally made up a good set. Then I added a storage pocket to the back of each seat.
Pete M Posted May 10, 2018 Author Posted May 10, 2018 48 minutes ago, rokinn said: I have those exact same seats, carpeted back, only drivers side folds forward, out of an 80's XJ. I think it was a 2 door but I honestly don't remember anymore. They also have the rocker type sliders. Haven't installed them yet. I've got another set (different fabric) that does have the fold forward on passenger side. Going to mix and match till I get what I want. Too many other things to do first. You didn't happen to pick up a set of black arm rests you want to sell me did you? they might have been in acceptable shape. so much of the interior was just trashed that I don't remember looking at them specifically. If I get back there I'll check it out.
HOrnbrod Posted May 10, 2018 Posted May 10, 2018 35 minutes ago, johnj92131 said: Then I added a storage pocket to the back of each seat. How did you do that John? Pics?
HOrnbrod Posted May 10, 2018 Posted May 10, 2018 3 minutes ago, Pete M said: are 2door XJ armrests the same as 4door? They be the same.
Eagle Posted May 11, 2018 Posted May 11, 2018 11 hours ago, Pete M said: do all early XJs have this carpeted panel? Only the upscale ones. Judging by the side bolsters, those are from a Laredo or Limited.
rokinn Posted May 11, 2018 Posted May 11, 2018 7 hours ago, Pete M said: they might have been in acceptable shape. so much of the interior was just trashed that I don't remember looking at them specifically. If I get back there I'll check it out. Thanks, much appreciated. Nice to know that the rear arm rests work also but the fronts are much preferred.
schardein Posted May 11, 2018 Posted May 11, 2018 On 5/10/2018 at 12:46 PM, HOrnbrod said: How did you do that John? Pics? This is a removable piece from the back of the seat on very early XJs. Like those pictured by the OP above, except with a pocket built in. This might be what John is referring to.
schardein Posted May 11, 2018 Posted May 11, 2018 11 hours ago, Jeep Driver said: The slide levers look different. Someone swapped, apparently. I suspect those seat bases are a matched pair. Those are the "rocker" type seat bases. See the "paddles" that face inboard? Those control the "rocker" motion. The plastic-tipped round metal rod levers control fore-and-aft.
schardein Posted May 11, 2018 Posted May 11, 2018 My 79 K5 Blazer passenger seat has a lever that allows the entire seat to flip forward for access to the back seat. The driver seat does not. I've never found or noticed this, but I suspect this might be the case for very early 2 dr XJs, based off this post. The idea being that back seat passengers get in the on the passenger side. The early "extra cab" Chevy Silverados only had a door that opened on the pass side from 98-2000. 2001 was the first year for suicide style opening rear doors on both sides.
HOrnbrod Posted May 11, 2018 Posted May 11, 2018 5 minutes ago, schardein said: This is a removable piece from the back of the seat on very early XJs. Like those pictured by the OP above, except with a pocket built in. This might be what John is referring to. Very cool - haven't seen those before. Thanks Greg. Now I have to find a set in gray or black.
schardein Posted May 11, 2018 Posted May 11, 2018 2 minutes ago, saveevryjp1998 said: Has anyone ever seen a bench seat like an mj in an an early xj across the front instead of buckets? I have 3 different times over the past 13 or so years and always wondered if that was actually a factory option. I've never seen one, ever, and I've searched junkyards from Hawaii to Virginia over the last 30 years. Not saying they don't exist, but I've never seen one.
schardein Posted May 11, 2018 Posted May 11, 2018 8 minutes ago, saveevryjp1998 said: Is that back of an 84-86 xj wagoneer? The red one with map pockets? I think that is where I have seen them. My 91 xj limited had these leather ones. The driver seat is electric and the passenger is not. I have seen several that way. That red panel with the pocket came from a 1986 XJ 4 dr Laredo package. I used the seat frames in my XJ because they were the "rocker" type bases like the OPs. I used to own an 89 XJ Wagoneer. Wish I'd kept it. It was power seats, both sides. My experience in looking at a bunch of XJs, is that driver and pass power seats went away with the switch from Renix to HO. HO are only power on the driver side, like your 91.
johnj92131 Posted May 11, 2018 Posted May 11, 2018 On 5/10/2018 at 10:46 AM, HOrnbrod said: How did you do that John? Pics? Don, Just had the upholstery shop take material from the rear of seat backs I was not going to use and make the pockets as in this picture:
HOrnbrod Posted May 11, 2018 Posted May 11, 2018 18 minutes ago, johnj92131 said: Don, Just had the upholstery shop take material from the rear of seat backs I was not going to use and make the pockets as in this picture: Ah, I see. Very cool.
