MeanLemons Posted April 28, 2018 Posted April 28, 2018 Hello y’all. I think I never mentioned it here but I have been boring out throttle bodies (91 and up) for years. To remove the bottle neck at the bottom of the throttle body (60mm). Last night I successfully made a jig to hold the throttle body so I can bore all way through to 62mm. With the new butter fly plate on. $80 shipped for the 60mm throttle body (core fee of $20 included). $120 shipped for the 62mm throttle body (core return of $20 included). i will start taking orders when the first batch of butterfly plates arrive and they all measure & match up to the prototype I have. I havent started doing renix TBs yet because I don’t have a core to play around with.
Pete M Posted May 10, 2018 Posted May 10, 2018 I might be able to help with the renix core. just gotta find time to swap it out.
WahooSteeler Posted May 10, 2018 Posted May 10, 2018 I'd be down for a renix one when you get around to them. I plan on getting a set of battery cables too.
Pete M Posted May 10, 2018 Posted May 10, 2018 2 hours ago, MeanLemons said: That ll be much appreciated! got it! message me an address.
MeanLemons Posted May 10, 2018 Author Posted May 10, 2018 59 minutes ago, Pete M said: got it! message me an address. Responded.
MeanLemons Posted May 10, 2018 Author Posted May 10, 2018 1 hour ago, WahooSteeler said: I'd be down for a renix one when you get around to them. I plan on getting a set of battery cables too. That’s an awesome plan!
88whitemanche Posted May 11, 2018 Posted May 11, 2018 Would definitely like a 2.5 one... ive got a spare in my parts pile if you want to try that out
MeanLemons Posted May 11, 2018 Author Posted May 11, 2018 9 hours ago, 88whitemanche said: Would definitely like a 2.5 one... ive got a spare in my parts pile if you want to try that out Yeah I can try that.
sinkrun Posted May 11, 2018 Posted May 11, 2018 If Petes falls thru I have a RENIX one here for ya try, may also couple newer ones.
TheDude Posted May 13, 2018 Posted May 13, 2018 I grab every throttle body I find so I have probably eight spares at least and know where to get five or so more. We can definitely work out some credit for cores type deal. Sent from my iPhone using Tapatalk
MeanLemons Posted May 13, 2018 Author Posted May 13, 2018 1 hour ago, TheDude said: I grab every throttle body I find so I have probably eight spares at least and know where to get five or so more. We can definitely work out some credit for cores type deal. Sent from my iPhone using Tapatalk That can happen.
MeanLemons Posted May 16, 2018 Author Posted May 16, 2018 I have one for 91-92 4.0L ready to go. (Technically it can also be for 91-95 in XJ/YJ platform & 93-95 ZJ platform).
MeanLemons Posted May 16, 2018 Author Posted May 16, 2018 I’m working on making a jig for the renix TB as we speak.
MeanLemons Posted May 17, 2018 Author Posted May 17, 2018 So I bored it to slightly over 60mm and I guess the wall is too thin. Maybe it’s slightly off center I ll investigate. i managed to finish boring and then grind out the slot on the shaft to accept the bigger plate. ya know those 91+ TBs I have been boring out? The OEM butterfly plates from those fit perfectly. Maybe I should tone it down and bore out to 59.5mm instead and then sand the butterfly plate round the edge.
TheDude Posted May 17, 2018 Posted May 17, 2018 I'm by no means an expert but it looks to be a hair off center to the lower right bolt hole.Let me know if you need another. Sent from my iPhone using Tapatalk
MeanLemons Posted May 17, 2018 Author Posted May 17, 2018 Yeah it need to be moved slightly. I ll definitely need another one.
MeanLemons Posted May 20, 2018 Author Posted May 20, 2018 I got a bunch of 96+ cores and bored them out. so yes they are now available
