I never flat towed my cj7 however I trailered it behind a comanche once. Never again. Trailer and cj outweighed the mj. They just arent heavy enough. Full-size half ton at least.
  • Replies 476
Posted Images
28 minutes ago, Pete M said:
flat towing is nothing like pulling a trailer.  :(
I understand that. I once towed a 92 dodge spirit on a tow dolly from kansas city to fort wayne and it had several sketchy moments involved. That trip made me full aware of the need for a heavier tow rig. Not saying it can't be done, lord knows ive hauled much heavier stuff, just saying a half ton pickup would be much safer/comfortable.
Absolutely! I’m hoping for the best but planning for the worst with this trip.
I'm never trying it again unless the tow rig weighs at least twice the towed rig.
honestly I'd keep the tow bar on and drive the Jeep.  :D  I did 3k miles in my pos to get to moab.  :peep:
Your POS has more leg room than mine! I remember... I drove it! :driving:
I've been scheming a few options:
  1. Renting a truck/trailer is around $1k
  2. Renting a U Haul and a dolly is around $1k
  3. Buying a YJ suspensions and brackets to make it all work is around $1k
  4. Maybe piggyback on a trailer with another rig but it'll definitely be a squeeze for the cost of fuel
  5. Throw together a tow bar for next to nothing and figure it out plus the cost of fuel
The problem with driving it out and back is the ride quality. Right now the tires live at 20# and there's probably more suspension in the sidewalls than there is in the leaf springs on the road. It's not completely horrible... but it's also not something I'd look forward to for 800 miles. Early last week I was ready for a "loose the shop moment" and start ordering parts to redo the whole suspension. Then the realization that should anything get delayed or go wrong that I wouldn't have a Jeep to take to Moab set in. Eventually, I need to address the awful suspension on this thing. Before I spend anything else on it, I should really see how it wheels! I've upgraded the engine (out of necessity), added a limited slip in the rear diff, added a super beefy transmission with a deep first gear, rock sliders, some creature comforts, and yet I've never really wheeled it outside of some basic trails around my place. It might be terrible! I might even hate it! I won't know until after this trip.
Before the trip, the top is coming off to ditch at least 300#. I'm not out anything to hitch it up and see for myself how it pulls. I'll throw the spare for the CJ and the truck in the bed for good measure. Years ago I used to flat tow my '72 Volkswagen all over with my truck or a '95 ZJ with a 4.0. Granted, there's about 1000# difference between the CJ and a Beetle and I completely understand how that affects the driving characteristics of the tow vehicle. Would it be a real super hero move to roll into Moab after driving all the way there?... you bet! Would it also be a super hero move to roll into Moab with my truck towing the CJ?... also yes. :cool:
Flat towing will never be my first choice. People have been flat towing them for years though behind other CJs, station wagons, and other such vehicles that we'd look at as questionable now. So much of it comes down to being smart about it!... even if that means admitting that it just might not work out.
safety aside, it's the constant fighting between the two rigs while moving down the road.  it was never, ever smooth like pulling a trailer.  braking, turning, going perfectly straight down the road.  it just always sucked and made for a mentally draining ride.  :(  but your CJ weighs less, so maybe it'll be better?  I guess it certainly wouldn't hurt to tool around town and find out.  be sure to attempt a few panic stops.  the angle of the tow bar can induce scary weirdness in the tow rig when hard braking occurs, especially if not going perfectly straight at the time.
if you flat tow behind a rented box truck it'll be a bit less cash.  at least that way the tow rig is massive.
I would think this would make it a better daily as well. Though time becomes a problem with this too.
I will echo everyone else though, I wouldn't use the MJ, unfortunately. It would look cool, but I think the MJ is too light, especially in the rear. I don't even like towing 1500lbs in a trailer behind my MJ, I can't imagine double that.
That has been the biggest thing on my list of to-dos on this Jeep. It would’ve been epic to completely blow it apart before heading to Moab, but the delay with Ruff Stuff for my truck brackets was maybe the biggest deterrent. I priced everything this time through Barnes, and my finger was hovering over the “complete purchase” button. Then I thought about it for a day, and now I’m comfortably too late. I’m hoping to find out what I really need and don’t need with this trip.
Moving forward on the CJ to Moab list. Would you believe that all of the tie rod ends are shot?… yup, I wasn’t surprised either. Parts are on order, but I wanted to give it some caster in the front axle also.
I added a 4° shim to the leaf pack because that’s what I had on hand. Ideally, I should be cutting the inner C’s and rotating them back to gain caster and I usually shoot for 6-8°. It’ll be way better than it was on the road. SOMETHING had to be better than the .5° of caster it did have. :idea:
The tow bar got a coat of paint too. I started going through the Jeep and all the stuff that just lives in it. A bunch of it got paired down but I also added some tools for Moab. I’ll get more into creating additional storage for certain things once the top comes off and it’s easier to work in. Probably next weekend? I feel like Moab is creeping up quickly.
it's even worse than you think because a flat tow adds 0 weight to the bumper to help plant the rear tires. :(  and if the bar is at the wrong angle, under heavy braking it can push down on the rear and pick up the front of the tow rig.
In my experience, having the tow bar pointing down slightly helps in an emergency stop. When the tow bar is level or tilted up towards the hitch ball, that’s what adds to lifting the rear of the tow vehicle. While I still haven’t attempted this combination yet, I’m curious how it’ll pull. The times I’ve flat towed vehicles in the past have been lighter vehicles, and so much of a good or bad experience comes down to looking ahead at the trip, knowing your vehicle’s limits, and plain being smart about everything.
More Moab prep today. I was hoping to tug it around with the Eliminator but I ran out of time before the weather started to turn and the power went out. In preparation to match up with the tow bar, I’m trying to get rid of as much wiggle and rattles as possible. That started on the truck side. I added a big set screw on the bottom corner of the receiver to keep the draw bar from knocking around.
It’s just a 1/2” bolt and nut. There’s another nut welded to the receiver. Then the top came off the CJ because it’s always easier to get motivated on CJ projects after the top comes off. :L: Along the way, as things came off that are in the way of getting the top off, they just went in the bed of the truck.
Ballast! :applause:
The steering got all new tie rod ends and the radiator got new hoses. What I found when I was crawling around under the Jeep was a big ol’ crack in the frame behind the front crossmember and the steering box had just a little play at full lock. The play turned out to be the left side frame rail twisting. I didn’t have making a steering box on my bingo card for the day. :fistshake2:
I might readdress this in the future (which means I’ll probably never do anything else with it). It’s made of junk that I had around and I’m not super crazy about the 1/2” heim but it made a huge difference! There’s just a plate on the right frame rail under the winch plate tying it all together.
Then the power went out! The CJ went out and the old rain cover went on. It still needs to be remade since it got hailed on early last year. We might be getting some snow tomorrow so I guess it’s better than nothing.
Maybe I’ll find time for a test tow this coming week.
Test tow day!
… it didn’t go well… but that’s okay! I had high hopes but, in the back of my head, I quietly had my doubts. Around town, things went great! I took it for a drive up to 55mph that went around a bunch of curves and hills. 55-60 felt just about right. The truck did okay as far as temperatures and even power. A little more oomph would be nice. Unfortunately where things just didn’t feel right was in the brakes. We all saw that coming!… again, that’s okay. After a couple practice emergency stops and then one final hard stop going downhill I lost faith in the brakes. They got hot and smelly.
I’m sure I could get some brakes figured, but realistically I’m running out of time. Maybe U Haul is the next move?
Next, I’m looking at storage for important stuff. I’d like to carry some extra fuel, but I’d like to keep everything contained in the Jeep. I’ve got a (probably too big) fuel tank that’s been kicking around the shop for a while. What I like about it is that it fits well and it’s low profile. I welded on a couple tabs at each end and bolted it in after drill yet more holes on the tub… because old Jeep. Next to that is the all important cooler and I snuck a 10# CO2 tank in there too.
There’s more stuff to do yet. The major one is finally adding three point seat belts. I suppose tomorrow I’ll start getting serious about renting a truck to get out there and back.
Ok, I can’t lie, that’s an incredibly beautiful sight there. Now I’m a little disappointed it didn’t work out.
If I had to pick something I don't like about mj's, I would say the towing capabilities are disappointing at best.
That said, it is any incredibly awesome combo. :comanche:
uhaul is a good idea, anything they have should easily do it.  although that $1 per mile is painful :(
Agreed! The payload capacity is excellent, but the towing capacity is very disappointing.
Same. :dry: But… I’m still going. Stay tuned for more beautiful sights from Moab. :L:
14 minutes ago, fiatslug87 said:
That picture makes the CJ look huge!
RIGHT?! Unfortunately the final straw was the mass of the CJ. Everything was stripped off and out of it but it still wasn’t enough. Failure is always an option. :fistshake2:
I believe there are systems that hook up to the line from a trailer brake controller and push a piston to push the brake pedal.  Let the CJ help with braking.
Probably not enough time before EJS and I have no idea how much they cost but it's always an option.
Yup. There’s essentially a tow dolly type surge brake setup that would tie into the front brakes of the CJ. Or the other option is an actuator that pushes the brake pedal. Those are a bit pricey. I briefly looked into them but you said it… time.
More work today. The three point seat belts got installed. These are “Jeep Wrangler” aftermarket but they could really go in just about anything. I had to weld a bung into the main hoop, but otherwise they just bolted in place of where the lap belts were.
Then I moved onto the fuel system. There’s really nothing wrong with it, but the pump has been loud since it went in there. I went back to the parts list from when I pieced together a Howell setup for a friend’s YJ a while back and just used that part number.
The old pump is now the new transfer pump should I need it. It runs off of a remote starter trigger switch.
What I didn’t want to do is plumb in a permanent auxiliary tank. This way I can remove it when I want. Otherwise the punch list is down to trying to get the parking brake working, nut and bolt it, recentering the steering wheel, and check the toe again. This is a huge annoyance.
Unfortunately, my potential trailer spot isn’t going to work out. I reserved a U Haul going there and the return trip, but now I’m about 60% leaning towards keeping the return reservation as a plan c… d?… and just driving it out there.
Decisions… decisions…
Drive it?  Ugh, makes my back hurt just thinking about riding in my cj that long. I havent driven it in several years but from what I recall they arent exactly "road trip friendly".  Would make for a really cool trip......
