88 2.5 runs super rich
Hi all new to the forum hoping to get some help sorry if I posted in wrong section  anyway I have an 88 Comanche 2.5. 4 banger 2wd and its running super rich can't pass emissions I have replaced and tested almost everything I can think of map tps iat o2 replaced cts sensor checked and cleaned all the spark plugs and not a huge change on my emissions test my co2 is allowed 1.20 and I'm at 7.34 way too high the same is for the hydrocarbons I don't know what to do next but need to pass because she's my daily driver any help appreciated thx             Also I have  checked for any vacuum leaks and nothing
No need for this I’m sure but clean the tube between the map and motor to make sure it’s getting a good vacuum signal. Mine was clogged with blowby over the years and cleaning it out cured it. I had fixed the throttle body o-rings on the injector “egg” but still had a bad stutter and raw fuel smell.
If you fill your gas tank to the brim each time then the charcoal canister can be saturated as well. That won’t affect the fuel economy as much as the O-rings but it will mess with CO numbers as well as the fuel saturated engine oil being vaporized and drawn in raw through the CCV tube so it’s not fully burnt by the tailpipe for testing.
My thermostat being too low temp (stuck part way open) threw off my numbers as well because it was stuck in cold mode.
You can actually watch the injector spray.........I doubt it's the injector.
MAP or O2 or coolant temp sensor. It's one or all three that will cause a rich condition.
If you did not replace O2 with NTK, replace again. If you did not replace MAP with GM MAP, replace again.
Clean your C101 or eliminate.
Clean your MAP port and replace line to MAP.
Replace temp sensor in manifold with Mopar.........you can still find those.
As stated, clean all grounds.
When the o-rings on the single injector leak, it still runs but the fuel pours down. It’s originally fed into the Venturi around the injector and that injector just allows fuel into the side and the “valve” inside just opens and closes to work the spray. There is a line in and return line out with pressure regulator.
Edited by carnuck
I understand. I doubt he has a reference as to what a normal spray will look like.
He can spend his $70 here. http://www.fuelinjector.citymaker.com/catalog/item/7638068/9101082.htm
Or, he can do the obvious first.........well..............he's going to do all that anyway.
The Oring kit is easy to install if you have the right touch for removing the 3? screws and not tightening them till they snap on reinstall.
Injector removed
O-rings kit 8005 (use dielectric grease to assemble)
Injector overhaul kit
Hi all sorry it's been awhile holidays and all. But had another question I have the 160 thermostat in my truck and been reading that it is too cold and that maybe that it's stuck in cold mode in open loop would wrong thermostat cause this if so then what is the correct Tstat that I should buy thanks again
I know MotoRad is the supplier for Mopar thermostats, but the parts store MotoRad thermostat I put in my 86 didn't last 6 months until it was stuck open. I suggest paying just a little more for a Mopar thermostat. These seem to be the most reliable. Even available on Amazon.
https://www.amazon.com/gp/aw/d/B00F6E3W8M/
Is stuck open because you got the Fail-Safe which is a No-No never get the failsafe it's the same thermostat you get a Mopar
