Comanche kid520
Everything posted by Comanche kid520
  1. Even though my tranny is only a 4 speed the 5 speed will fit
  2. Ok so my tranny is shot it is a 2wd sorry bout that question will a ax 5 from a 90 fit for my 88 2.5 ???
  3. The countershaft ok how does that work and will a chevy tranny fit for my jeep ??
  4. Hi all back again 😎😎 well when it rains it pours so yesterday driving home from work and went to grab 3 gear and nothing felt like it was in neutral got to a red light and couldn't get it into any gear makes a weird grinding noise somehow got it into 4 th and babied it to gas station even with it idling makes grinding noise even made the noise while being towed behind the truck not sure what it is I replaced the clutch probably year and a half ago I get the feeling that maybe the syncros are bad hope not so any ideas or tips will help a lot...., not really looking forward to pulling the tranny again but it is just nuts and bolts 👍👍 thx all
  5. Hi all sorry it's been awhile holidays and all. But had another question I have the 160 thermostat in my truck and been reading that it is too cold and that maybe that it's stuck in cold mode in open loop would wrong thermostat cause this if so then what is the correct Tstat that I should buy thanks again
  6. Awesome thanks i will definitely take the ground off a clean it will let you know what happenes
  7. I'm sorry for the late reply but what does tbfi mean ?? And cruiser do you mean the ground that is on the back off the block ???
  8. Hi all new to the forum hoping to get some help sorry if I posted in wrong section anyway I have an 88 Comanche 2.5. 4 banger 2wd and its running super rich can't pass emissions I have replaced and tested almost everything I can think of map tps iat o2 replaced cts sensor checked and cleaned all the spark plugs and not a huge change on my emissions test my co2 is allowed 1.20 and I'm at 7.34 way too high the same is for the hydrocarbons I don't know what to do next but need to pass because she's my daily driver any help appreciated thx Also I have checked for any vacuum leaks and nothing
