Front axle cocked over?
Hi guys,
Just put 5.5" RE coils in the front of my MJ this morning, I got it back on the ground and found its cocked over to the drivers side between 1 and 2 inches. Anyone had this problem? I have aftermarket bent LCA'S in it, are they directional/ offset? I can't see any other reason for it. I can try unbolt the sway bar after work, but does anyone have any ideas?
TIA
Drivers side.
Passenger side.
Drivers LCA
Passenger LCA.
Sent from my SM-N900W8 using Tapatalk
If I was to lengthen my existing track bar, what do you think would be the best way to get the final measurement? I'm thinking of cutting, sleeving and welding, so I'm guessing with wheels on the ground, and axle centered under the rig, that would give me the track bar measurement I need?
If you can do this then just order the builder parts and make a proper track bar otherwise Just order one new already made for your application they are not expensive
I chopped the track bar yesterday, it was short by a couple inches. I found 1" black gas pipe makes a tight interference fit over the track bar. My track bar is solid, I've seen other guys modify theirs, and theirs are hollow. Not sure why the difference. I didn't get to finish it, had to get my truck off the hoist to change the shift fork in my sister-in-law's chevy tracker. Will post more pics when it's done.
Rusty's adjustable track bar is hollow tubing. I've lost track of how many I've seen or heard about that failed in any of a number of ways on the trail. The reason for the difference is $$$.
I've seen build threads of guys making their stock bars adjustable, they chop them and tap the tube, and add threaded rod and jam nuts. So I guess some XJ'S / MJ'S might have come with hollow track bars? Mine is solid anyhow.
No, they did not. Factory track bars were all solid. I have owned everything from an '84 XJ (the first year) to a 2001 XJ (the last year). ALL factory track bars were solid.
Some cheaper kits like rough country include instructions for re-drilling the lower tracbar mount to compensate for the lift. I personally would just get an adjustable but maybe someone saved the instructions for how to do that mod instead if you want to go that route
That's only good for up to about a 4-inch lift. Any more than that and you run out of real estate on the bracket.
96f48dcc003d3077e2dfd29973dd557e.jpgc63be1f64e448e7cbec6bbbfe28ece3f.jpgwelded a section of schedule 40 Gas Pipe into my Track Bar. This is how she sits. Haven't driven it yet, so not sure how it steers, probably will put a pitman arm out of a ZJ in it to change the drag link angle, then get an alignment.
Don't drop the pitman arm unless you also drop the frame end of the track bar. To avoid bump steer, the track bar and the drag link need to be at the same angle. Not by looking at it, since the track bar has that big bend in it, but the direct line between the two end fittings of each bar.
