groffman056 Posted December 11, 2015 Share Posted December 11, 2015 will a 1988 cherokee frame fit under a comanche body Link to comment Share on other sites More sharing options...
shelbyluvv Posted December 11, 2015 Share Posted December 11, 2015 They don't have frames Link to comment Share on other sites More sharing options...
Lee21490 Posted December 11, 2015 Share Posted December 11, 2015 Xj is unibody, Has no actual frame. MJ has a uniframe design, Not a compltely true frame.. But still stronger than the XJ's. What are you trying to accomplish? Link to comment Share on other sites More sharing options...
groffman056 Posted December 11, 2015 Author Share Posted December 11, 2015 I'm trying to just change my 88 comanche 2wd to a 4wd Link to comment Share on other sites More sharing options...
dunnc1991 Posted December 11, 2015 Share Posted December 11, 2015 I'm trying to just change my 88 comanche 2wd to a 4wd As stated, XJ's don't have frames. You can swap to 4wd fairly easily using a 4x4 front axle, trans, and t-case from an XJ/MJ. There is a lot of threads and write ups on here to read through. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 11, 2015 Share Posted December 11, 2015 Link to comment Share on other sites More sharing options...
gogmorgo Posted December 11, 2015 Share Posted December 11, 2015 The XJ and MJ were originally designed as 4x4's, and the 2wd's merely deleted the front axle (there's a solid beam in its place, all suspension is the same), driveshaft, and transfer case. It's pretty well a bolt-on swap, although you may find you have to drill and/or tap holes for the tcase shifter. You'll also either have to get your rear driveshaft shortened or find one for an MJ with your wheelbase and drivetrain, but everything else is shared with the XJ. It may be worth finding a complete donor to transfer stuff over from, that way you know you have all the little niggly things. Also, while it's technically possible to convert your 2wd trans to 4x4, you'd pretty much have have to get a 4x4 trans anyhow to get the parts to do it, so just use the 4x4 trans. There are many write-ups. For someone who isn't nervous about a complete frame swap, shouldn't be a difficult task. Link to comment Share on other sites More sharing options...
75sv1 Posted December 11, 2015 Share Posted December 11, 2015 I think the '88 had the BA1/5. I though you could pull the tailcone off the tranny, and saw off the extended shaft. Then bolt on a TC. I didn't go that route as I wanted a stronger Trans, NV3550. Link to comment Share on other sites More sharing options...
yellaheep Posted December 11, 2015 Share Posted December 11, 2015 I think the '88 had the BA1/5. I though you could pull the tailcone off the tranny, and saw off the extended shaft. Then bolt on a TC. I didn't go that route as I wanted a stronger Trans, NV3550. LOL. Um no. Link to comment Share on other sites More sharing options...
PEEJ Posted December 11, 2015 Share Posted December 11, 2015 75sv1 Is right.If he you happen to have the BA-10/5 you can convert it as described above.You don't even have to pull the tranny to do it.Just done this to my truck a couple months ago.But you will have to find a 4wd. tailhousing to put in the place of the 2wd. tailhousing.Also you,ll need to remove the speedometer gear off the tailshaft It's all easy. Link to comment Share on other sites More sharing options...
Pete M Posted December 12, 2015 Share Posted December 12, 2015 and after all that you'll still have a ba-10/5. gag. Link to comment Share on other sites More sharing options...
terrawombat Posted December 12, 2015 Share Posted December 12, 2015 Just saw the BA-10/5 in half. Best solution. Link to comment Share on other sites More sharing options...
jpdriver1 Posted December 14, 2015 Share Posted December 14, 2015 Just saw the BA-10/5 in half. Best solution. They make pretty good boat anchors :rotf: Link to comment Share on other sites More sharing options...
Blue88Comanche Posted December 14, 2015 Share Posted December 14, 2015 thats awesome, and saved for later :cheers: Link to comment Share on other sites More sharing options...
