neohic Posted November 26, 2014 Share Posted November 26, 2014 I went looking around for pictures on how to take apart a fuse block (box?) and came up with a bunch of information on how to do it... but we all love pictures so I wasn't satisfied with what I was coming up with. Fuse block front: Fuse block bare chassis: Back of fuse block: Back of bulkhead connection showing the elusive 8mm head (however apparently sometimes 7mm, 6mm, or 1/4") bolt: Here's the extraction tool I made using a piece of stainless TIG filler. It's roughly 1/4" from tip to tip and I tapered the ends so it would fit nicely around the female fuse terminals: Shown in fuse block: The extraction tool fits snugly vertically above and below where the fuse would seat into. Keep pushing it in until the wire starts to slide out the back. When the terminal comes lose, it simply pulls out the remainder of the way. Terminal: The two angles "wings" on the terminal is what is being pushed together by the extraction tool. Before putting the terminal back in, it;s a good time to tighten up the fuse seat. Gently bend the "wings" out so the terminal stays tight when inserted back into the block. Link to comment Share on other sites More sharing options...
Nobles41 Posted November 26, 2014 Share Posted November 26, 2014 Thanks for the write-up and pics. I'm assuming the Renix era XJ and MJ fuse blocks are the same. Correct me if I'm wrong. I tried to extract a fuse block from a late 80's Cherokee but with no luck. I didn't see that bolt in the middle. Maybe next time I'm at the salvage yard I 'll grab it. Thanks again. Link to comment Share on other sites More sharing options...
Keyav8r Posted November 27, 2014 Share Posted November 27, 2014 Thanks for the how-to with photos. Always wondered how to get those terminals out. I don't currently have any issues with my fuse block (knock on wood), but it's good to know how to do it if I ever need to. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 27, 2014 Share Posted November 27, 2014 Ben, I've never had to do this but it's good to know. Will the below work as replacement terminals? The factory p/n for these is J3231223. http://www.delcity.net/store/1!way-Fuse-Block-Terminal/p_11128 Link to comment Share on other sites More sharing options...
Mountain Dude Posted November 28, 2014 Share Posted November 28, 2014 I rebuilt the fuse block of my '88 with parts from a 1st generation S-10 / S-15 fuse block. They are exactly the same. Even the ganged buss bars have the same pitch as the Jeep one so you can change the power supply side terminals too. Link to comment Share on other sites More sharing options...
neohic Posted November 28, 2014 Author Share Posted November 28, 2014 On 11/27/2014 at 5:58 PM, hornbrod said: Ben, I've never had to do this but it's good to know. Will the below work as replacement terminals? The factory p/n for these is J3231223. http://www.delcity.net/store/1!way-Fuse-Block-Terminal/p_11128 Looks like it. If I had to replace a fuse block and clean up wires, I'd probably go that route and get new terminals instead of cutting, splicing, and soldering everything. Link to comment Share on other sites More sharing options...
xjrev10 Posted December 2, 2014 Share Posted December 2, 2014 Completed the fuse box swap... Thanks Ben. Technically the box itself is fine, it's just plastic. The connectors, I totally different story. I ended up cutting and soldering on different connectors for a few of them. (Connectors that came with the fuse box I got from Ben) Exactly what I didn't want to do. Anybody doing this swap, be sure to get a fistful of new connectors. Should note that soldering is not required with new parts. I had used parts so I soldered the wires together instead of tearing the connectors off and trying to recycle them. You need a few 4 ways, a few 3 ways, a few 2 ways and of course single connectors. It's fairly easy, just stay organized and do one at a time, marking the hole in on the new one immediately after removing the wire from the old box. Make sure the orientation is correct also with the 2, 3, and 4 way connectors.. I used a small screwdriver out of a eyeglass repair kit. WARNING: The screwdriver works fantastic for nice connectors. It will destroy not so nice ones. Hence why I needed to replace more then I thought.. Here is a link again for the correct connectors. For the 3 way and 2 way, you could get a 4-way and just cut it down. http://www.delcity.net/store/Fuse-Block-Terminals/p_177 I took some pictures but photobucket isn't cooperating right now... Also I learned there is really no need to replace the whole box if you have a issue with just one connector. Buy a new one and install.. But it is pretty nice to be able to transfer your newly rebuilt wires into a new clean box. I was able it sit on a spare tire/wheel on the floor beside the jeep and work in the floorboard. No need to do a hand stand under the dash. You may need to cut the loom a little bit. Took me a few hours with only one beer break. My soldering tool is also a POS which added more time.. Link to comment Share on other sites More sharing options...
Gubachoo Posted October 22, 2016 Share Posted October 22, 2016 I recently redid all the terminals in my fuse block using these terminals. I ordered a whole bunch plus a handful of the bussed ones too. I left it in the truck and just spend about two hours in an awkward position. Bent and ground a paperclip to remove the terminals. if you have a good quality set of terminal pliers (preferably the ratcheting type, not the standard part store stripper/crimper) then no solder is needed. I ended up doing everyone over since most needed it and I didn't want to have to do it again. At the same time I picked up a bunch of other stuff from Delcity to upgrade my battery cables. Bought some 1ga at the parts store and the rest from them. They have these neat little solder pellets (https://www.delcity.net/store/Terminal-Solder-Slugs/p_1036) that you just drop in the terminals, heat up to the correct point, and push the cables in. When done well I was super happy with the seal (after ruining the first one learning the correct amount of heat and time.) I also grabbed two of these guys (https://www.delcity.net/store/Anti!Rotational-In!Line-Battery-Terminals/p_1016) and put them in-line from the battery. The negative I cleaned at spot, drilled a hole, and put a 3/8 bolt with a washer right to the fender well to improve my grounding and allow it to continue on to the block (which I then cleaned and did all the stuff cruiser recommended.) I bought an isolated single post for the positive (https://www.delcity.net/store/Junction-Blocks/p_801581) so I could get rid of the double wire terminal off the battery. I mounted it to the fender well also and made a short cable from it to the distribution solenoid thingy (still not 100% what that thing is and I'm a mechanic, so you'd think I would know by now...) out of the same cable and ends to ensure no loss of power to the rest of the truck. Overall the del city stuff cost me about 80 shipped (including way more terminals than I needed plus a few extra end terminals and solder plugs to be safe) and the big battery cable cost me about 40 for seven or so feet of each pos and neg. I still have a foot or two of each for any future stuff it may be needed for. It took probably two hours to make the cables (if you use the solder plugs you need some sort of torch, I used oxy/ac but map gas or propane would work as well according to the site) including putting some nice shrink-wrap on them and the R&R. I still want to upgrade the grounds in other spots but I am super happy with how this all went. It started from lightly flickering interior lights that stemmed from weak and broken fuse contacts (about half of them ended up breaking when I removed them from the block and just wiggled them, bad news) and the sight of breaks and cracks in my positive battery cable. I recorded it turning over on my phone with the coil disconnected before and after and it turns about 15-20% faster now and no more flickering anything. Thanks for whoever figured out these terminals were the right ones as I was unsure about what to do with this whole mess before I found this post. Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 16, 2020 Share Posted April 16, 2020 I really really don't want to revive an old thread but I couldn't help but notice that no specific tool is listed for the DIY. I just replaced one of the multi terminals last night in my block and ran into an issue with crimping on the wire. Does any one know of a specific tool for these multi terminals? The FSM has nothing listed on the subject. Link to comment Share on other sites More sharing options...
Minuit Posted April 16, 2020 Share Posted April 16, 2020 A standard open barrel crimper will do an OK job on the Pack-Con terminals. I don't know how to do the bus bars - my guess is you'd have to either find the OEM crimper for those or bend them out of the way for clearance on the ones you aren't crimping. Link to comment Share on other sites More sharing options...
Rad_Comanche Posted February 26, 2021 Share Posted February 26, 2021 On 4/16/2020 at 9:06 PM, eaglescout526 said: I really really don't want to revive an old thread but I couldn't help but notice that no specific tool is listed for the DIY. I just replaced one of the multi terminals last night in my block and ran into an issue with crimping on the wire. Does any one know of a specific tool for these multi terminals? The FSM has nothing listed on the subject. Expand Those terminals have the same crimping ends as the pins I used in my Deutsche DT connector. I used the crimper linked below, which has multiple gauge sizes, and two different size "seal" crimp holes to crimp the larger wings that hole the terminal to the insulation. https://www.amazon.com/dp/B081381N72 Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27, 2021 Share Posted February 27, 2021 On 2/26/2021 at 9:52 PM, Rad_Comanche said: Those terminals have the same crimping ends as the pins I used in my Deutsche DT connector. I used the crimper linked below, which has multiple gauge sizes, and two different size "seal" crimp holes to crimp the larger wings that hole the terminal to the insulation. https://www.amazon.com/dp/B081381N72 Expand Right but I ran into this issue except instead of two, it was four across. So I am not sure if that crimper is up to the task. Link to comment Share on other sites More sharing options...
Rad_Comanche Posted February 27, 2021 Share Posted February 27, 2021 On 2/27/2021 at 4:30 AM, eaglescout526 said: Right but I ran into this issue except instead of two, it was four across. So I am not sure if that crimper is up to the task. Expand Ohhhh, that is a good point. The jaws might have trouble with those. You know what? I already have the crimper, and I need to put new terminals in my fuse box anyway. I will buy some terminals and find out if they play nice together. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 27, 2021 Share Posted February 27, 2021 On 2/27/2021 at 3:54 PM, Rad_Comanche said: Ohhhh, that is a good point. The jaws might have trouble with those. You know what? I already have the crimper, and I need to put new terminals in my fuse box anyway. I will buy some terminals and find out if they play nice together. Expand That would be awesome as it seems standard and the barrel crimpers I got will only probably reach to about the second one in a row of four. That being said the power wire could go to one of the end terminals now that I think about it. Link to comment Share on other sites More sharing options...
schardein Posted February 28, 2021 Share Posted February 28, 2021 This little guy can be helpful in getting the terminals out. https://www.rockauto.com/en/parts/lisle,56500,battery+terminal+disconnect,1000860 Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 18, 2021 Share Posted April 18, 2021 good info. nice write up. Link to comment Share on other sites More sharing options...
captnphilgood Posted January 11, 2024 Share Posted January 11, 2024 Yeah just did an upgrade on the wiper motor and assembly and fried out the wires going to the 40 amp fuse I need to know what that goes to anybody out there know , show pictures if possible. I have a 88' Comanche 4 liter I6. Link to comment Share on other sites More sharing options...
devotee Posted March 23 Share Posted March 23 Great thread. Thanks to those who came before. I'm about waist deep into fuse clip replacement currently (electric pun). Link to comment Share on other sites More sharing options...
