MJam86 Posted January 6, 2014 Posted January 6, 2014 I have an 88 with the 4.0. Anyone ever have an issue with their throttle linkage? This part is the one that is attached to like a 1/4 L shaped rod. I'm looking to see if anyone has a fix for this issue, I have some ideas but it'd be easier to have something that i know works.
Jeep Driver Posted January 6, 2014 Posted January 6, 2014 You can simply replace your throttle cable........or......... go high tech. http://www.kartek.com/Product/72/Cable-Morse-Ball-Joint-End.aspx Use pliers to crush and destroy existing plastic end or cut off....assuming you have enough threaded adjustment for length in the cable at the cable mount. Silver solder or epoxy new end on. These ends may be available at hobby shops that specialize in 1/4 scale RC......or look to web........or look to lawn tractor shops such as Cub Cadet, these are used for trans and throttle links. May have to drill out the threads on the joint to get a slip fit over your existing cable rod. There are other rod ends but you may have to remove your TB to get that pressed in ball cut off and drilled out to replace the ball end.
MJam86 Posted January 7, 2014 Author Posted January 7, 2014 You can simply replace your throttle cable........or......... go high tech. http://www.kartek.com/Product/72/Cable-Morse-Ball-Joint-End.aspx Use pliers to crush and destroy existing plastic end or cut off....assuming you have enough threaded adjustment for length in the cable at the cable mount. Silver solder or epoxy new end on. These ends may be available at hobby shops that specialize in 1/4 scale RC......or look to web........or look to lawn tractor shops such as Cub Cadet, these are used for trans and throttle links. May have to drill out the threads on the joint to get a slip fit over your existing cable rod. There are other rod ends but you may have to remove your TB to get that pressed in ball cut off and drilled out to replace the ball end. Its not the cable part.
MJam86 Posted January 7, 2014 Author Posted January 7, 2014 Junkyard. This is what I am thinking, among other things. I just didn't know if anyone had any other ideas in case I can't find anything.
Jeep Driver Posted January 7, 2014 Posted January 7, 2014 You can simply replace your throttle cable........or......... go high tech. http://www.kartek.com/Product/72/Cable-Morse-Ball-Joint-End.aspx Use pliers to crush and destroy existing plastic end or cut off....assuming you have enough threaded adjustment for length in the cable at the cable mount. Silver solder or epoxy new end on. These ends may be available at hobby shops that specialize in 1/4 scale RC......or look to web........or look to lawn tractor shops such as Cub Cadet, these are used for trans and throttle links. May have to drill out the threads on the joint to get a slip fit over your existing cable rod. There are other rod ends but you may have to remove your TB to get that pressed in ball cut off and drilled out to replace the ball end. Its not the cable part. What did I miss here? Confused.
MJam86 Posted January 7, 2014 Author Posted January 7, 2014 Picture is sideways sorry. Most people think that the transmission line pressure cable is actually the throttle linkage. After reading your post a few times that's what it sounded like to me, my apologies if I am wrong. I actually found the party I need at least I think I did. http://www.moparpartsoverstock.com/showAssembly.aspx?ukey_assembly=866560&ukey_product=6845431 It took quite a bit of searching as everything I searched actually came up with the transmission cable. I'll update this one I get the actual part in the mail.
HOrnbrod Posted January 9, 2014 Posted January 9, 2014 The part number for the 88 pedal is 53005315. I've sent you a PM where that part is available. 53005315 ACCELERATOR PEDAL LINK U53005185 1987-90 JEEP 1 634 15.00
MJam86 Posted January 11, 2014 Author Posted January 11, 2014 I found the part number thanks for the PM. I have yet to call and find out if they actually have the part. Thanks!
MJam86 Posted January 14, 2014 Author Posted January 14, 2014 Ok so here is my fix!<br />Take the rod drill a hole, then thread in the small eye hook things, bend it out so it can wrap around the ball on the throttle body and foot pedal assembly, then finally clamp it down tight. So my fix was under $1. Hope this helps someone else in the future.
MJam86 Posted January 14, 2014 Author Posted January 14, 2014 Ok so here is my fix! Take the rod drill a hole, then thread in the small eye hook things, bend it out so it can wrap around the ball on the throttle body and foot pedal assembly, then finally clamp it down tight. So my fix was under $1. Hope this helps someone else in the future.
Eagle Posted January 14, 2014 Posted January 14, 2014 I have an 88 with the 4.0. Anyone ever have an issue with their throttle linkage? This part is the one that is attached to like a 1/4 L shaped rod. I'm looking to see if anyone has a fix for this issue, I have some ideas but it'd be easier to have something that i know works. What's the issue? I see a photo with no explanation of what problem it's supposed to be showing. The lower end of that arm goes to a bellcrank on the frame rail. That bellcrank pivot gets rusted up or gooked up and doesn't rotate freeley. That's the most common problem with the Renix throttle linkage, and the cure is usually to shoot it with PB Blaster and work it manually until it rotates freely.
yxmj Posted January 14, 2014 Posted January 14, 2014 Ok so here is my fix!<br />Take the rod drill a hole, then thread in the small eye hook things, bend it out so it can wrap around the ball on the throttle body and foot pedal assembly, then finally clamp it down tight. So my fix was under $1. Hope this helps someone else in the future. Nice cheap fix.....could use it to get the truck heading down the road......keep your eyes open, now that you have a threaded opening you might come across the correct ball cap connector that can also be threaded into place. :thumbsup:
Jeep Driver Posted January 14, 2014 Posted January 14, 2014 Posted Today, 06:09 AM MJam86, on 06 Jan 2014 - 04:05, said: I have an 88 with the 4.0. Anyone ever have an issue with their throttle linkage? This part is the one that is attached to like a 1/4 L shaped rod. I'm looking to see if anyone has a fix for this issue, I have some ideas but it'd be easier to have something that i know works. What's the issue? I see a photo with no explanation of what problem it's supposed to be showing. The lower end of that arm goes to a bellcrank on the frame rail. That bellcrank pivot gets rusted up or gooked up and doesn't rotate freeley. That's the most common problem with the Renix throttle linkage, and the cure is usually to shoot it with PB Blaster and work it manually until it rotates freely. His plastic ball end no longer stayed on the ball. Ball ends are not free, ingenuity is even more expensive, I suppose. :idea:
MJam86 Posted January 14, 2014 Author Posted January 14, 2014 I have an 88 with the 4.0. Anyone ever have an issue with their throttle linkage? This part is the one that is attached to like a 1/4 L shaped rod. I'm looking to see if anyone has a fix for this issue, I have some ideas but it'd be easier to have something that i know works.<br /><br />What's the issue? I see a photo with no explanation of what problem it's supposed to be showing.<br /><br />The plastic clip is broke. There is a plastic piece at the end of the rod that clips onto the ball at each end of the rod.
MJam86 Posted June 4, 2014 Author Posted June 4, 2014 The part number for the 88 pedal is 53005315. I've sent you a PM where that part is available. 53005315 ACCELERATOR PEDAL LINK U53005185 1987-90 JEEP 1 634 15.00 I got a PM from someone asking me about this thread. I wanted to put out the info that they have discontinued that part as well so this link didn't work either.
Kheltic Posted December 22, 2020 Posted December 22, 2020 On 1/6/2014 at 4:00 AM, MJam86 said: I have an 88 with the 4.0. Anyone ever have an issue with their throttle linkage? This part is the one that is attached to like a 1/4 L shaped rod. I'm looking to see if anyone has a fix for this issue, I have some ideas but it'd be easier to have something that i know works. http://img.tapatalk.com/d/14/01/06/7y6a3ehe.jpghttp://img.tapatalk.com/d/14/01/06/5u7uhare.jpg I have the exact same problem and I'm curious if you ever found that part? I need Item #5 in this picture.
Eagle Posted December 22, 2020 Posted December 22, 2020 https://www.amazon.com/Ball-Socket-Universal-Joints/b?node=16411991 Not sure what size might fit
cruiser54 Posted December 22, 2020 Posted December 22, 2020 I might have a handful of those linkage pieces in the shed.
Kheltic Posted December 22, 2020 Posted December 22, 2020 5 hours ago, cruiser54 said: I might have a handful of those linkage pieces in the shed. Let me know if you're willing to part with one if you're able to dig it up.
Kheltic Posted December 22, 2020 Posted December 22, 2020 On 12/22/2020 at 12:23 AM, Eagle said: https://www.amazon.com/Ball-Socket-Universal-Joints/b?node=16411991 Not sure what size might fit Thanks man, it led me to this part. I think this might work, it looks almost identical to the piece that's not staying connected. Not sure if it's a 10mm ball head though. I'm going to see if I can figure out the spec.
87MJTIM Posted December 22, 2020 Posted December 22, 2020 3 minutes ago, fiatslug87 said: What else is in your cart??? A baker's dozen.
