KSjeepguy88 Posted November 19, 2013 Share Posted November 19, 2013 I work at a local auto parts store, I was looking through our system and found a bigger filter that fits the 4.0ls Stock filter: wix 51626 New filter : wix 51182 They both have... 21 micron rating M20x1.50 thread 2.462" gasket inside diameter. 3.663" bottom outside diameter The ONLY difference is the "51182" is 5.207" tall and the stock "51626" is 3.812" tall Hope this helps someone someday... Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 19, 2013 Share Posted November 19, 2013 That's only for Renix oil filters - the thread on the HOs is SAE, not metric. Here's the list for the HO oversized filters: Oversize Oil Filters for HO 4.0L Engines (3/4"x16 thread)5.178" HIGH, 3.660" DIAMETERAC-Delco PF2, $6.28Motorcraft FL-1A, $6.49Purolator L30001, $5.76Napa 1515, $6.69Wix 51515, $6.69Mopar L-72 L-326, L-526, L-55, L-1007, L-138Baldwin B118, $9.26Hastings LF115, $8.73Mobil 1 M1-301, $8.00Amsoil EaO15, $18.75Donaldson P550008, $4.216.93" HIGH, 3.660" DIAMETERAC-Delco PF42Motorcraft FL299Purolator L40017Napa 1773Wix 51773Mopar L-526 Link to comment Share on other sites More sharing options...
Eagle Posted November 19, 2013 Share Posted November 19, 2013 In choosing any alternate filter for the Jeep engines, be sure the substitute has an anti-drainback valve. Link to comment Share on other sites More sharing options...
Oyaji Posted November 19, 2013 Share Posted November 19, 2013 Good info. I always like using a taller filter on any vehicle that has room for it. There are a couple advantages: more filter element means not only greater filtration capacity, but also less oil pressure drop; and the taller filter is easier to change next time around because it's easier to get ahold of. :) Link to comment Share on other sites More sharing options...
Tactical Bacon Posted November 19, 2013 Share Posted November 19, 2013 I can attest to Purolator, Napa/Wix, K&N, and Mobil 1 using silicone anti-drainback valves in their filters. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 19, 2013 Share Posted November 19, 2013 In choosing any alternate filter for the Jeep engines, be sure the substitute has an anti-drainback valve. Of course. Link to comment Share on other sites More sharing options...
GirsMJ86 Posted November 19, 2013 Share Posted November 19, 2013 Dang, wish I had know about this. Just got myself a new WIX 51626, guess I'll make note for next time. Link to comment Share on other sites More sharing options...
Rockfrog Posted November 19, 2013 Share Posted November 19, 2013 I swapped my Renix nipple for an HO nipple so now I just use the Ford FL-1A's or Purolator L30001 in my 88 MJ and in my '00 XJ ... I can find that style of filter just about anywhere. Link to comment Share on other sites More sharing options...
jimoshel Posted November 19, 2013 Share Posted November 19, 2013 I just use a modified coffee can with a roll of toilet paper in it. Link to comment Share on other sites More sharing options...
Oyaji Posted November 19, 2013 Share Posted November 19, 2013 I just use a modified coffee can with a roll of toilet paper in it. Toilet paper filters do exist, being a canister (like your "modified coffee can") and a roll inserted for the filter element. IIRC, they filter down to 5 microns, too, making them better in that respect than store-bought filters. Also IIRC, they are a by-pass type filter, meaning they don't filter all the oil volume coming from the oil pump, just some percentage of it. They did use to have the reputation of keeping engine oil super clean. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 19, 2013 Share Posted November 19, 2013 Link to comment Share on other sites More sharing options...
jimoshel Posted November 19, 2013 Share Posted November 19, 2013 I worked the wheat harvest in Kansas when I was a kid. Seems most of the farmers used them on most of their equipment. A roll of toilet paper was a standard item along with a monkee wrench, pair of pliers and a hank of baling wire.in the tool box Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted November 19, 2013 Share Posted November 19, 2013 That's only for Renix oil filters - the thread on the HOs is SAE, not metric. Here's the list for the HO oversized filters: Oversize Oil Filters for HO 4.0L Engines (3/4"x16 thread) 5.178" HIGH, 3.660" DIAMETER AC-Delco PF2, $6.28 Motorcraft FL-1A, $6.49 Purolator L30001, $5.76 Napa 1515, $6.69 Wix 51515, $6.69 Mopar L-72 L-326, L-526, L-55, L-1007, L-138 Baldwin B118, $9.26 Hastings LF115, $8.73 Mobil 1 M1-301, $8.00 Amsoil EaO15, $18.75 Donaldson P550008, $4.21 6.93" HIGH, 3.660" DIAMETER AC-Delco PF42 Motorcraft FL299 Purolator L40017 Napa 1773 Wix 51773 Mopar L-526 Will any of these oversize filters work on a 2.5, or is there another list? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 19, 2013 Share Posted November 19, 2013 That's only for Renix oil filters - the thread on the HOs is SAE, not metric. Here's the list for the HO oversized filters: Oversize Oil Filters for HO 4.0L Engines (3/4"x16 thread) 5.178" HIGH, 3.660" DIAMETER AC-Delco PF2, $6.28 Motorcraft FL-1A, $6.49 Purolator L30001, $5.76 Napa 1515, $6.69 Wix 51515, $6.69 Mopar L-72 L-326, L-526, L-55, L-1007, L-138 Baldwin B118, $9.26 Hastings LF115, $8.73 Mobil 1 M1-301, $8.00 Amsoil EaO15, $18.75 Donaldson P550008, $4.21 6.93" HIGH, 3.660" DIAMETER AC-Delco PF42 Motorcraft FL299 Purolator L40017 Napa 1773 Wix 51773 Mopar L-526 Will any of these oversize filters work on a 2.5, or is there another list? The 91-92 2.5L filter threads are the same as on the 4.0L, but whether or not there is enough physical room for a larger filter I don't know. Link to comment Share on other sites More sharing options...
rmoore1031 Posted March 3, 2016 Share Posted March 3, 2016 Purolator 3001 is now $2 at Wal-Mart here. Gonna stock up soon. Link to comment Share on other sites More sharing options...
75sv1 Posted March 3, 2016 Share Posted March 3, 2016 NAPA had/has a sale going on. I wanted their Platinum series for synthetic. 41515 (same size as the 1515). They don't have one for the 1773 size. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 3, 2016 Share Posted March 3, 2016 This opens up a new world in oil filters for your Renix. http://cruiser54.com/?p=257 Link to comment Share on other sites More sharing options...
mikekaz1 Posted March 3, 2016 Share Posted March 3, 2016 That's only for Renix oil filters - the thread on the HOs is SAE, not metric. Here's the list for the HO oversized filters: Oversize Oil Filters for HO 4.0L Engines (3/4"x16 thread) 5.178" HIGH, 3.660" DIAMETER AC-Delco PF2, $6.28 Motorcraft FL-1A, $6.49 Purolator L30001, $5.76 Napa 1515, $6.69 Wix 51515, $6.69 Mopar L-72 L-326, L-526, L-55, L-1007, L-138 Baldwin B118, $9.26 Hastings LF115, $8.73 Mobil 1 M1-301, $8.00 Amsoil EaO15, $18.75 Donaldson P550008, $4.21 6.93" HIGH, 3.660" DIAMETER AC-Delco PF42 Motorcraft FL299 Purolator L40017 Napa 1773 Wix 51773 Mopar L-526 curious Ive always used a Purolator 14670.... on all my jeeps Link to comment Share on other sites More sharing options...
