Everything posted by KSjeepguy88
88 Comanche Project Dd
KSjeepguy88 replied to KSjeepguy88's topic in Member Projects: Your Comanches
I sold the 2014 rubicon wheel. And got my new raceline 81 17x9.5 beadlocks put on the Comanche today. It's looking good nice!!!- 28 replies
- Daily driver
- clean
(and 1 more)
Tagged with:
Got my dirty30 built and installed over the last 2 weeks!- 28 replies
- Daily driver
- clean
(and 1 more)
Tagged with:
Ok. I lost track on this build... I now have everything on my MJ 6.5" iron rock off-road from coils. Rough country Long Arms. JCR 1-ton OTK steering. Ford 8.8. With 4:10s LSD, IRO 8.8 swap kit/truss, solid diff cover. BillStein 5100 series shocks. IRO trac bar. 2" coil front spacer (to make it level) 2014 rubicon wheels (17") 285/75R17 treadwright guard dog tires 5on4.5 to 5on5 wheel adapters Big thank you to @ramblinringo for helping me do all the work on my comanche.- 28 replies
- Daily driver
- clean
(and 1 more)
Tagged with:
On my 88 MJ 4.0l, my idle is very high and I can't find out why... I've cleaned the Throttle body and IACV, replaced some vacuum lines and adjusted the TPS... I don't know what else to do to see if I can get the idle lower, but to replace the IACV. Thanks for the input
Mine is the 4.0l auto with NP231
My drivers side mount was in 2 peaces. The passenger side mount on my truck was all one peace but it was dry cracked and old.
I work at a local auto parts store, I was looking through our system and found a bigger filter that fits the 4.0ls Stock filter: wix 51626 New filter : wix 51182 They both have... 21 micron rating M20x1.50 thread 2.462" gasket inside diameter. 3.663" bottom outside diameter The ONLY difference is the "51182" is 5.207" tall and the stock "51626" is 3.812" tall Hope this helps someone someday...
If the CPS was bad it would not start at all! It would not send a signal to the ECM telling where the crank is at in its rotation, check all your vacuum lines and maybe your idle air control valve
Cb Radio And Antenna?
KSjeepguy88 replied to redwolf624's topic in MJ Tech: Modification and Repairs
This is where I mounted my CB on the back of my center console -
What Brand Of Lift Is This?
KSjeepguy88 replied to KSjeepguy88's topic in MJ Tech: Modification and Repairs
I'll keep that in mind. Thanks guys! -
I'm going to go look at it in person Friday morning, I hope I can use the track bar and brace, and the rear shackles -
Yea I know he got the lift from a friend and he blew the motor in his XJ before he could get the lift on it -
I found a guy on Craigslist that's selling this 6" lift off an XJ and I can't find out what brand it is. Any help?
Here is where I mounted mine, under the tool box used firestik mount and antenna. Out the CB radio on the bad side on my center consul -
Me and @RamblinRingo are just finishing up prepping our MJ's for Sunday!!! You all better be there! find us and say hello too
Tires in the bed... Just wish they were on the axles!!!! I'm going to do a SOA swap on the rear and 6.5" coils, and long arms in the front. Should sit very close to level, I hope to have it all on and done by the first of the new year!- 28 replies
- Daily driver
- clean
(and 1 more)
Tagged with:
This is what my drivers side motor mount looked like when I took it out, Got the new ploy inserts in and no more sound!
Got my tires mounted on my 2013 JK wheels today! Now to get this 2" boost on for the time being...- 28 replies
- Daily driver
- clean
(and 1 more)
Tagged with:
Got my new motor mounts, now I just need to get them in
285/75R17S On A 2" Spacer Lift?
I already have 5on4.5 to 5on5 lug adapters I plan to do a SOA in the rear and 6.5" springs up front so sounds like I'm going to just wait a month or 2 and get all my lift ready then put it all on. Thanks for the input -
So I have 2" spacers and a rear add-a-leaf sitting in my garage but do you think some 285/75R17s on 2013 wrangler sport wheels will fit on my MJ with the 2" quick boost? Just want my MJ on some tires now!!!
It's back on for the 3rd of November.
It's working great! Hahahaha- 28 replies
- Daily driver
- clean
(and 1 more)
Tagged with:
