onlyinajeep726 Posted February 13, 2014 Share Posted February 13, 2014 Well that sucks... lol. Perhaps being an '86 has something to do with it? All I know is that it's a 16 gal and it was on the truck when I bought it... Couldn't tell ya if they swapped it in at some point or if it was factory. Wasn't a bit rusty though after 28 years, so I dunno. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 13, 2014 Share Posted February 13, 2014 It's factory. The LWB MJs could be had w. 16 gal tanks through 1990. In 1991 the 16 gal tanks went away and 18 gal tanks replaced them. Link to comment Share on other sites More sharing options...
92tanMJ Posted February 13, 2014 Share Posted February 13, 2014 On 2/13/2014 at 7:05 PM, hornbrod said: Thanks Alex - looks like I'll have to pass - it would be difficult for me and require exhaust work. It looks like those shocks are over 4" in diameter, si?. I can measure mine tomorrow afternoon if you would like me too? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 13, 2014 Share Posted February 13, 2014 On 2/13/2014 at 11:08 PM, Zack said: I can measure mine tomorrow afternoon if you would like me too? That would be great if you could - thanks. Link to comment Share on other sites More sharing options...
54bobby Posted February 13, 2014 Share Posted February 13, 2014 mines an 87 w/ 16 gal tank and I'm curious about the Monroe fitment too. Link to comment Share on other sites More sharing options...
92tanMJ Posted February 14, 2014 Share Posted February 14, 2014 On 2/13/2014 at 11:32 PM, hornbrod said: On 2/13/2014 at 11:08 PM, Zack said: I can measure mine tomorrow afternoon if you would like me too? That would be great if you could - thanks. No problem. If I get out of class early I will measure them before work and post back around noon, otherwise it'll be after 4 pm central time lol Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted February 14, 2014 Share Posted February 14, 2014 I just took a quick glance under my 16 gal equipped LWB and with standard diameter shocks, there's about an inch and a half of wiggle room between the bent flange of the tank and the shock... I think it will hit with the fatter Load Levelers. Link to comment Share on other sites More sharing options...
Incommando Posted February 15, 2014 Share Posted February 15, 2014 I noticed that these are being mentioned for use with a lift and also an SOA in one case. Lifts and larger tires often mean off-roading. Shocks of this nature usually do not help off-road and often effect flex. Just a heads up. Link to comment Share on other sites More sharing options...
92tanMJ Posted February 15, 2014 Share Posted February 15, 2014 On 2/13/2014 at 11:32 PM, hornbrod said: On 2/13/2014 at 11:08 PM, Zack said: I can measure mine tomorrow afternoon if you would like me too? That would be great if you could - thanks. Don, it rained all days yesterday and is currently raining... I'll measure when it's decently dried up. Sorry for the delay Link to comment Share on other sites More sharing options...
Roost426 Posted February 16, 2014 Share Posted February 16, 2014 I just installed the normal sensatracs on the back, do we use the metal spacer/washer on the top shock mount at all? It seems one side had it on mine and the other did not, So I have them both on right now without the washer. Link to comment Share on other sites More sharing options...
92tanMJ Posted February 16, 2014 Share Posted February 16, 2014 On 2/16/2014 at 1:19 AM, Roost426 said: I just installed the normal sensatracs on the back, do we use the metal spacer/washer on the top shock mount at all? It seems one side had it on mine and the other did not, So I have them both on right now without the washer. I thought the metal washer was supposed to stop the nut from digging into the rub bushing :dunno: I used mine Link to comment Share on other sites More sharing options...
92tanMJ Posted February 17, 2014 Share Posted February 17, 2014 On 2/13/2014 at 11:32 PM, hornbrod said: On 2/13/2014 at 11:08 PM, Zack said: I can measure mine tomorrow afternoon if you would like me too? That would be great if you could - thanks. I just measured mine, its 3.25" but the amazon says 3.6" so maybe I ordered the wrong ones? :dunno: Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 18, 2014 Share Posted February 18, 2014 Thanks. I think I see an easy way to make these fit on my LWB.............. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted September 27, 2014 Share Posted September 27, 2014 Is this shock still available? I read ever pg of this thread and never came across a clear p# or link to look up. I would imagine these shocks in combination with metric ton springs and a LWB truck would be a pretty awesome hauling combination. Link to comment Share on other sites More sharing options...
neohic Posted September 27, 2014 Share Posted September 27, 2014 On 4/23/2013 at 1:28 AM, airspeed said: The Monroe p/n is 58497. From page 1. :thumbsup: Link to comment Share on other sites More sharing options...
Minuit Posted September 27, 2014 Share Posted September 27, 2014 I've had these shocks (as well as regular SensaTracs for the front) for a few months now, and I'm quite happy still. I've hauled several pretty heavy loads and never has the truck gone below level. They seem to have slightly raised the rear when unloaded as well. Link to comment Share on other sites More sharing options...
BIGHEEP Posted September 27, 2014 Share Posted September 27, 2014 If anyone is looking to put these on a lifted vehicle here is the link to the shock lengths. The shocks you want are in the 585xx-586xx ish part numbers. http://www.monroe.com/assets/downloads/english/MonroeMountingLengthSpecifications.pdf Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted September 28, 2014 Share Posted September 28, 2014 On 9/27/2014 at 6:54 PM, neohic said: On 4/23/2013 at 1:28 AM, airspeed said: The Monroe p/n is 58497. From page 1. :thumbsup: Thanks my man. Anything in particular i should put up front to complement them? Link to comment Share on other sites More sharing options...
neohic Posted September 28, 2014 Share Posted September 28, 2014 I was planning on using the load levelers and Sensa Tracs up front. Didn't work out with the levers on my LWB so I went with the Sensa Tracs all around. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted September 29, 2014 Share Posted September 29, 2014 On 9/28/2014 at 3:16 PM, neohic said: I was planning on using the load levers and Sensa Tracs up front. Didn't work out with the levers on my LWB so I went with the Sensa Tracs all around. Levers? :hmm: Link to comment Share on other sites More sharing options...
neohic Posted September 29, 2014 Share Posted September 29, 2014 On 9/29/2014 at 2:06 AM, ftpiercecracker1 said: On 9/28/2014 at 3:16 PM, neohic said: I was planning on using the load LEVELERS and Sensa Tracs up front. Didn't work out with the levers on my LWB so I went with the Sensa Tracs all around. Levers? :hmm: Fixed... levelers. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted October 1, 2014 Share Posted October 1, 2014 Just ordered. Had to re-read the final checkout price a dozen times. $70 bucks for a pair of new shocks seems way cheap, but who's complaining? For comparison local orielly's is charging 100 a piece. Now to order a pair of the Sensa Tracs. :brows: Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted November 11, 2015 Share Posted November 11, 2015 This thread hasn't been updated in over a year, but they're available on Amazon, with Prime for less than $70/pair. http://www.amazon.com/Monroe-58497-Sensa-Trac-Adjusting-Absorber/dp/B0012X238G/ref=sr_1_1?ie=UTF8&qid=1447270483&sr=8-1&keywords=monroe+58497 Link to comment Share on other sites More sharing options...
mikekaz1 Posted November 24, 2015 Share Posted November 24, 2015 any one have any experience with these and metric ton springs? Link to comment Share on other sites More sharing options...
Megadan Posted November 24, 2015 Share Posted November 24, 2015 My interest is peaked, but I would love to hear someone who has put some miles on them. I have a mild dislike of most monroe shocks as they seem to wear out quickly. How are these holding up? Link to comment Share on other sites More sharing options...
