Automan2164 Posted October 1, 2012 Share Posted October 1, 2012 That time again!Beginning of the month time again. You know what that means. Time for a new highlight. Kick back and enjoy this member's fine pair. GJEEP's '89/'92 COMANCHE SporTruck duo MODEL AND YEAR '89 MJ SporTruck (shortbed) a.k.a "Stinky" '92 MJ SporTruck (shortbed) a.k.a "Son of Stink" ENGINE & PERFORMANCE: '89 MJ...Hesco Stroker w/ aluminum head (coming soon; all performance goodies bought and paid for waiting on the motor), complete '91 MJ High-Output wiring conversion, Borla header, Hesco 62mm bored throttle body, aFe Power Stage 2 CX pro cold air intake system, Hesco hi-flow fuel pressure regulator, Bosch gray 4-hole 19 lb fuel injector, MagnaFlow catalytic converter & muffler '92 MJ...K&N filter, Borla header, MagnaFlow catalytic converter & muffler, Hesco 62mm bored throttle body DRIVETRAIN: '89 MJ...NOS AX-15 teammed to NP-242 transfer case w/ D30/ D44 4.11 gears; Hurst Billet/Plus short shifter, Novak transfer case shifter bracket/ cable kit, Brown Dog engine block brackets & motor mounts '92 MJ...AX-15 teammed to NP-231 transfer case (truck converted to 4wd recently) w/ D30/ D35 3.55 gears; Hurst Billet/Plus short shifter, Novak transfer case shifter bracket/ cable kit COOLING: '89 MJ...Griffin all aluminum 2-row radiator, SPAL programmable electric fan controller, Turbo City hi-flow thermostat housing, Hesco high-flow water pump, electric fan override switch '92 MJ...Modine heavy-duty radiator, electric fan override switch ELECTRICAL & IGNITION: '89 MJ...IPF H4 headlight wiring upgrade, Jeepers & Creepers heavy-duty battery cables, Mean Green heavy-duty 200 amp alternator, Mean Green gear reduction starter '92 MJ...factory stuff for now STEERING: '89 MJ...ZJ quick ratio steering box, T&T Customs heavy-duty track bar frame mount, Old Man Emu steering stabilizer, Steadfast Security steering column collar '92 MJ...'96 XJ steering box, ZJ OEM tie rod & tie rod ends, Steadfast Security steering column collar SUSPENSION: '89 MJ...Tomken 4" sway bar mounts, JKS adjustable track bar (for 1”-3.5” lift), Old Man Emu Nitrocharger shock absorbers, M.O.R.E 3/4" coil spring spacer, Old Man Emu 3" coil springs, JKS adjustable upper & lower control arms, '96+ XJ D30 heavy duty axle shafts w/Spicer 297X u-joints, NOS Metric Ton rear leaf springs '92 MJ...Truck converted to 4wd recently w/ new OEM hubs, ball joints, '96+ XJ D30 heavy duty axle shafts w/Spicer 297X u-joints, NOS heavy duty XJ Up-Country coil springs, new OEM uppser & lower control arms, track bar, new repro rear leaf springs, Tokico Trek Master shocks INTERIOR: '89 MJ...'97+ XJ full window upgrade while maintaining old-style door panels, OEM converted power windows w/ Beijing XJ regulators (uses factory regulator mounting holes of original door w/ newer glass), door locks & mirrors, XJ center console emergency brake, CR Laurence 3-panel power-slider deep tinted rear window, Second Skin Audio door sound matting, Dynamat 1/2" foam matting for cab, Infinity Reference Series 5.25 & 4x6 speakers, Mopar aftermarket AM/FM CD player, ACC carpet kit, bucket seats & center console, XJ modified overhead console '92 MJ...OEM converted power windows w/ Electric-Life regulators, door locks & miroors, CR Laurence 4-panel deep tinted rear window, Second Skin Audio door sound matting,Infinity Reference Series 5.25 & 4x6 speakers, Alpine head unit, ACC carpet kit, re-upholstered bench seat, XJ modified 'shortie' over head console (just the temp module) BRAKES: '89 MJ...Dual diaphragm brake booster & master cylinder upgrade, PowerStop cross-drilled rotors (front & rear) w/ Extreme Truck semi metallic brake pads, TeraFlex rear disc brake kit for D44 '92 MJ...Dual diaphragm brake booster & master cylinder upgrade, PowerStop cross-drilled rotors (front) w/ Extreme Truck semi metallic brake pads LIGHTING: '89 MJ...DesighTech 50W halogen back-up bulb, OEM cargo lamp, NOS Marchal driving lights '92 MJ...DesighTech 50W halogen back-up bulb, NOS driving lights WHEELS/TIRES: '89 MJ...SpiderTrax wheel spacers for rear axle, BF Goodrich A/T 31x9.50R15 (coming soon) w/ either NOS TJ Canyon or Moab rims '92 MJ...SpiderTrax wheel spacers for rear axle, Good Year Wrangler 235/70R15 tires w/ TJ Canyon rims MISCELLANEOUS: '89 MJ...NOS front & rear bumpers (I think to be powder coated metallic silver), grille & power mirrors, factory skid plates (front & fuel tank), T&T Customs heavy-duty bellypan skid plate & NP-242 transfer case skid plate, Draw-Tite Class III Maxi-Frame Receiver Hitch, power tailgate lock, factory over-rail bedliner, DEI Viper alarm, 97+ XJ windshield washer reservoir, paint & body work all done by me (after getting certified), entire chassis, interior tub & bed Herculine'd '92 MJ...NOS chrome front & rear bumper, grille & power mirrors, factory skid plates (front, transfer case & fuel tank), Draw-Tite Class III Maxi-Frame Receiver Hitch, factory over-rail bedliner, DEI Viper alarm, SnugTop camper shell w/ deep tinted windows, '01 XJ narrowed roof rack & first-generation Dodge Dakota high mount stop light, custom bed mounted bench seat, seat belts & side consoles for 4 & 6 year old daughters Best MJ story '89 MJ...Intentionally proposed to my wife (12 years ago) in this MJ knowing that in the future-- no matter how much I spent on it-- she will never ask me to sell it! '92 MJ...Seeing it for sale on the internet; hauling @$$ north 3 hrs to buy it, and learning it was a 1 owner, Jeep dealer service manager owned vehicle pampered its entire life. What owner loves best about CC The fact it's all Comanche-- with owners across the nation buying/ building/ sharing their trucks with others on the forum. I've seem some creative, highly detail-driven stuff done with your MJ's and I look forward to seeing more of it. How the '89 MJ looked a few months after I bought it (yes, that's my @$$) It's was together once back in 2003...then I decided to tear it apart and upgrade to ('91 MJ) High Output wiring/ Stroker conversion Stripped the chassis/ underside down then applied 3 heavy coats of Herculiner CR Laurence Power Slider nifty-ness. Wish I bought more than one of these 10 years ago. '89 MJ is getting there SLOWLY but surely. Time to throw-down for the engine. --------------------------------------------------------------------------------------------------------- How the '92 MJ looked when I bought it. Rear bumper was mildly bent on the driver's side but other than that the truck was straight. '92 MJ interior when purchased...It had been converted to XJ buckets & center console... ...and I converted it back to a bench seat & mini console. '92 MJ 4wd conversion shot - with the exception of the D30 all parts are OEM new & creak-free so far. '92 MJ exterior recent shot (prior to chrome mirrors & 4wd conversion) --------------------------------------------------------------------------------------------------------------------- Beautiful. Gjeep, both MJ's are an absolute testament to your detail. That '89 will be one of the best built mild rigs on the road. The tasteful touches with the new full window doors and old door panels shows a great desire to keep the originality of the truck, but improve upon the inner workings. The '92 looks to be a great drive, and clean enough to eat off to boot. The mini overhead console is a great addition, and looks like it should have been there from factory. 2 great trucks, one great member. Enjoy the spotlight. :cheers: Rob Click here to view the article Link to comment Share on other sites More sharing options...
fiatslug87 Posted October 1, 2012 Share Posted October 1, 2012 Beautiful MJs G!! I would love to see the '89 once complete. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 1, 2012 Share Posted October 1, 2012 I've had the pleasure of knowing the G-man for a few years now via the forum. I thought I was a nit-pickin SOB, but this guy is off the charts. :yes: "Better than new" is often used by used car salesmen and other idiots, but in this case it's pure fact for both of these rigs. The man knows his MJ stuff and it shows, clearly. Enjoy the Hesco in the 89 G. :cheers: Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 1, 2012 Share Posted October 1, 2012 2 Beautiful Trucks for sure. :thumbsup: Link to comment Share on other sites More sharing options...
huricane4 Posted October 1, 2012 Share Posted October 1, 2012 Mmmmmmm that sliver truck is awsome Link to comment Share on other sites More sharing options...
Minuit Posted October 1, 2012 Share Posted October 1, 2012 Absolutely stunning work! Both of those trucks are beautiful in every way I can possibly think of. :drool: Link to comment Share on other sites More sharing options...
86customanche Posted October 1, 2012 Share Posted October 1, 2012 very beautiful indeed. Congrats! Link to comment Share on other sites More sharing options...
500 MJ Posted October 6, 2012 Share Posted October 6, 2012 Well deserved, two great examples of clean MJs! Link to comment Share on other sites More sharing options...
87Warrior Posted October 6, 2012 Share Posted October 6, 2012 Spectacular trucks. Absolutely beautiful. Congrats on the MJOTM! Link to comment Share on other sites More sharing options...
Comanche County Posted October 9, 2012 Share Posted October 9, 2012 They're so clean! Tasteful and beautiful! Link to comment Share on other sites More sharing options...
Dadinator Posted October 10, 2012 Share Posted October 10, 2012 Nice trucks. Link to comment Share on other sites More sharing options...
knever3 Posted October 11, 2012 Share Posted October 11, 2012 Wow, awesome specs and parts list. Money well spent love the trucks. Link to comment Share on other sites More sharing options...
JeepnDale Posted October 12, 2012 Share Posted October 12, 2012 Wow. Detailed well beyond most. Hats off to GJeep. Link to comment Share on other sites More sharing options...
vaquaro Posted November 1, 2012 Share Posted November 1, 2012 That's a winning pair for sure :thumbsup: Link to comment Share on other sites More sharing options...
