Alexia Posted October 22, 2012 Author Share Posted October 22, 2012 Very nice! I thought about doing something like this a while back with the bed, but decided against it due to time and money constraints. Might do it when I fix the floors though... The kit is about $100. However, you pretty much can not use the surface spray for about three weeks otherwise it will possibly tear or flatten the area. As well, it has to avoid getting wet. Link to comment Share on other sites More sharing options...
Alexia Posted October 27, 2012 Author Share Posted October 27, 2012 I have a cleaned, machined, and prepared engine block back. I am working on the head right now and wish I had dug into it sooner. The exhaust valves are pitted from oil leaking through the valve stem seals. Link to comment Share on other sites More sharing options...
Alexia Posted October 27, 2012 Author Share Posted October 27, 2012 If you are swapping to a double diaphram brake booster the junction, left, and right hard lines come to about $20 at the dealership. Much cheaper than buying and making your own. Right Front Hard Line Left Front Hard Line - Some brake fluid dripped on to the fender and down on to the frame. It messed up the recently applied under coating. :( Link to comment Share on other sites More sharing options...
Alexia Posted October 28, 2012 Author Share Posted October 28, 2012 Even after lapping this intake valve continues to fail. Link to comment Share on other sites More sharing options...
Backdraft Posted October 28, 2012 Share Posted October 28, 2012 Even with the setback from the valve, you truck is coming along great! Thanks for the inspiration to get back to work on my project. Link to comment Share on other sites More sharing options...
Alexia Posted October 31, 2012 Author Share Posted October 31, 2012 Even with the setback from the valve, you truck is coming along great! Thanks for the inspiration to get back to work on my project. Thank you and you are welcome! I am going to simply purchase an already ported cylinder head with oversize valves. Much easier than getting this cylinder head fixed. Link to comment Share on other sites More sharing options...
88Pghcomanche Posted November 4, 2012 Share Posted November 4, 2012 Nice pics. Sent you a PM. Link to comment Share on other sites More sharing options...
Alexia Posted November 7, 2012 Author Share Posted November 7, 2012 Alright, having trouble concentrating on work today. I picked up new cooling parts today.(Thermostat housing, thermostat, water pump tube.) The remanufactured cylinder head arrives today along with the Bosch 27#~ fuel injectors and a M90 supercharger. I will have to post some pictures later! Link to comment Share on other sites More sharing options...
RockinMJ Posted November 7, 2012 Share Posted November 7, 2012 Supercharger ? I like. Link to comment Share on other sites More sharing options...
Alexia Posted November 7, 2012 Author Share Posted November 7, 2012 Supercharger ? I like. Yep! 4.7L Supercharger Stroker - I'm going for crazy. The cylinder head arrived, but the injectors were delayed until tomorrow. Link to comment Share on other sites More sharing options...
Rymanrph Posted November 8, 2012 Share Posted November 8, 2012 4.7L Supercharger Stroker - I'm going for crazy. Jealous. Can you build two and donate one? Link to comment Share on other sites More sharing options...
Alexia Posted November 9, 2012 Author Share Posted November 9, 2012 Jealous. Can you build two and donate one? >_> Um! That would be an expensive donation! XD I do have to rebuild the drive train on the LJ after the MJ. So... I don't know! That is going to hopefully be a drop in premade stroker. USPS is taking three days to deliver a package from Atlanta, GA to Huntsville, AL.(About a four hour drive.) So I am still waiting on that to arrive before I take pictures. Link to comment Share on other sites More sharing options...
Alexia Posted November 11, 2012 Author Share Posted November 11, 2012 Q: What's up with the nasty engine block mount brackets? A: Waiting for Black Friday sales to purchase heavy duty brackets. This may look like a mess, but I routed all these specifically make them hold each other in place. Valve setup is not finished. Awaiting the arrival of correct length push rods. The remanufactured cylinder head had 0.02" removed to level it so the valve preload is out of specification. Link to comment Share on other sites More sharing options...
COFFMAN Posted November 12, 2012 Share Posted November 12, 2012 Nice work, did you think about useing roller rockers Link to comment Share on other sites More sharing options...
Alexia Posted November 12, 2012 Author Share Posted November 12, 2012 Nice work, did you think about useing roller rockers Thanks! $500+ for roller rockers is just not worth it. $24 for new push rods is worth it however. :D I spent four hours trying to get the damn transmission to line up and slip on. I still have it unmated and hanging there. :/ Link to comment Share on other sites More sharing options...
MancheKid86 Posted November 12, 2012 Share Posted November 12, 2012 Looking good sir, Watch out for your sparkplug wires tho, If you have a break in your shielded insulation on the wwires, It will cause it to find the easiest path to grond, which may be another spark plug, Other than that great work, and amazing detail Link to comment Share on other sites More sharing options...
Alexia Posted November 12, 2012 Author Share Posted November 12, 2012 Looking good sir, Watch out for your sparkplug wires tho, If you have a break in your shielded insulation on the wwires, It will cause it to find the easiest path to grond, which may be another spark plug, Other than that great work, and amazing detail They are all brand new so hopefully that never happens until many years in the future. :D The little plastic spark plug wire guides were broken and I gave up trying to figure out how there were supposed to run originally so I redid it with my knowledge of computer case wiring. Link to comment Share on other sites More sharing options...
Alexia Posted November 15, 2012 Author Share Posted November 15, 2012 Proper length push rods, exhaust manifold, catalytic converter, and a couple things I broke are ordered. Most should arrive tomorrow so I can HOPEFULLY do the engine installation this weekend. Link to comment Share on other sites More sharing options...
tmanhollister Posted November 15, 2012 Share Posted November 15, 2012 :popcorn: Link to comment Share on other sites More sharing options...
Alexia Posted November 17, 2012 Author Share Posted November 17, 2012 THE ENGINE IS INSTALLED! WHOOOOOOO! *Dies* Link to comment Share on other sites More sharing options...
88swampedmj Posted November 17, 2012 Share Posted November 17, 2012 I haven't been on the site in a few years, but I'm happy to come back and see such a great build going on! What color do you plan on painting the truck after the build is done? Link to comment Share on other sites More sharing options...
Alexia Posted November 17, 2012 Author Share Posted November 17, 2012 I haven't been on the site in a few years, but I'm happy to come back and see such a great build going on! What color do you plan on painting the truck after the build is done? Welcome back to the site! I am torn between a few colors right now. Once I get the tires and rims mounted I can get a better idea of what will go together nicely. Link to comment Share on other sites More sharing options...
Alexia Posted November 25, 2012 Author Share Posted November 25, 2012 How to make a 1999+ lock cylinder fit in 1997-1998 ignitions. New 9.547" push rods installed. This was a pain getting it to measure correctly. Lots of accessories, vacuum lines, and other bits installed. Cleaned, sanded, cleaned, and pied valve cover. Gloss black valve cover - Normally my policy is to paint the valve cover green on any engine I work on. This will be an exception to keep the color scheme. Link to comment Share on other sites More sharing options...
Alexia Posted November 26, 2012 Author Share Posted November 26, 2012 IT LIVES! (Mostly) Link to comment Share on other sites More sharing options...
RockinMJ Posted November 26, 2012 Share Posted November 26, 2012 Awesome work Alex. You do clean work. I know your excited. When do you think you will be able to drive? Link to comment Share on other sites More sharing options...
