Hey y'all, I'm about to go change the oil in my 90 MJ (4.0 straight 6). I've done an oil change on a 97 3.0L V6 Grand Am before (my only other car), but that's about it with my experience in working on cars. I'm pretty sure the oil is put down the hole on the top of the engine block of the straight 6, but I just wanted to check before I do anything stupid. Sorry for the ridiculous question, but hey, you gotta learn sometime.
Yepper, twist off cap on valve cover. Need a pic, I'll get you one asap.
Only dumb question is the one you don't ask, or something like that.
Thanks a ton. I don't think I need a picture, since that's pretty much the only cap on there as far as I know, but hey, if you have one I'll check it out haha...
Also be sure you get the correct oil filter. The 1990 was the last year they used the filter with the metric thread. The newer filter will go on, but it may leak or it may actually blow off.
Alright, one last issue... The damn oil filter doesn't want to come off. I even tried using one of those rubber jar top openers, but to no avail. Any suggestions? :headpop:
Thanks again for y'alls help!
punch a skrewdriver through it. apply twist. Or get a pair of mech's gloves or dish gloves.. you know the yellow ones that people put on then grab your head with? yeah. they'll take a OF out lickety split
I would use the screwdriver as a last resort. It makes the rig undriveable if it still won't come off. :(
Oh you can drive it, it just won't run very long, and things will be really messy afterwards.
Thanks fellas. I tried the screw driver suggestion (my roommate told me about it earlier today) to no avail. Couldn't get to the filter at a good angle. I'll be going up to Autozone tomorrow to pick up a filter wrench, if they don't loan them out.
Thanks again guys!
Quick update - I bought the breaker bar, and a strap wrench... Neither of them did the trick. Ended up calling AAA and having them tow it up to a shop by me. The AAA guys even tried getting the damn thing off, but it wouldn't budge.
Thanks again for your help fellas. At least now I have the proper tools to get the thing off next time.
maybe they crossthreaded the wrong one on there... don't remember if your year was metric or SAE?
I've done the metric on the standard thing (I think that's the way it went, an 87 truck with a 93 engine, meaning an 87 oil filter purchased accidently would go that way? or the other way round?)
Anyway the filter screwed up and would "pop" off the threads everytime I tried to tighten it the last bit. I was sure I'd stripped something (and the oil filter threads looked fine) until I remembered the engine was years away.
I don't know that doing the opposite thing (newer oil filter, older engine) would actually go on. Chances are it's just really gorilla'd on there and you haven't gotten a grip on it yet.
Also, buy the right sized metal strap oil filter wrench. I've got rubber straps and some that look like a big C that's meant to open a jar and neither of those work for cr*p.
It could have been overtorqued, or maybe it has been on there for a while (a loooong while). Glad you got it off.
You shouldn't have to touch those tools you bought ever again, tho. Regular service oil changes (3-5K miles) will keep the filter from becoming one with the adapter, and don't overtighten the new filters as you put them on. Spin them down until snug, then another 1/4 to 1/2 turn does it. Don't forget to wipe some clean oil around the gasket when you put the new filter on also. I llike to write the mileage on the filter body with a sharpie when I install it to know when to change it (unless you keep a log or similar).
Oil changes are cheap, engines aren't ;)
Jeff
