MjPioneer Posted October 18, 2010 Share Posted October 18, 2010 On my 89 I went with the Soa and corresponding coils because I wanted to be as big as possible (Hey we're all young once right?) I'm trying to stay away from gigantic on my 87. I've been looking for a lift but not finding anything to impressive for our Mj's. So far I have found Rustys, Rough Country, and Rubicon Express make lifts for us but they all appear to be basic BB. Rustys does offer full packs but after my last set of Rustys packs I will be staying away from them. I want to build this truck more long the low center of gravity lines so I don't want to go about 3.5". What are some suggestions you guys have? Quote Link to comment Share on other sites More sharing options...
88pioneer Posted October 18, 2010 Share Posted October 18, 2010 http://hellcreeksuspensions.com/ And you get a CC discount Quote Link to comment Share on other sites More sharing options...
ComancheKid45 Posted October 18, 2010 Share Posted October 18, 2010 Yep Hell Creek is your best bet. its alot of Rough Country Components with his own Leaf packs for the rear :thumbsup: Quote Link to comment Share on other sites More sharing options...
Incommando Posted October 19, 2010 Share Posted October 19, 2010 And great customer service.... Quote Link to comment Share on other sites More sharing options...
xjrev10 Posted October 19, 2010 Share Posted October 19, 2010 I'm interested in Hell Creek Suspension. Can someone give me the lowdown on Rough Country products? I have heard that they are not of the highest quality comparing to Rubicon Express, TNT, etc. Quote Link to comment Share on other sites More sharing options...
Pete M Posted October 19, 2010 Share Posted October 19, 2010 they are a good middle of the road lift kit. :thumbsup: you can buy the leaf packs separately if you want a high-end lift for the front. Quote Link to comment Share on other sites More sharing options...
FireFighter32 Posted October 19, 2010 Share Posted October 19, 2010 How many inches of lift are usually gained from a spring over rear axle? 3.5 - 4.5??? Quote Link to comment Share on other sites More sharing options...
mvusse Posted October 19, 2010 Share Posted October 19, 2010 Depending on what perches you use usually 5"-5.5". Most people pair SOA with 6.5" front lift for a level truck (no rake). Quote Link to comment Share on other sites More sharing options...
codymanche Posted October 19, 2010 Share Posted October 19, 2010 is the kit from hell creek bolt or weld? Quote Link to comment Share on other sites More sharing options...
Pete M Posted October 20, 2010 Share Posted October 20, 2010 their spring-under lifts are bolt-on. if any are spring-over, then that would need perches welded on. Quote Link to comment Share on other sites More sharing options...
Geonovast Posted October 20, 2010 Share Posted October 20, 2010 is the kit from hell creek bolt or weld? Avoid bolt-on SOA kits. Quote Link to comment Share on other sites More sharing options...
codymanche Posted October 20, 2010 Share Posted October 20, 2010 and why is that? i wanna keep the rear end that i have i been told its a 44 with limited slip and i don't wanna cut or mess something up if i don't have too such as a weld Quote Link to comment Share on other sites More sharing options...
88pioneer Posted October 20, 2010 Share Posted October 20, 2010 perches are simple. grind off the old weld new on. nothing much to screw up there. Quote Link to comment Share on other sites More sharing options...
mvusse Posted October 21, 2010 Share Posted October 21, 2010 You don't even have to remove the old perches. Just weld new ones on on the opposite side of the tube, leaving the old ones in place. Quote Link to comment Share on other sites More sharing options...
codymanche Posted October 21, 2010 Share Posted October 21, 2010 but why not bolt on Quote Link to comment Share on other sites More sharing options...
mnkyboy Posted October 21, 2010 Share Posted October 21, 2010 Bolt in SOA works just fine, the downside is they cost more and they usually retain the stock shock mount so you don't gain quite as much ground clearance. Quote Link to comment Share on other sites More sharing options...
codymanche Posted October 21, 2010 Share Posted October 21, 2010 well would it be good for jeepspeed I'm not really looking to climb Quote Link to comment Share on other sites More sharing options...
mnkyboy Posted October 21, 2010 Share Posted October 21, 2010 I don't know the rules for jeep speed but I would imagine it would be fine. I have the RRO bolt on kit on my truck and I've never had an issue with it, I have it bolted to my d35 but I plan to weld it on once I upgrade the rear axle. Quote Link to comment Share on other sites More sharing options...
88pioneer Posted October 21, 2010 Share Posted October 21, 2010 I don't know about you, but I don't wanna have the only thing holding my axle on to be something bolted on. The perches could slip or a bolt could break, an there goes the axle Quote Link to comment Share on other sites More sharing options...
mnkyboy Posted October 21, 2010 Share Posted October 21, 2010 I'm gonna guess you have never seen a bolt in SOA. The perch isn't slipping because its keyed into the factory perch and the 4 large bolts holding each one on make the tiny u-bolts under your axle look silly. The axles not going anywhere. Quote Link to comment Share on other sites More sharing options...
codymanche Posted October 21, 2010 Share Posted October 21, 2010 i know basics of jeepspeed but that one i don't know all i know is they have to be stock engine and axle wise i believe don't qoute me on it but u can lift and wheel travel is limited to 15-17 inches in the rear and 15 in front i believe. cuz if i where to get it i was thinking rocky road and the lift they have for 600 Quote Link to comment Share on other sites More sharing options...
Pete M Posted October 22, 2010 Share Posted October 22, 2010 if you want to jeepspeed, don't go get the cheapest lift you can find. Quote Link to comment Share on other sites More sharing options...
mnkyboy Posted October 22, 2010 Share Posted October 22, 2010 That's the lift I started with,my truck went down the road but I don't think I would have raced with it as is. It was a good starting point but as my MJ evolves it has less and less of the RRO kit on it. If you want to save money I would suggest doing your homework and piecing a kit together. Quote Link to comment Share on other sites More sharing options...
knever3 Posted October 22, 2010 Share Posted October 22, 2010 These guys make kits for our trucks too! I bought their Stainless Steel 3" lift shocks and they make a few kits, check them out!! http://bds-suspension.com/product-display?ma=7&mo=33&yr=1989 Quote Link to comment Share on other sites More sharing options...
codymanche Posted October 22, 2010 Share Posted October 22, 2010 I'm on a budget too so i mean I'm not going to be in the desert everyday for awhile. but i know i want a lift tho Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
