CEThomas Posted October 31, 2006 Author Share Posted October 31, 2006 Well I could all the numbers, but I did a tooth count and I have a 3.55. Is that a good ratio for a 2.5 with 31" tires ro should I look for a 4.10? Local yard has a 3.55 front axle out of an XJ for $80 and a rear 3.55 axle out of a 95 Explorer for $100. Charles Link to comment Share on other sites More sharing options...
CEThomas Posted October 31, 2006 Author Share Posted October 31, 2006 Well I have started a photo album of the project. Here is thephoto link below. Link to comment Share on other sites More sharing options...
JOMJ87 Posted October 31, 2006 Share Posted October 31, 2006 I had 31s and 3.55s and it wasnt much worse than my 35s and 4.10s so you should be ok but if you go with a ax-5 you will not see overdrive to much but PLAN for LATER cause you know once you start you can't stop. Its kinda like crack. Cole Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 31, 2006 Share Posted October 31, 2006 I'd give it a shot, just as it's cheap. At least, in comparison to running another gear ratio. That said, I've found the 2.5L to be gutless beyond belief in all of my experience with it. Long as you don't care about 1/4 mile times or plan to do any hardcore offroading it should be liveable though. Link to comment Share on other sites More sharing options...
Pete M Posted October 31, 2006 Share Posted October 31, 2006 2.5L + 4 speed stick = 3.55 gears and the trans is an AX-4 or the rarer T-4 2.5L + 5 speed stick = 4.10 gears and the trans is an AX-5 or the rarer T-5 2.5L + 4speed auto = 4.56 gears and the trans is an AW-4 2.5L + 3speed auto = ??? gears and the trans is a 999 or 904 or something like that. It only happened in 86 MJ and 84-86 XJs. There is no such thing as 3.73 gears in an MJ unless someone can prove me wrong. If you want 31s, then I would seek out 4.10 geared axles. Link to comment Share on other sites More sharing options...
500 MJ Posted October 31, 2006 Share Posted October 31, 2006 That looks just like mine when I got it Link to comment Share on other sites More sharing options...
CEThomas Posted October 31, 2006 Author Share Posted October 31, 2006 This thing came with a bed full of trash and a funk smell inside that has not went away yet ;) But it did not cost me anything :cheers: Yet :cry: Charles Link to comment Share on other sites More sharing options...
JOMJ87 Posted November 1, 2006 Share Posted November 1, 2006 This thing came with a bed full of trash and a funk smell inside that has not went away yet ;) But it did not cost me anything :cheers: Yet :cry: Charles Oh it will and this smiley should be cash not paper :papers: you will be empty pocketed before you turn around. Cole Link to comment Share on other sites More sharing options...
CEThomas Posted November 21, 2006 Author Share Posted November 21, 2006 Got some more work done on the front to open up the front wheels. Got to do some work on the 6.2 in my truck this week but going to put in the new axle on the front this weekend if time will allow. The cut made. Link to comment Share on other sites More sharing options...
CEThomas Posted December 11, 2006 Author Share Posted December 11, 2006 Got the new 8.8 in under the MJ :bowdown: Looks like we will need about 6" of lift on the other end :cheers: Charles Link to comment Share on other sites More sharing options...
CEThomas Posted December 11, 2006 Author Share Posted December 11, 2006 This is IHRA MJ :D Charles Link to comment Share on other sites More sharing options...
Kernel Posted December 11, 2006 Share Posted December 11, 2006 pothole sniffer. Link to comment Share on other sites More sharing options...
CEThomas Posted December 11, 2006 Author Share Posted December 11, 2006 :D :cheers: Link to comment Share on other sites More sharing options...
CEThomas Posted January 7, 2007 Author Share Posted January 7, 2007 Front boby work done and wench bumper on. Charles Link to comment Share on other sites More sharing options...
SuicidalPenguin Posted January 8, 2007 Share Posted January 8, 2007 Front boby work done and wench bumper on. That's a sweet bumper. I like it. Link to comment Share on other sites More sharing options...
CEThomas Posted January 8, 2007 Author Share Posted January 8, 2007 Thanks, Charles Link to comment Share on other sites More sharing options...
warf90 Posted January 8, 2007 Share Posted January 8, 2007 Charles, The bumper looks great on the MJ! Link to comment Share on other sites More sharing options...
CEThomas Posted April 10, 2007 Author Share Posted April 10, 2007 Well just can not force myself to go back down on the MJ so the kid will have to learn to wheel on my Ranger and the MJ will be ready to go down the road. Here are some photos after we put the front end parts I got off 89MJay Sure looks like the caster is way off :eek: Lot of body work to start on soon :chillin: Charles Link to comment Share on other sites More sharing options...
Rokhound Posted April 10, 2007 Share Posted April 10, 2007 looking good :popcorn: Link to comment Share on other sites More sharing options...
88MJay Posted April 10, 2007 Share Posted April 10, 2007 Looking good. Throw a socket on top of one of the balljoints (make sure it fits on there nice and flush) and place a magnetic angle finder (can get them cheap at any hardware store) on top of the socket to check the caster. Should be around 7 degrees or so. Although a range of 5 to 9 is reasonable in most cases. Link to comment Share on other sites More sharing options...
CEThomas Posted April 11, 2007 Author Share Posted April 11, 2007 Looks to be 10 - deg :eek: Charles Link to comment Share on other sites More sharing options...
88MJay Posted April 11, 2007 Share Posted April 11, 2007 I'm not an expert on this but I remember my XJ having adjusters on the lower control arm frame brackets that would allow you to change the caster. Maybe you could get a couple degrees that way? I don't know if MJ's have them. I cut them off mine and didn't really pay attention. Link to comment Share on other sites More sharing options...
CEThomas Posted April 11, 2007 Author Share Posted April 11, 2007 Thanks, I will take a look this weekend. Link to comment Share on other sites More sharing options...
CEThomas Posted April 15, 2007 Author Share Posted April 15, 2007 Checked and both sides came out at 10 deg.s :eek: Charles Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 15, 2007 Share Posted April 15, 2007 I'm likin the project so far man. what're ya doin about the box? Link to comment Share on other sites More sharing options...
