warf90
Everything posted by warf90
  1. I am also planning this swap with a 92 XJ complete donor. What about the fly wheel? Does that need to be changed? Will the H.O. crank sensor work with the Renix Flywheel?
  2. Finally got to work on the temperature gauge problem. I found the purple wire open or broken in between the connector by the starter solenoid and the dash. I temporarly jumped a wire inbetween the sensor and the where the purple wire comes off the ignition switch and the guage functions properly. I think I am just going to run a new wire instead of trying to find the broken wire. OK now on to the fuel guage problem. Still have not figured out the cold running problem.
  3. The O2 sensor is new. I replaced that during the engine installation. I thought the O2 came in to play more when the system goes into the closed loop. Maybe not though. I replaced the sensor for the guage and not the computer. It is the sensor that has the threaded rod on the tip and it was from the back of the head. I am going to pull the sending unit back out and check it. It sure sounds like you may be right about the float getting hung up in the full position.
  4. I pulled the fuel pump/sending unit out of the tank that orginally went with the 4.0 L and installed into the tank in what was the 4cyl truck. The fuel pump/sending unit and instrument cluster were both in my other MJ before I junked it and it did work in the other truck. I guess I need to pull it bad out of the tank and make sure everything look ok with it.
  5. I have not had to time to get back to the MJ, but some of the problems that I have is, I do not know what year the cluster came out of. I am guessing that it is an 88. The previous owner swapped it out. I did buy a sending unit for a guage for an 88. I assume thats what I got from the auto parts store. As far as the gas guage not working. I did install the 4 liter pump with the rest of the sending unit that goes with it. The coolant temperature sensor for the computer is there an plugged up. It is a different sensor than the one needed for the gauge. I am still not sure of the running problem. What is the difference between an 89 4 cyl dash harness and a 90 6 cyl dash harness? I did not see anything different. It looked to me that all the connections were the same. It may be the problem, I am not sure.
  6. I swapped a 4.0 liter AW4 into what was a 4 cyl 5 speed MJ. I have a couple of issues that I need help with. The temperature gauge does not work at all. I am not sure what year the instrument cluster is from. I am guessing an 88 and I got the sending unit for an 88. The guage never moves. When I ground the wire out it still does not move. I had a spare gauage out of another 88 and installed it. Still no luck. The gas gauge does not work. It reads Full all time. Even when disconnect the wire under the bed the gauge does not move. When I ground it, it does not move either. But it is already reading past full. When I did the conversion, I left the dash wiring from the 4 cylinder in the truck. The 4 cylinder was a 89. The drivetrain was from a 90. They are both renix. The last problem I have is when it is cold it runs for about a 1 minute and then it wants to die. I have to give it gas to keep it running. When I drive it cold it stumbles from dead stop. It will only do that a couple times and then it is fine. When it warms up it runs good. THanks for the help.
  7. thanks for the info Eagle, thats good news.
  8. I am in the middle of swapping from a 2.5 liter manual 2wd to a 4.0/aw4 4wd. The 4.0 drive train came out of a 90 mj. This is going into a 89 mj. I am curious about the wiring harness for the dash and front lights. Is there a difference between the two. I know that I have to change the computer for the engine and that harness and add the auto computer and harness. Do I need to change the dash and front light harnesses?
  9. Image Not Found
  10. The 89 I am asking about is another MJ that I bought. It is a 4 cyl. The 90 I have is a 4 liter. Sorry for the confusion. The oxygen sensor makes sense, since it is running so rich. I do not want to put a ton of money into because I am junking the 90 and installing the drivetrain into the 89. The 90 I have is in pretty bad shape and the 89 I bought is in excellant shape. I just wanted to make sure the 4 cylinder was running good before I removed it and tried to sell it. The motor itself sounds and runs great. It only has 96,000 miles on it. Thanks for everyone's input.
  11. I would think a clogged converter would make it lose power all the time. This thng runs great for about the first 10 minutes of driving. Although I could see the O2 sensor causing problems. When you drive it, it seems like it is starving for gas or the spark goes away. You step on the pedal and it just bogs and some times it will back fire through the throttle body. But after all that it idles perfect.
  12. The other thing that I forgot to mention is the check engine light is on and it does smell like it is running rich when it is running. You are probaly right though, I should change the filter again and clean the tank better.
  13. Yes also installed a new sock on the pump. What does not make sense is that it ran great for a week and then started doing this. I wish I had a fuel pressure gauge.
  14. Sorry, yeah I also changed the fuel filter.
  15. On my 89 with a 2.5 liter, I bought this after it sat for 3 years. I drained the gas and had to replace the fuel pump. It ran great for a about a week. Now after you drive it for about 10 minutes in starts to lose power. The more you drive it the worse it gets. I can drive it and then bring it back to my garage and it idles fine. Its just when you are driving it, it falls on its face likes it starving for gas. Sitting in nuetral you can rev it and watch the gas spray through the throttle body but it just bogs down. I am puzzled. Please help.
  16. I jsut bought an 89 2wd with a 4 cyl 5 speed manual transmission. How do I tell what manual transmission is in this truck? I am going to try and sell the drive train out of it and I need to know to list it. Thanks
  17. I have performed a search and looked for any information that I could find. I am still a little confused about my problem. I have a 1989 MJ with a 4 cylinder that I just purchased for $200.00. Any way, it will not start. It is definatly fuel related. I check the fuel pump relay. The red wire from the fusible link has 12 volts, the yellow wire which I believe is the 12 volt switched has 12 volts. The problem is the relay will not change states when powered up. It acts like to me that it is not getting grounded. I have read in other posts that the ground back at the tail light may have something to do with it. Am I in the ball park of looking in the right place? Any help with this would be awesome.
  18. Great Looking MJ. Do you still have to get a permit to Ride at Royal Blue? I rode there about 5 years ago on that trail and it is awesome. That is one of my favorite trails.
  19. I have 4.10 gears with 33" X 12.50 and I am getting 15 mpg.
  20. I have an axle seal that continues to leak. I replaced the seal and the axle on that side and it still leaks. The front axle I have is a Dana 30 out of an 89 XJ. It has had the super 30 kit installed with an ARB Locker, 1 piece 30 spline chromolly axle shafts. It looks to me that the axle is not centered in the housing, therefore causing the seal to leak. It looks to me that the axle is shifted up, creating a gap between the seal and the axle shaft on the bottem. The only thoughts I had that could make that shift like that would be the ball joints or the unit bearing. The other thought is the housing could be bent, but it does not appear to be. I need to figure out a way to check all 3 of these things. Any one have any thoughts?
  21. warf90
    your first car
    MY first car at 16 was a 1978 Subaru GL 2 door 1600 cc! My first new car 1986 Toyota 4wd truck.
  22. I already have rear discs on the Dana 44 in my MJ. I was just looking around that yard and was curious if either one of these might be of any use. For example the Dana 35 fitting a Dana 44 with or with out modifications.
  23. I was at our pull and pay yard this weekend and saw a Grand Cherokee with a what looked to be a dana 35 with complete disc brake set up on the rear. I also found a Honda SUV with what looked to be a dana 44 with rear disc brakes, although it had 6 lug axles. Are both or either one of these worth grabbing if the price is right?
  24. Charles, I read in the thread that you measured 44 1/4" at the center of the rear opening. I went out and measured mine. I am running 33 X12.50 tires and SOA. Mine measured 40 1/8". Hope this helps you. Tim
