mnkyboy Posted August 1, 2012 Author Share Posted August 1, 2012 I haven't updated this in forever. The MJ is now running 4.88s and locked front and rear. I trussed the front axle and finally got the D44 and disc brakes built and installed as well as a dual diaphram brake booster. I also bobbed about 16" off the bed. Its not done but getting there,I've driven it a little and the truck is much happier with the new gears. Link to comment Share on other sites More sharing options...
Darren Posted August 7, 2012 Share Posted August 7, 2012 Nathen that looks awesome! I can't wait to see it in person. Link to comment Share on other sites More sharing options...
89eliminator Posted August 7, 2012 Share Posted August 7, 2012 looking good. any plans to ditch the rear axle shock mounts? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 7, 2012 Author Share Posted August 7, 2012 goblazers_6 said: Nathen that looks awesome! I can't wait to see it in person. You should make the trip up the hill some time Link to comment Share on other sites More sharing options...
mnkyboy Posted August 7, 2012 Author Share Posted August 7, 2012 89eliminator said: looking good. any plans to ditch the rear axle shock mounts? Eventually they will go I just wanted to get it together. I don't want to give up any travel so the shocks will go into the bed,but that's another project for later. Link to comment Share on other sites More sharing options...
mnkyboy Posted August 7, 2012 Author Share Posted August 7, 2012 Link to comment Share on other sites More sharing options...
mnkyboy Posted August 9, 2012 Author Share Posted August 9, 2012 Got my hyd hand brake installed and all hooked up. It works awesome with the new disc brakes,it will ratchet and work as a park brake or I can disable the ratchet and use it to hold on a hill or obsticle. Now that I have brakes again I was able to drive around a bit and check out the new gears,with 4.88s its like a different truck. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 9, 2012 Share Posted August 9, 2012 Sweet MJ man! I like the bobbed bed. I actually have been trying to find a pic of someone that bobbed a short bed, was thinking about doing it to mine. Keep up the good work! Link to comment Share on other sites More sharing options...
mnkyboy Posted August 9, 2012 Author Share Posted August 9, 2012 Thanks. The bed turned out pretty good,the hardest part was blending the inside of the bed. I don't care for having my springs so far behind the truck but I guess I have to live with it till I can get around to linking the rear. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 9, 2012 Share Posted August 9, 2012 mnkyboy said: Thanks. The bed turned out pretty good,the hardest part was blending the inside of the bed. I don't care for having my springs so far behind the truck but I guess I have to live with it till I can get around to linking the rear. yeah believe it or not I just noticed the springs lol. Yeah linking it would fix that. Or what about using XJ springs. they are 5.5" shorter. You would probably have to flop them to get the right wheelbase. Just a thought. Link to comment Share on other sites More sharing options...
mnkyboy Posted August 9, 2012 Author Share Posted August 9, 2012 I considered it,I've got a few sets of XJ packs laying around. Problem with the shorter pack is I will lose some flex and I already don't like how the rear flex's vs the front. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 9, 2012 Share Posted August 9, 2012 mnkyboy said: I considered it,I've got a few sets of XJ packs laying around. Problem with the shorter pack is I will lose some flex and I already don't like how the rear flex's vs the front. This is true. I didnt think about that. Then I guess linking it is the way to go! Link to comment Share on other sites More sharing options...
89eliminator Posted August 9, 2012 Share Posted August 9, 2012 what was the decision of putting the truss on the bottom of the tubes as opposed to the top? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 9, 2012 Author Share Posted August 9, 2012 I wanted to go from C to C but didn't want to go through the trouble of going on top of the axle since its temporary. I have a HP D44 waiting to be retubed,I plan to build a nice truss on top when I build the 4 link mounts. The truss seems to work well,and the loss of clearance isn't as much as I thought it would be but we will see when I get into the rocks. Link to comment Share on other sites More sharing options...
mnkyboy Posted August 13, 2012 Author Share Posted August 13, 2012 Worked on my new taillight mounts/armor Link to comment Share on other sites More sharing options...
mnkyboy Posted August 14, 2012 Author Share Posted August 14, 2012 Built myself a t-case skid today Link to comment Share on other sites More sharing options...
mnkyboy Posted August 28, 2012 Author Share Posted August 28, 2012 Worked on the tail lights today. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 28, 2012 Share Posted August 28, 2012 Do you still have the passenger side taillight? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 28, 2012 Author Share Posted August 28, 2012 The stock lights are in pretty bad shape. I will have to look at it but I'm thinking it got broken more since I took it off. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 28, 2012 Share Posted August 28, 2012 mnkyboy said: The stock lights are in pretty bad shape. I will have to look at it but I'm thinking it got broken more since I took it off. If it aint in too bad of shape I might buy the passenger side one from that is if you don't want an arm and leg for. All I need is the Passenger side. Its that or I'm doing LED housings like yours. How hard were they to make btw? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 28, 2012 Author Share Posted August 28, 2012 I will look at it,if its useable you can have it for whatever shipping is. The rear armor/light housings were fairly easy to make but I have a pretty well set up shop. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 28, 2012 Share Posted August 28, 2012 mnkyboy said: I will look at it,if its useable you can have it for whatever shipping is. The rear armor/light housings were fairly easy to make but I have a pretty well set up shop. thanks man. Yeah I'm just working out of the garage. Did you just bend the plate around the corner or cut, weld and grind? Link to comment Share on other sites More sharing options...
mnkyboy Posted August 28, 2012 Author Share Posted August 28, 2012 I made them in two pieces,one I rolled for the contour of the side and the other I rolled to make the bed corner then welded them together. Link to comment Share on other sites More sharing options...
Rockdrummer93 Posted August 29, 2012 Share Posted August 29, 2012 Thanks. I'll have to see what I can work out Link to comment Share on other sites More sharing options...
pilecenturyfarm Posted August 30, 2012 Share Posted August 30, 2012 mnkyboy said: I made them in two pieces,one I rolled for the contour of the side and the other I rolled to make the bed corner then welded them together. You wouldn't be interested in making a set and shipping them out would you... no lights just the housings precut... Link to comment Share on other sites More sharing options...
