My MJ only has the metal loops down inside the bed to use as tie-downs. At some point, there were rails on the top of the bed, as evident by the dozens of holes that are there.
What have you done in regards to bed rails/tie downs?
kinda hillbilly-ish, but I'm using large eyebolts with fender washers at each corner on top of the bedrails. Cheap, yes.....attractive, no. But I do use my MJ as the truck it was built to be sometimes, and nothing about it is attractive anyway :D
Jeff
edit: not the best pic, but this is what I'm talking about.
Image Not Found
whats wrong with the tie down spots in the bed?
Nothing, until the bed is full of gravel or mulch and you need access to that tie down.
XJ roof racks
Cool idea , I'm borrowing that one for sure 8)
Same here, but for a different application than to be used as tie down locations. :idea:
Whats all that white stuff all over the place????? :yes: :yes: :yes:
The sno-cone factory up the road blew up, and that's all the debris that got scattered around. :fool:
I'm not exactly sure how that roof rack idea works, since I don't have one. Can you explain to a retard?
Essentially, just screw the roof rack rails into the top inside of the bed and slide the main supports for the cross bars into them. By doing so, it gives you a tie-down location that is at the top of the bed, and can be adjusted to fit the current hauling needs.
EDIT: The cross bar support can be seen in Geonovast's first pic.
You can see it in the second one too, it's up by the truckbox.
You can see it in the first one too, it's up by the truckbox.
:huh???: I think you mean it can be seen in the second one too. :wavey:
That's what I said... Don't misquote me.
:rotf:
That's a pretty neat idea. Do you have more pics/info/write-up?
I love stuff that is modular like that. mmmmm
That is a great idea. I will also be stealing that one. Just need to trim my bed liner so that it is under rail instead of over rail.
Why not leave the bed liner over rail, and screw the XJ runners over the top of the bed liner. into the top inside of the bed :hmm:
You don't need self tappers. Bolts I'm using are the original bolts off the XJ. Torx, but the heads sit flush like they're supposed to so the thinger can slide over it.
Did you have to use 4 sets of the rails? Seems like one track wouldn't be long enough to stretch the whole length of the bed.
