comanche body lift?
If you're very talented with a plasma cutter, can work metal and weld good enough, you could probably make the cab removable, which in itself would probably give you a 2-3 body lift.
I never saw the point of a body lift more than an inch. Why stuff the bigger tires if you don't gain any flexibility from it?
My boss and a couple of guys i work with swear by body lifts. I think anything over a 1 inch looks ridiculous, as they are all rocking 3 inchers, and could drive a mack truck through the frame and body gaps they have created. Ugly as hell. My bosses' only excuse is he wanted a true 3" of lift, plus his tires, and he only had fragments to spare in garage height. He pulled it off ok IMO. Gap guards, bumper relocates... Rest of the guys I work with are just plain idiots.
Rob L.
Rob L.
yup. they are ugly, and do not offer anything other than an ugly gap, and tire clearance. no enhanced suspension travel or performance. i hate them with a passion.
The limit in IL is a 3 inch body lift. Found this out when I was layed off and spending the winter driving a wrecker a couple of years ago.
The story....
The police dispatcher calls and gives me a 1-vehicle accident, truck split in half with FD enroute. I go and pick-up the rollback thinking I am going to be spending some time winching pieces of a truck onto it tonight. But what has me wondering is the fact that dispatcher gave me an in-town address. I can't figure out how they managed to hit anything hard enough to split a vehicle in two.
I get to the scene to find the pick-up sitting in the middle of the street, like it was parked there. Just missing its bed. Now its fairly normal to see pick-ups with all sorts of home made, stake beds, flat beds, or even just a sheet of plywood thrown over the frame. I get out and the officer brings me over and says, I don't know how they did it.. but the bed from the truck is wedged across the street between two trees.
The bed is REALLY wedged between these two trees. It is sitting on about at 40 degree angle and all the grass is torn up from the street to it. I couldn't pop it loose from its position with a crow bar and even with some Fire/Rescue guys we couldn't pop it loose. I ended up winching it out, bending the heck out of it in the process. After we got the truck back to shop, the police measured the aluminum cylinders used as a body lift at 5 inches.
The accident reconstructionist said that the kid driving hit the box against a tree on the corner. This caused the bolts through the blocks to break off. When he turned the corner the box was slungshot off the frame and skidded across the street on its side. It hit the trees on the other side of the street and fell over wedging itself.
Maybe it is the redneck in me but...
I really like that truck!
I bet he makes a bundle renting it out for redneck weddings & funerals. :thumbsup:
(how many gunracks do you think it has?)
Rob L.
out here in nh, body lifts are great. there inst much for rock crawling and its way cheaper than buying a suspension kit. you can run bigger tires and you get axle clearance and you can take lawn edging and cover your gaps. in fact companies make gap guards so you don't have the look. out how often do most people fully max out there suspension to the point where they need to have that extra bit of travel? i know some do, but its really not that many. so just think of how economical they are next time you start insulting a genius idea.
