ComancheKid45 Posted March 3, 2010 Share Posted March 3, 2010 lol well thats the 1 i went with, besides the fancy chrome trim its the same :rotf: Link to comment Share on other sites More sharing options...
MjAllTheWay Posted March 3, 2010 Share Posted March 3, 2010 Thanks man i looked at that one dident really like it i kinda like the other one because of the black and chrome Link to comment Share on other sites More sharing options...
carnuck Posted September 23, 2010 Share Posted September 23, 2010 I kind of wondered about doing this! Cool that it works! Now how about a pic of where the Shift cable comes through the firewall? Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 23, 2010 Share Posted September 23, 2010 Link to comment Share on other sites More sharing options...
relyt120 Posted June 29, 2012 Share Posted June 29, 2012 Once again I'm going to post to a very old thread. I have a 3/4 cluster(guages but no tach) I want to put in my truck in place of the idiot lights that are currently installed. Only problem is that I have a column shifter and don't want to lose my prnd12, obviously. I need to know if I can remove the face of the full size gas gauge with the opening already present and transfer it and the indicator to the new 3/4 cluster without f'ing anything up and having to buy another one. I don't really want to cut a hole since I do have a gauge face that has a perfect opening in it. So what do you think, will I ruin it? :hmm: Thanks in advance for your input. Link to comment Share on other sites More sharing options...
johnj92131 Posted June 29, 2012 Share Posted June 29, 2012 Very short answer, NO. The plastic case of the. 3/4 cluster does not have the hole to put the needle thru. You need to use the old case. Put the new gauges in the cluster, excep for the fuel gauge. You also need to swap the printed circuit board form the 3/4 cluster. You don't say what year. Link to comment Share on other sites More sharing options...
relyt120 Posted June 29, 2012 Share Posted June 29, 2012 its an '89. I figured that might be the case, actually may be better since I bought it not realizing the guy had separated the light box on the left and only sold me the main part...... Link to comment Share on other sites More sharing options...
relyt120 Posted June 29, 2012 Share Posted June 29, 2012 So remove gauges, put in old case, move board, done? Thank you for your help. Link to comment Share on other sites More sharing options...
johnj92131 Posted June 29, 2012 Share Posted June 29, 2012 That's the way I was going to do my 91. Link to comment Share on other sites More sharing options...
relyt120 Posted June 29, 2012 Share Posted June 29, 2012 Turns out its not that easy. :fs1: The gauges won't go into the dummy light housing since it doesn't have the appropriate holes. So I used the new housing and drilled a hole for the prnd12 cable to go through. You'll see where the side light box is missing :doh: so I trimmed the one I had and it will mount on its own. :wrench: This one is the dummy. This one is the 3/4. So pretty much I ended up just moving the prnd12 and the gas gauge to the new housing. I havent re-installed it in the truck yet, will post pics when complete. Link to comment Share on other sites More sharing options...
relyt120 Posted July 1, 2012 Share Posted July 1, 2012 :hijack: At the fourth post in a row I believe this thread is officially hijacked . long story short: went to install it and switching the gas guages in the 3/4 cluster is not possible since they use different screw holes for the circuit had to cut a hole :fs1: after that everything was fine. Thank you to OP for the excellent information. Link to comment Share on other sites More sharing options...
EUREKA Posted January 14, 2022 Share Posted January 14, 2022 On 2/20/2009 at 9:15 AM, HOrnbrod said: The indicator (made by Ididit) window is fastened to the fixed upper column housing and the pointer is fixed to the moveable middle column housing. This indicator is for a GM 3-speed tranny, but it lines up perfectly with the AW4 shift points. Not illuminated though so I'm working on a small LED to embed within the movable pointer. Resurrected. Sorry to people who don't like thread necromancy. Did you ever get that LED figured out? Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2022 Share Posted January 14, 2022 12 minutes ago, EUREKA said: Resurrected. Sorry to people who don't like thread necromancy. Did you ever get that LED figured out? Don passed away a couple years ago. maybe someone else remembers if he did? Link to comment Share on other sites More sharing options...
EUREKA Posted January 14, 2022 Share Posted January 14, 2022 Just now, Pete M said: Don passed away a couple years ago. maybe someone else remembers if he did? Oh, I'm sorry to hear that! I've read a lot of his posts over the years. Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2022 Share Posted January 14, 2022 we all have. his words of wisdom live on. Link to comment Share on other sites More sharing options...
schardein Posted January 14, 2022 Share Posted January 14, 2022 14 hours ago, EUREKA said: Resurrected. Sorry to people who don't like thread necromancy. Did you ever get that LED figured out? If you have pick-n-pull type junkyards near you, you might go check out 70s-80s GM full size vans. They used similar steering column mounted shift indicators. They were lighted from the factory. Older ones will be for 3 speed transmissions (like TH350/TH400) later will be four speed (like 700R4). Here is an example of a 3 speed type. You can see the bulb in the lower bracket that is wired into the dash lighting circuit. You best bet is to find and pull one in a junkyard yourself so you see how they come off/are installed, so you can adapt it to your column. Link to comment Share on other sites More sharing options...
EUREKA Posted January 14, 2022 Share Posted January 14, 2022 That's a great idea! Unfortunately we lost our only yard to a fire. Nearest one is a 3.5 hour drive, and it's a twisty one at at that. Link to comment Share on other sites More sharing options...
89 MJ Posted January 19, 2022 Share Posted January 19, 2022 On 1/14/2022 at 10:10 AM, schardein said: If you have pick-n-pull type junkyards near you, you might go check out 70s-80s GM full size vans. They used similar steering column mounted shift indicators. They were lighted from the factory. Older ones will be for 3 speed transmissions (like TH350/TH400) later will be four speed (like 700R4). Here is an example of a 3 speed type. You can see the bulb in the lower bracket that is wired into the dash lighting circuit. You best bet is to find and pull one in a junkyard yourself so you see how they come off/are installed, so you can adapt it to your column. That same era Chevy pickups and Jeep J-Trucks will work too. You can also find some of those Squarebody pickups (starting in 84 for the c10 and k10, IIRC) with an overdrive transmission, so those ones will more than likely have a slightly different indicator, but I could be wrong on that. Link to comment Share on other sites More sharing options...
schardein Posted January 19, 2022 Share Posted January 19, 2022 4 minutes ago, 89 MJ said: That same era Chevy pickups and Jeep J-Trucks will work too. You can also find some of those Squarebody pickups (starting in 84 for the c10 and k10, IIRC) with an overdrive transmission, so those ones will more than likely have a slightly different indicator, but I could be wrong on that. The 73-87 Chevy trucks (91 for Suburbans and Blazers) had the gear indicator in the dash panel rather than on the steering column. I think the 72 and earlier trucks had it on the column. Link to comment Share on other sites More sharing options...
EUREKA Posted January 19, 2022 Share Posted January 19, 2022 2 hours ago, schardein said: The 73-87 Chevy trucks (91 for Suburbans and Blazers) had the gear indicator in the dash panel rather than on the steering column. I think the 72 and earlier trucks had it on the column. Thanks! I will probably go this route when I get back to my 91 MJ. I deleted the floor shifter and plan to convert it to column shift. Link to comment Share on other sites More sharing options...
