Best way to Lower a Comanche
For the front, I'd start with some ZJ V8 coils.
I'd use the V8's, to get thicker spring to start with.
Cutting them down stiffens up the ride further, but as you lose up travel, you'll want the higher spring rate.
I've trimmed XJ/ZJ coils down before, cutting off that slight flat section at the bottom hasn't effected me negatively at all,
YMMV, but I didn't have any issues with it.
You could even start trimming your stock coils, to see what height you like, before taking the knife to the ZJ coils (in case you cut too much).
I don't know how much is too much.
I'd probably try to figure what the minimum up travel I'd be happy with (depending on use), and set my ride height to allow that.
For the rear, try keeping the MJ main leaf, and swap all the lower leafs out for (flatter) XJ leafs.
They're shorter, but should still be OK, and they're not up to the same load carrying either, but I'm guessing you're not building it to carry heavy loads.
Again, I'd try to trim the bumpstops as much as I could, while keeping hard parts away from each other, and set the height at the minimum up travel I'd be comfortable with.
You might end up looking for some thicker, flat leafs to replace 1 or 2 of the XJ leafs with, to keep the ride height down, while firming things up.
Overload coils on shocks, or air shocks could be bandaid fixes, but I'd try to dial the pack in for my needs.
FWIW, you could build shackles shorter than XJ's, if you wanted to.
Would have the side effect of being stiffer than the stockers, and you could use poly/graphite bushings too.
I didn't have any stock XJ shackles, so I made these little guys up to drop my XJ at inspection sticker time (compared in pic to unknown lift shackles):
Image Not Found
Image Not Found
I didn't bother to bush the upper mount, since they only go in for a short time.
Wow thanks for the input! I'm going to try and refrain from cutting any springs or other major fabrication. Trying to keep it a simple low-budget bolt on project. I will try the V8 ZJ coils first since they will definitely be the most firm. Once I get the front where I like it then I will start on the rear. To start with I will probably do XJ shackles and 2 inch blocks. As the budget allows I might have a custom spring pack built to replace the blocks. Since I'm trying to keep the drop around 3 inches, I should be able to avoid major metal work and modifications. But that is still great information for anyone wanting to go even lower.
just to clarify, you WILL have to cut those V8zj coils. Otherwise you will see about a 1in lift. I was planning on taking about 1.3 turns off of a set of coils I have from a 2000 xj. You would need to take more off the ZJ coils.
Then we'll go straight to the Ranger coils. It has been stated in several places that rear stock ZJ coils will drop the front end slightly. I plan to compare both the Ranger and ZJ coils, to see if the theories are correct and how much difference can be measured.
wolfpack is right, V8ZJ's will lift you, unless you cut them.
Cutting is easy, just need a cutting wheel on an angle grinder (& safety glasses)
I understand if you don't want to do it.
I don't have any experience with Ranger coils, so I can't comment on those.
As far as the blocks go, packs would be better, but if you're gonna do blocks DO NOT get aluminum blocks (cheap ones that most carry as lift/drop blocks).
I had a pair of Summit Racing brand aluminum blocks way back when.
Both cracked in half within a couple months.
Glad I noticed it, before they broke free from the Jeep.
Superlift always had nice cast iron blocks, that's what I replaced the broken Summit's with.
Info is 15 years+ old now, so YMMV.
Good luck :cheers:
the winch maker use to make a lowering kit for the comanches years ago, i found one at a little truck shop in canada like 4 or 5 years ago gave me a drop 2" drop all the way around and handled great look up my project "my lowered jeep", i used a 4" steel block and xj shacklesto give me a nice level look with the bump stops removed in the rear
pm me if your interested for the front springs
  • 3 months later...
so what did everyone figure out?? I'm looking to do a 3/4 on the MJ and this post is perfect. but since i won't be starting for a couple of weeks i would like to know how everyone made out.
yeah i figured removing a leaf would probably give the least desirable results.
And its ok if the ride quality suffers a little bit, the DD is a Cadillac! :yes:
Well mine rides like a caddy :brows: :chillin:
don't drop it!!!!!!! Taller is better...........But if you must you could always put some lawn mower tires in it..........drop it by a foot maybe :idea: :nuts: :popcorn:
Idk :rotf:
  • 7 years later...
I remember seeing a youtube video of a guys street comanche where in order to keep the front suspension geometry like stock he took a 2wd beam cut the ends off it and welded them on top of the center of another 2wd beam, so it would lower it the thickness of the tubes and the control arms should keep stock angles. I think it would still need shorter springs.
