kmack Posted January 22, 2010 Share Posted January 22, 2010 how do you guys calculate the exact amount of gas your using? when i fill up i can drive for a while before the guage starts to move, and when its reading empty, i can usually drive for a while still so i don't know exactly what the fuel capacity is. it seems between 70 and 80 litres. and i have 235/75s and thats not whats listed in my door, does that mean my speedo is off? Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 1. Write down odometer reading. 2. Fill tank until the pump stops itself. 3. Go driving for awhile, probably until your needle is at about half. 4. Go fill tank back up (most accurately at the exact same pump) until the pump stops itself. Divide the mileage you traveled by the amount of gas you put in the second time. Link to comment Share on other sites More sharing options...
kmack Posted January 22, 2010 Share Posted January 22, 2010 is this common knowledge? :doh: Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 is this common knowledge? :doh: Simple math. Link to comment Share on other sites More sharing options...
kmack Posted January 22, 2010 Share Posted January 22, 2010 :Canadaflag: :chillin: Link to comment Share on other sites More sharing options...
kmack Posted January 22, 2010 Share Posted January 22, 2010 o ya. is my tire size going to affect the odometer? i thought 235/75 was stock. Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 235/75R15 is a hair above stock. Stock sizes ran from 195/75/R15 to 225/75/R15 There's a chart around here somewhere that shows what speedo gear you need for your tire/gearing combo. Link to comment Share on other sites More sharing options...
jimoshel Posted January 22, 2010 Share Posted January 22, 2010 '89 2.5 AX5, 4:11, 215.65R15. 21 MPG using 85. Heavy footed. Generally run 80-85. Don't go by speedometer. It's exactly 16 miles from my boony hut to the intown home. 14 mile from service sta to home. One round trip 32 miles.Fill up every second trip, 64 miles. 3 gals. Link to comment Share on other sites More sharing options...
WBKrazy Posted January 22, 2010 Share Posted January 22, 2010 88 shortbox 2.5 ax-4 2wd, 225/75/15's and 3.55's.... was getting between 20-22, mostly highway Link to comment Share on other sites More sharing options...
DJM/78 Posted January 22, 2010 Share Posted January 22, 2010 I don't get very good milage , mine is a 4.0 HO , DD , 31" tires , high altitude driving and a lead foot . :yes: 31" only took my spedo off about 5mph , not too bad . It evens out because I drive my bikes as DD , two thirds of the year . :banana: Here comes spring . :thumbsup: Link to comment Share on other sites More sharing options...
jimoshel Posted January 22, 2010 Share Posted January 22, 2010 The last time I come down Pikes Peak I got 762.5 MPG. Link to comment Share on other sites More sharing options...
DJM/78 Posted January 22, 2010 Share Posted January 22, 2010 The last time I come down Pikes Peak I got 762.5 MPG. :rotf: Yeah , but you need a Fred flinstone manual brake , to keep from flying of the edge . :shake: Link to comment Share on other sites More sharing options...
JeepcoMJ Posted January 22, 2010 Share Posted January 22, 2010 my 87 lifted MJ with brand new H.O., .030 bore, comp. cam, borla header, 2001 intake, 62mm TB, mustang injectors, K&N filter, aw4 auto, 4.10 gears, and 33's will net me between 17mpg and 22mpg depending on how I'm driving and if I'm on the interstate or not. with the 35's on it, I get a max of 16mpg usually around 14.7mpg. my 86 (when it was running/driving) got me between 26mpg and 32mpg...but i put a '96 camaro 3800 v6 in it. my 86 diesel gets between 28mpg and 36mpg, depending on how/where I'm driving it. Link to comment Share on other sites More sharing options...
vaquaro Posted January 23, 2010 Share Posted January 23, 2010 90 W/ 2.5-AX 4-3:55 -2wd -235/75 x15....21mpg city /25.5 mpg hiway ,GPS corrected milage - :D Link to comment Share on other sites More sharing options...
Pete M Posted January 23, 2010 Share Posted January 23, 2010 fuel mileage is overrated. or maybe I should put it as knowing your fuel mileage is overrated. :D knowing those numbers doesn't affect how I drive or what I drive. I guess if the numbers start dropping off it might show that there's a problem, but there are other indicators of a bad o2 sensor or fuel leak or clogged cat. :dunno: Link to comment Share on other sites More sharing options...
comanchedude Posted January 23, 2010 Share Posted January 23, 2010 4.0/AW4/231, 33s with 4.10s. Best tank to date was 20mpg. Usually average around 16-18 though. same here.. but i just went 35s..so don't know yet if it changed much Link to comment Share on other sites More sharing options...
Squeegy410 Posted January 24, 2010 Share Posted January 24, 2010 Wellllll.... Mine says it gets about 20 mpg, butttttt... I always knew the speedometer was slow, so last night i pulled up next to a cadilac or something with a huge digital readiout. it read 57, mine read 47 :ack: I knew it was about that far off but it't not because of my tires or anything. The previous owner was a world renown cheap skate and I'm positive he messed with the speedometer til he got it to slow down and make his miles stay down so he could sell it. Still a good jeep, and I can honestly say it gets OVER 20 mpg :D so i have a ball park of my mpg and I don't care enough to be acurate. BTW thats a 4.0 5speed. IDK the gears. Link to comment Share on other sites More sharing options...
mvusse Posted January 24, 2010 Share Posted January 24, 2010 57/47*20=24mpg. Link to comment Share on other sites More sharing options...
kmack Posted January 24, 2010 Share Posted January 24, 2010 11l/100km or 21mpg 4.0 5spd renix Link to comment Share on other sites More sharing options...
krochus Posted January 30, 2010 Share Posted January 30, 2010 My 2wd 5 speed 4.0HO powered sport xj is really surprising me with a running average of 20.8mpg in mixed driving over the past 4 fillups. Best of all this thing is a rocketship compared to the 16mpg 4.0ZJ it replaced or my lifted and locked yj EDIT: If you have speedo accuracy questions and use an iphone there's an app that's a "GPS" speedometer. I use it and have tested it and it's dead on accurate Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted January 30, 2010 Share Posted January 30, 2010 1987 SWB, 2.5, 4sp manual, 2wd, studded 235/75-15s, canopy, hilly terrain, daily driver. 33 highway miles/day round trip to work, 5 days/week. Last tank I received 18.2 mpg. Previous tank was 18.8, and the one before that 18.3. Pretty consistent at 18 mpg. Link to comment Share on other sites More sharing options...
mnkyboy Posted January 30, 2010 Share Posted January 30, 2010 2.5,AX4,3.55 and 31X10.50s i usually got 17-18mpg, i havent checked it with the 33X12.50s but i can tell its much lower. I need gears bad Link to comment Share on other sites More sharing options...
