hogelectra Posted November 20, 2008 Share Posted November 20, 2008 The previous owner installed a PS unit on my MJ. It works fine but when I go under neath working on the suspension I found something alarming. By adding a new fan belt to the configuration it rubbed against the lower radiator hose. So to solve the problem he zip tied it to a control arm. I can see me in the desert here in AZ and the zip tie breaking and wearing through my hose, water draining out and my engine overheating leaving me strained. My question how best to fix: 1. Better way of holding the hose away 2. Find a replacement hose that is longer that will naturally not run against the belt 3.. The PS unit has to come off Image Not Found Link to comment Share on other sites More sharing options...
carnuck Posted November 20, 2008 Share Posted November 20, 2008 The hose for a PS unit has a bend to move it away from the belt. Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 20, 2008 Share Posted November 20, 2008 carnuck said: The hose for a PS unit has a bend to move it away from the belt.It appears to be the radiator hose that has the zip tie holding it down to the LCA... If it were mine, I would get the right equipment for it instead of trying to find ways to rig what's not supposed to be there. Link to comment Share on other sites More sharing options...
reson46 Posted November 20, 2008 Share Posted November 20, 2008 Can you get a better picture? That one is pretty small and it's hard to tell what is going on. It would be interesting to see the PS unit and the modifications to the radiator hose. But, regardless of what is currently rigged, 1 and 2 are not even options. If a PS or radiator hose is zip tied to the control arm get that stuff out of there. Go to the junk yard and replace the mess with the stock set up. Willy Link to comment Share on other sites More sharing options...
Eagle Posted November 20, 2008 Share Posted November 20, 2008 Can you take a pic from the top of the engine looking down at the hose and PS unit? I have an '86 XJ 4-cyl here and an '88 MJ 4-cyl. Both have power steering. I can probably get you a photo over the weekend for comparison to your setup. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2008 Share Posted November 20, 2008 Looks to me like the power steering pump return hose is tie-wrapped to the tierod? If so, that's insane. :nuts: Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 20, 2008 Share Posted November 20, 2008 I blew up his pic the best I could. I think you can see a little better now that the zip tie is around the lower radiator hose...you just can't see the LCA because of the draglink in the way. Link to comment Share on other sites More sharing options...
mvusse Posted November 21, 2008 Share Posted November 21, 2008 I'll try to remember to see what my setup looks like tomorrow afternoon, but it might be hard to tell with the skid plate in the way. I do know for a fact that my (factory) power steering does not include a zip tie on the lower radiator hose, although there are a number of zip ties on various other engine parts (that are factory :nuts: ). Link to comment Share on other sites More sharing options...
hogelectra Posted November 21, 2008 Author Share Posted November 21, 2008 Went to the auto store today - only one hose for the lower radiator. Here are more pictures. I sure appreciate this help. Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
offroader461 Posted November 21, 2008 Share Posted November 21, 2008 Where in Az are ya...maybe you can stop by my house and i can take a look at it for ya....Pm me if you wanna do that Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 21, 2008 Share Posted November 21, 2008 In this picture...it appears the zip tie is attached to the track bar... Image Not Found Link to comment Share on other sites More sharing options...
reson46 Posted November 21, 2008 Share Posted November 21, 2008 That looks like a bad situation just waiting to happen. I would suggest replacing it with the stock PS and belt set up. :thumbsup: Willy Link to comment Share on other sites More sharing options...
jaekl Posted November 21, 2008 Share Posted November 21, 2008 It looks like he mounted the original pump higher. It's the brackets that are odd. Otherwise it's a 86 set up with a separate belt. Normally the pump is a lot lower with a shorter belt but my belt is farther forward. Perhaps it's the wrong water pump which made him change the alternator belt resulting in the steering belt farther back. Those are definitely home made brackets. Link to comment Share on other sites More sharing options...
hogelectra Posted November 21, 2008 Author Share Posted November 21, 2008 Yes home grown and not thought out - finding that everywhere and correcting as I discover his handywork. What I need is to see a factory setup and see if there is a way of fixing this Link to comment Share on other sites More sharing options...
Redramman Posted November 22, 2008 Share Posted November 22, 2008 Replace the hose.My Ram has lower hose on other side but it has a wiggle bend in it to go around the serpentine belt.If you can't find a hose to fit that try some metal tubing with shorter rubber hose conecting each end.Look at Street Rod and racing catalogs and websites.Get a bracket that holds hose to an engine bolt . Link to comment Share on other sites More sharing options...
BLHTAZ Posted November 22, 2008 Share Posted November 22, 2008 Redramman said: Replace the hose.My Ram has lower hose on other side but it has a wiggle bend in it to go around the serpentine belt.If you can't find a hose to fit that try some metal tubing with shorter rubber hose conecting each end.Look at Street Rod and racing catalogs and websites.Get a bracket that holds hose to an engine bolt .That's not fixing the problem though. Why make all that effort to put a band-aide on something instead of doing it right when you know what it needs :dunno: Link to comment Share on other sites More sharing options...
hogelectra Posted November 23, 2008 Author Share Posted November 23, 2008 Could someone past some pictures of how the power sterring unit is installed on a 2,5L Link to comment Share on other sites More sharing options...
carnuck Posted November 25, 2008 Share Posted November 25, 2008 Kellena Moedt asked how to post pics. The way to do it now is to open a Comanche Club Image Hosting account and then use their link system to post up. Link to comment Share on other sites More sharing options...
jtdesigns Posted November 25, 2008 Share Posted November 25, 2008 carnuck said: Kellena Moedt asked how to post pics. The way to do it now is to open a Comanche Club Image Hosting account and then use their link system to post up. I think he's asking for some stock pictures from a 2.5.. I would post them for you but I don't have a 2.5, I have the 4.o. Someone on here could do that I'm sure..... anybody????? :help: Link to comment Share on other sites More sharing options...
carnuck Posted November 26, 2008 Share Posted November 26, 2008 Gotta get some daytime to do it. I have both 4.0L and 2.5L. The serpentine set up 2.5 is same as 4.0L. Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2008 Share Posted November 26, 2008 carnuck said: Gotta get some daytime to do it. I have both 4.0L and 2.5L. The serpentine set up 2.5 is same as 4.0L. He doesn't have a serpentine setup. I'll try to take pics of both the '86 and the '88 over Thanksgiving and post 'em up. Link to comment Share on other sites More sharing options...
hogelectra Posted November 28, 2008 Author Share Posted November 28, 2008 I appreciate the help - looking forward to pics Link to comment Share on other sites More sharing options...
Sugarfoot Posted November 28, 2008 Share Posted November 28, 2008 Looks like a longer hose might work. Your hose looks a little bloated anyway and also looks to maybe have been trimmed down? How much travel in the adjustment of that belt? Shorter/longer belt maybe? You don't need much. No $$ loss as you would always have a spare. Check your motor mounts. Link to comment Share on other sites More sharing options...
manche Posted November 30, 2008 Share Posted November 30, 2008 glad I'm manual steering :driving: Link to comment Share on other sites More sharing options...
